#29 |
Troll Hunter
Drives: fr-s, tundra
Man, that is never a fun experience to have right when you get your car. Hope you have another car to drive around in meanwhile, and that the engine swap goes smoothly..
#30 |
Drives: 2017 86
This is why I buy new sports cars, but in the end I normally void the warranty doing things to it myself. I can handle when shit goes wrong and it's my fault. I am sorry you have to deal with someone else's fuck up. On the other hand, I would get all that good stuff in writing to make sure they aren't trying to schmooze you, my friend. Good luck. Keep updating!
#31 | |
Drives: 2015 Mustang GT (on order)
#32 |
Drives: white Sport-tech
That's awesome paid for a used car and now you get a brand new engine!
Sucks it had to happen this way but the end result should mean 1,000's is miles of problem free fun, at no more cost to you. |
#33 |
trevorovert - I do have old betsy to drive in the meanwhile at least
. I talked with a few friends that work at this dealership and they had nothing but good to say about the tech that will be doing the engine swap, everyone else outside the dealer I've talked with gave me the same name as the go to guy at this dealership so that makes me feel better.Darkrune - defiantly going to get all this in writing to ensure that. I would love to buy new one day but I'm too cheap and saving $7000+ over a new one for some miles makes sense to me, always has . I usually don't have this kind of a headache on my hands lol.jeebus - I agree. I believe the biggest thing was the front end collision history coupled with the incorrect coolant factoring heat on the motor and premature wear more than the oil and filter. Muskokan - yep I can't complain anymore on that point. Also to help the situation since the engine isn't falling under warranty replacement I get to keep the engine block coming out of the car along with anything not used for spare parts . So new engine going in has remaining powertrain warranty and I get the old engine and parts to keep!
#34 |
Wow can't believe it's been right at 1YR since this originally all happened. I'm happy to report my second engine that came 100 miles on it is still going strong almost 16,000 miles later including 3-4 auto-crosses and a couple of track weekends in Memphis, TN at MIR.
Considering I got to keep my original engine I feel everything worked out for the best though this is not the ideal situation, I've kept up on the forum and have noticed multiple other FR-S's and BRZ's having "rod 4 bearing failure" which honestly seems like a production issue. I noted to others that my car originally had a history of engine "issues" and visits from Toyota engineers / service techs specifically to look over said engine issues throughout the early life of the car. Car was always serviced at the purchasing dealer along with normal oil changes, etc. which still lead to a pre-mature failure of the rod 4 bearing. For others that didn't have the situation I did Toyota needs to make these things right and take care of the customers, mine had full oil and has always been checked along with the maintenance and service schedule. Toyota is just trying to find a way to shift blame and not have a recall or "attention" situation on hand. I also wanted to note to everyone check your engine front covers, the oil pump housing that's stamped. My original engine with all the issues and ultimate failure as others was stamped with "#1" and a eagle / bird on the engine. My current engine that's been issue free these last 16,000 miles so far has a "#2" with no eagle /bird stamped on that same front cover. Revision possibly? Possibly from reviewing engine issues and cases early in release after the initial cars starting rolling off lots? Not sure. All my friends in my local Auto-x and track groups that have these cars got later 13 / early 14 models and all noted they have the "#2" stamp on their front engine cover, food for thought. Hopefully some of this information is helpful to others out there .
| The Following 6 Users Say Thank You to TheMarkness For This Useful Post: | enouf (02-04-2015), PWBRZ (02-05-2015), Sportsguy83 (02-04-2015), strat61caster (02-04-2015), Tcoat (02-04-2015), zc06_kisstherain (02-04-2015) |
#36 | |
With the "all these engines are blowing up" hysteria you are the first to actually come up with a possible method of actually anticipating an issue and even if your theory is wrong at least you puts some facts on the table. The actual number of failures is really a very small percentage and you may very well have identified the run that is at issue.
#37 |
Drives: FR-S,GTI
Oh NO
I just checked and I have a 1 and a bird on my engine cover. It's a 2013. |
#38 |
Drives: 2013 Raven Fr-s, 2013 Versa Sedan
60k mile Powertrain Warranty.
| The Following User Says Thank You to samisons For This Useful Post: | Tcoat (02-04-2015) |
#39 |
Drives: 10 Series FR-S
#41 |
Drives: BRZ DGM Limited
#42 |
Drives: Scion Frs 2014 Asphalt
Take it to the dealer. Good luck
| Knocking sound | Moe23 | Issues | Warranty | Recalls / TSB | 80 | 04-18-2019 09:09 PM |
| Knocking sound from what sounds like rear suspension | husker741 | Issues | Warranty | Recalls / TSB | 12 | 04-24-2017 06:26 AM |
| Knocking on Startup? | 636 | Issues | Warranty | Recalls / TSB | 17 | 02-03-2014 08:18 AM |
| Knocking/Rattle on start up. | jimbobrand | Issues | Warranty | Recalls / TSB | 18 | 01-13-2014 12:34 PM |
| Bubbling/knocking (but not liquid) sound aside from chirping | mike_ekim1024 | Issues | Warranty | Recalls / TSB | 22 | 05-05-2013 04:20 PM |
