Old 02-04-2014, 06:48 PM   #29
fasterthanu
Drives: 2014 R32
I used 3rd gear hard on freeway on ramps. It was definitely my favorite.You have the "meat" of the powerband when merging with traffic 2nd Is too short and 4th is just too tall. That is without a doubt the worst street beating I could give it on a daily basis.
fasterthanu is offline   Reply With Quote
The Following 3 Users Say Thank You to fasterthanu For This Useful Post:
schmearcampain (02-04-2014), strat61caster (02-04-2014), Wattage (02-04-2014)
Old 02-04-2014, 06:58 PM   #30
illest86
I can't remember what 3rd feels like... it's been away since November. Sense my bitterness?
illest86 is offline   Reply With Quote
Old 02-04-2014, 07:01 PM   #31
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
I shift at 3K rpm for my daily driving/work, but generally only get to second gear because of traffic..
I also skip gears but generally from 4th-> 6th
calmtigers is offline   Reply With Quote
Old 02-04-2014, 07:04 PM   #32
Tromatic
Originally Posted by Mister View Post
Thank you for reminding me why I have a personal policy to avoid buying used import sports cars.
+ Jaun to that. I find that first is all I need, though. 5500 RPM all the time everywhere I go.
Tromatic is offline   Reply With Quote
Old 02-04-2014, 07:21 PM   #33
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
In Automatic mode I wish 4th wasn't there sometimes and in Manual mode I usually forget about 6th. Woe is me for driving an auto
Old 02-04-2014, 08:31 PM   #34
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
Somebody said skipping gears can cause more wear and tear?...I've never heard of such bs. Gm's vettes/camaros/ta's with the T-56 trans have had a skip-shift feature for years for economy reasons.
Car is gone - parts for sale
6speed_Sam is offline   Reply With Quote
The Following User Says Thank You to 6speed_Sam For This Useful Post:
AVodka14 (02-05-2014)
Old 02-04-2014, 08:36 PM   #35
schmearcampain
Drives: 2014 Argento FRS 6MT
Originally Posted by TM View Post
I always downshift to 3rd when taking turns.
3rd? why not 2nd? or how fast are you taking your turns? I'm at 15 mph or so.
schmearcampain is offline   Reply With Quote
Old 02-04-2014, 08:47 PM   #36
chadwick86
Drives: Hot Lava FRS
As someone who drives a 5-speed manual as a DD.. When I get in the FRS and have 6 gears, it's extremely refreshing.
There are often times when I feel like 2nd-3rd in the 5 speed has to be stretched more than I would like, or I find myself downshifting at weird times every once in awhile (in moderate traffic).
The 6 speed is great, and 3rd is like the perfect cruise gear at slow speeds.
chadwick86 is offline   Reply With Quote
Old 02-04-2014, 08:50 PM   #37
strat61caster
strat61caster's Avatar
Honda has publicly instructed owners to not skip gears, many believe this is due to the S2000 on which some owners had problems with the synchros wearing quickly (I believe there was even a note in the owners manual at some point, but I can't back that up). The idea is that you're asking the synchro to do more work instead of matching the revolution difference between say 2-3 you're asking it to go 2-4, more wear and tear on the part.
http://www.mediafire.com/view/yegnjd...nuary+2006.pdf
Funny enough this forum post from 3 years ago brings up all the points discussed so far and has a copy pasted text from the bulletin I linked if you don't trust it:
http://www.standardshift.com/forum/v...hp?f=6&t=13489
Bottom line is that it's up to you how to drive your car, some people will take the time to row the gears, others won't. Sure transmissions designed to skip gears (especially autos where the feature is built-in) won't have a problem, but apparently some trannies do have problems.
ineedyourdiddly
Braces (02-05-2014)
Old 02-04-2014, 08:59 PM   #38
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
Honda has publicly instructed owners to not skip gears, many believe this is due to the S2000 on which some owners had problems with the synchros wearing quickly The idea is that you're asking the synchro to do more work instead of matching the revolution difference between say 2-3 you're asking it to go 2-4, more wear and tear on the part.
It makes sense.. Not sure I'll go by what the article says, but I'll definitely have that on my mind every time I skip a gear.. lol
I don't skip gears often.
Old 02-04-2014, 09:17 PM   #39
jonboy99
jonboy99's Avatar
Drives: Black Panda BRZ
Originally Posted by NOHOME View Post
First car with a 6 speed box, and after a year and a half I have to say that the idea is kinda silly.
Are you sure this isn't your first car with a manual box?
I take all my turns at 80mph so third is perfect.
jonboy99 is offline   Reply With Quote
Old 02-05-2014, 03:23 AM   #40
TM
TM's Avatar
Drives: DGM BRZ 6MT
Around 18mph is the lowest I would shift into 3rd. I take my turns around 18-22mph. Up to around 26mph if the roads are completely dry.
You're in LA, though. The roads here are a lot wider here with less traffic. Whenever I 'm back in NYC, I take my turns in 1st or 2nd gear.
TM is offline   Reply With Quote
Old 02-05-2014, 06:06 AM   #41
Hanni_0176
Hanni_0176's Avatar
Drives: 2013 Scion FR-S 10 Series MT
Hey OP, this might help...
Mods: K&N Air Filter - Open Flash Tablet (Stage 1 v1.55) - more to come!
Hanni_0176 is offline   Reply With Quote
The Following User Says Thank You to Hanni_0176 For This Useful Post:
schmearcampain (02-06-2014)
Old 02-05-2014, 06:55 AM   #42
Vincenttam
WtsTofu
Vincenttam's Avatar
Drives: Ultramarine fr-s
I think second gear is pretty useless. Not completely useless but i usually find myself going from 1 to 3 almost instantly. 3 can take on 2 almost as well. fist gear to 3.5 rpm than straight to 3 lol. Plus third gear is so easy to get into, why take it away?? haha
Vincenttam is offline   Reply With Quote
Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode SteveH Other Vehicles & General Automotive Discussions 7 02-13-2013 01:08 AM
Reverse Gear not going into gear? MT joergasm Issues | Warranty | Recalls / TSB 22 11-29-2012 01:08 AM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 09:39 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 08:44 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 52 01-29-2012 02:21 PM
