Old 01-30-2014, 05:38 PM   #1
hmkk
Noob drop in filter question
I've swapped my OEM intake for the Injen and thought I would go back to the OEM with a drop in filter, been looking at different posts and most I've seen talked about was the HKS, aFe, K&N filters. My question is, which ones require 'oil' for the filter? and which one would I be better off with in terms of long lasting and least required maintenance (cleaning, replacing etc)? I've seen pros and cons about most of them including the HKS having problems trapping dust in the filter and allowing accumulation of particles near the MAF. Not sure if this is always the case but just wanted to know what you guys think.
Thanks in advance.
hmkk is offline   Reply With Quote
Old 01-30-2014, 06:16 PM   #2
jflogerzi
jflogerzi's Avatar
stick with the dry ones if you going back to stock airbox. I run the TRD air filter.
Old 01-30-2014, 06:22 PM   #3
humfrz
K&N is an oiled filter. So far, my car's engine hasn't rejected it ...
raul (01-30-2014)
Old 01-30-2014, 06:32 PM   #4
hmkk
Any specific recommendations on dry filters? Thought the TRD air filter only fits the TRD intake since its elongated?
Old 01-30-2014, 06:34 PM   #5
jflogerzi
jflogerzi's Avatar
http://ft86speedfactory.com/trd-perf...lter-1007.html
Old 02-01-2014, 10:00 AM   #6
tyler_win_photo
tyler_win_photo's Avatar
The TRD one is basically a K&N, but with a red trim around it. TRD fits in the stock air box. You shouldn't have to worry too much about an oiled filter messing up your maf, unless you really go overboard while re-oiling during your cleaning process it. Most the time you'd at most have to clean your filter once per year, though that's being very generous with it. My friend has run an HKS for 20k miles, no issues at all.
tyler_win_photo is offline   Reply With Quote
Noob question dro Scion FR-S / Toyota 86 GT86 General Forum 60 07-05-2013 10:33 AM
Noob Air Filter Question GhostofAkina Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 24 03-09-2013 10:47 PM
noob question ft86me Engine, Exhaust, Transmission 13 02-28-2013 05:53 AM
Trd drop in filter question bdanisi Engine, Exhaust, Transmission 2 02-12-2013 09:48 PM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 03:40 PM
