86WORX
Old 02-01-2014, 04:03 PM   #29
1086
1086's Avatar
Drives: UM86 - 6MT
I gotcha ok ok
1086 is offline   Reply With Quote
Old 02-01-2014, 04:04 PM   #30
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by 8686 View Post
Dear @shiv@vishnu
thank you for updating the 700K files. But I noticed that you name it as MT while it is for AT. Does that make any diffrence in the tune or is it just a name mistake.
Thank you again
Yep.. I just labeled the folder incorrectly. It is indeed for a 6AT
Old 02-01-2014, 04:06 PM   #31
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by no chrome View Post
i assume we should also NOT allow romraider to correct checksum after we edit while saving the .bin?
does not match because the bin we are using is actually based on the newer (DI seals) rom?
It doesn't matter if RomRaider does or doesn't correct the checksum because it will corrected by OpenFlash Manager when the file is uploaded. The checksum doesn't match because the files were patched together externally using a hex editor instead of being modified and saved in RomRaider (so their checksum fix wasn't applied).
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
no chrome (02-02-2014)
Old 02-01-2014, 04:07 PM   #32
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by jeebus View Post
my point is I'm asking if he has release notes?
To see actual mapping changes use the compare function in RomRaider to show the list of maps that were modified. Then just compare the tables instead of each individual hex address which can be a bit overwhelming.
Old 02-01-2014, 04:48 PM   #33
jeebus
Drives: 2015 Mustang GT (on order)
yeah that's what I did. There's a lot of differences in how you approached things. I guess I'll just have to flash and see how it feels.
jeebus is offline   Reply With Quote
Old 02-01-2014, 04:57 PM   #34
jflogerzi
jflogerzi's Avatar
No complaints here. You will like it
Old 02-01-2014, 05:46 PM   #35
jeebus
holy crap, 1.55b feels amazing! Even right off idle the car feels better (from that additional 20 degrees of VVT exhaust?)
3rd gear pull below:
http://www.datazap.me/u/jeebus/3rd-g...g=0&data=1-7-9
Old 02-01-2014, 06:17 PM   #36
PMok
Codename: Stitch
PMok's Avatar
hey Shiv, I have the ZA1J900C ROM. when I flashed to Stage 1 (both v1.42 and v1.55b), afterwards the OFT info screen now indicates I have ZA1JA01C Calibration ID instead of the 900C. Is that normal? I think others who reflashed did not notice a change in Cal ID. @shiv@vishnu
Also, I was running 1.42 for a while and my Adv. Multiplier had dropped down to 0.52. Discussed with others in a different thread and they think the tune was too aggressive for the lousy 91 CA gas here. Thoughts on how well the 1.55b will address this? So far I have only been driving 1.55b for a few trips though and the Adv. Multiplier has dropped from 1.00 down to 0.78 now. Will keep an eye on things in the days to come.
Old 02-01-2014, 06:26 PM   #37
Shiv@Openflash
Drives: 2013 FRS
Yes, you CAL ID will often change to A01 type regardless of what you started off with. This is normal and intentional.
And after you first flash your ECU, don't be surprised if you see some Adv Mult gymnastics on 91oct. Give it time and it will settle down. Usually a bit higher than the lowest value you saw during the initial learning process. This is completely understandable with CA 91oct fuel. And nothing to worry about. The only time I would take action on 91oct is if it dropped to 0-0.25 and just stayed there. That would suggest loading a less aggressive map would be in order. In CA, we are cursed with low octane fuel. But there are enough safety systems in place (in the ECU code) that keep things where they should be.
Cheers
shiv
PMok (02-01-2014)
Old 02-01-2014, 06:38 PM   #38
jeebus
Cheers
shiv
really? you aren't concerned until it's sitting down at .25? Hmmmm....I guess I'm just more conservative than that.
Old 02-01-2014, 06:39 PM   #39
Shiv@Openflash
Drives: 2013 FRS
It's ok to be conservative. But it's more important to understand what you are being conservative about. In this case, all the ECU is doing is scaling down your knock correction table so that you don't get as much proactive ignition advance.
jeebus (02-01-2014)
Old 02-01-2014, 06:44 PM   #40
jeebus
you would know much better than I. I guess I just like to see my logs filled with rainbows and unicorns.
The Following 2 Users Say Thank You to jeebus For This Useful Post:
PMok (02-01-2014), Vmax911 (02-01-2014)
Old 02-01-2014, 11:29 PM   #41
Burn
Slack Bum
Burn's Avatar
Hi @shiv,
I'm able to flash 1.55B bin file to my car but not from the mod database, is it still older roms are still unsupported from MOD DB ?
Burn is offline   Reply With Quote
Old 02-01-2014, 11:41 PM   #42
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by Burn View Post
Hi @shiv,
Yes that is correct.
Burn (02-02-2014)
Search this Thread:
Advanced Search
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
FS: Openflash Tablet Sgt.Beardface Engine, Exhaust, Bolt-Ons 8 01-04-2014 12:12 PM
FS: Openflash tablet nguyen_er Engine, Exhaust, Bolt-Ons 6 12-30-2013 01:31 PM
new OpenFlash tablet autobrz Engine, Exhaust, Bolt-Ons 5 12-23-2013 10:05 AM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 01:10 AM
