#15 |
Drives: WRB BRZ, Monte Carlo SS
nevermind the throttle was at 0.00 so i am assumming the afr is perfectly ok for a universal base map. I wonder if a remote tune from shiv would make much difference.
#16 |
I think most OTS maps are made rich to be on the safe side...a custom tune would most likely just lean it out a bit in places to get more power. Just my guess.
Ultramarine 2013 Scion FR-S 6MT
#17 |
Drives: World Rally Blue BRZ
I would not be worrying about any tune, if my car was leaking/burning coolant. Tunes don't work on engines that went KABOOM.
#18 |
#19 |
Drives: 2013 Asphalt FRS
Obv already has been brought up a million times.
2013 Sion FRS
2014 Subaru WRX 2014 Subaru XV |
| The Following User Says Thank You to NickFRS For This Useful Post: | CaptainSlow (01-31-2014) |
#20 |
So you're really short or do the "laid back" driving style and your foot kept slipping off the throttle?
#21 |
#22 | |
Senior Member/Old Fanboi
Drives: 2000 2ZZ-GE MR2 Spyder HT
You do not even need to buy one. Most the parts stores will rent one to you. You can pressure check the system in a matter of a few minutes. Bear in mind that if the leak is internal then you will not see or hear the leak. In that case, it could be a head gasket, cracked head or cracked block. Some engines have water passages in the intake manifold or plenum with o rings or gaskets to seal them but I do not think the FA20 does. Good luck, I hope it does not turn out to be too serious and whatever it is is covered by the warranty.
So many modders have more cents than sense!
#23 |
Drives: 13' Subaru BRZ Limited SWP 6MT
Did you take it to the dealer with an aftermarket tune loaded?
#24 |
I did but that is because i forgot to remove it. They didn't say anything. Everything came back OK and they added some coolant, changed the tailight gaskets, and did a underside repair in the trunk for rattling but now i hear this ticking sound so i will take it back and ask them to repair the topside.
| Tags |
| antifreeze, coolant, openflash, openflash tablet |
| Any News on 2014 FRS? | hmong337 | Scion FR-S / Toyota 86 GT86 General Forum | 63 | 01-02-2014 04:49 AM |
| Where do you get your car news? | natehan | Off-Topic Lounge [WARNING: NO POLITICS] | 17 | 12-10-2013 04:35 AM |
| Sad Sad news for me | Omoi | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 06-02-2012 12:00 AM |
| Bad news from dealer | BMWDavid | BRZ First-Gen (2012+) -- General Topics | 116 | 03-01-2012 12:15 AM |
| News Onslaught | Guff | Off-Topic Lounge [WARNING: NO POLITICS] | 9 | 11-29-2011 05:11 PM |
