86WORX
Old 12-01-2012, 10:29 AM   #211
yomchi1989
n00b
Drives: Pfft... go by Kangaroo! STRAYA!
Originally Posted by stevo_12v View Post
I must be getting better at this. Took me 40mins to unbolt the crosspipe, take out the cradle brace, swap over the Perrin/Cusco shifter components, reinstall all parts back to correct torque settings.
CUSCO flat washer and PERRIN 'stiffy' part.
For anyone curious... The diameter of the CUSCO washer is about 1mm wider than the PERRIN. Or in other words, the diameter of the PERRIN shaft is 1mm LESS THAN the outer diameter of the CUSCO barrel part.
OEM shifter(with cusco part still on it) part on top of the, PERRIN 'stiffy' T part.
Lengthways view
CUSCO 'barrel' on top of the PERRIN 'stiffy'. The cusco is about 1-1.5mm wider than the shaft of the PERRIN.
PERRIN 'stiffy' T Part sitting in the rubber mount. This part sat much more snug than the OEM T part with CUSCO part.
The CUSCO/PERRIN hybrid installed. I noticed this felt very TIGHT. Eager to see how this setup goes compared to the WL KDT926 and the CUSCO shift kit.
Made a tiny start to the HKS Spec-L exhaust install...
How did you go with the hybrid?
yomchi1989 is offline   Reply With Quote
Old 12-01-2012, 05:49 PM   #212
stevo_12v
stevo_12v's Avatar
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
I just gotta say.. the CUSCO/PERRIN hybrid... works.. and works DAMN well.
Maybe it might have been the HKS exhaust overpowering it.. but it definitely felt much better. Kinda like stock, but firmer and less noise.
Also, I forgot to torque down one of the 45deg angled nuts(with washer) on the cradle brace.. now I gotta order that washer(I'll prob get the pair to be safe) again.. and then jack the car up.. yet again :/
Oh well.. Lesson learn.. triple check your torque settings. Also.. the HKS exhaust is EXCELLENT. It's 5:46am and I haven't gone to bed yet. Work at midday, I'll write up and post some pics later.
[CENTER]
Build thread
stevo_12v is offline   Reply With Quote
Old 12-01-2012, 05:51 PM   #213
Hawk77FT
Drives: GTS 86
Looking forward to your feedback on the hybrid mate. Do you know the diameter of the insulator by any chance as I want to combine whiteline with the perrin bushing?
Sent from my HTC One X using Tapatalk 2
Hawk77FT is offline   Reply With Quote
Old 12-02-2012, 12:43 AM   #214
stevo_12v
stevo_12v's Avatar
You mean the shaft part of the Perrin? That shaft isn't an insulator, its a metallic piece. But if you are using it with the Whiteline KDT926, it should fit. The hole in the KDT926 is pretty big. Probably about 3mm wider either way of the PERRIN 'stiffy' shaft diameter.
[CENTER]
Build thread
Old 12-02-2012, 12:56 AM   #215
stevo_12v
stevo_12v's Avatar
HKS Spec-L Installed..
Got home 2:00am and started the changeover for the exhaust. The hardest part to this install is actually removing the muffler off the hangars. You need to shove a slotted screwdriver in between the hangar and slowly slide/pry it out. Use lots of WD40 too.
Stock exhaust removed..
Mid pipe install was a bit tricky when doing it with one person. Another set of hands would be good. I made do with a big bucket to hold/level off the other end while I bolted up the front part of this pipe. The I installed the single grommet holding the rear end.
Left Muffler..
Left Muffler installed..
As you can see from this pic, part of the exhaust almost crosses in front of the diff. So you might need a lower profile jack when you lower the car(or put the rear tyres on a piece of wood/brake rotors).
View of Left Muffler..
Right Muffler..
Right Muffler installed.
[CENTER]
Build thread
The Following User Says Thank You to stevo_12v For This Useful Post:
Guff (12-02-2012)
Old 12-02-2012, 05:00 AM   #216
stevo_12v
stevo_12v's Avatar
Forgot to tighten up the two nuts(in green) and washer. Gotta get some new ones.
Edit: Part Numbers
[CENTER]
Build thread
yomchi1989 (12-02-2012)
Old 12-03-2012, 11:17 AM   #217
stevo_12v
stevo_12v's Avatar
Haters.. LOL
Oh man.. this post made my night. Couldn't stop smiling.
His car..
[CENTER]
Build thread
The Following 3 Users Say Thank You to stevo_12v For This Useful Post:
Chojin9 (01-18-2013), GaN-MaN (12-03-2012), ML (12-03-2012)
Old 12-03-2012, 11:41 AM   #218
ML
ML's Avatar
Drives: 13 White MT FR-S
simulated fun =/= real fun?
Old 12-04-2012, 08:00 AM   #219
stevo_12v
stevo_12v's Avatar
Fast n Furious Parking at my work..
Well.. the boys rocked up in convoy to install yet MORE parts to the TOYOTA
Brian O'Connor.. in this R34 G-TR
Johnny Tran.. in his Civic Type-R
Jessie.. in his VW Scirocco R
Your's Truely..Vin Diesel(ahem).. in this yet-to-be-modified-always-build-in-progress Toyota 86
Group shot of the.. Fast-n-Furious crew
[CENTER]
Build thread
Old 12-04-2012, 08:14 AM   #220
stevo_12v
stevo_12v's Avatar
Bargain Bin @ Covs Parts Myaree :D
Since I lost my washers underneath the cradle brace under the shifter. I decided to head off to COVS parts in Myaree to buy some washers. Didn't really want to go into a big-box hardware store like Bunnings as I can't keep an eye on my baby..
While there I saw what was in their 'Bargain Bin'..
I asked how much they were and he said $7 for the 1/4in socket set, and $4.50 for the 1/4 socket handle. He said $10.60 all up for me including the washers.
These will come in very handy when removing the Aero panels underneath the car. Also I can store them in my hard pencil case with the other tools
It's funny, sometimes its the little bargains that make your day.
[CENTER]
Build thread
Old 12-04-2012, 08:20 AM   #221
trinitron
Drives: gts 86
Great looking car!
Where would you recommend buying the trd kit? You seemed to have a few problems with your purchase being shipped on time?
Does the modellista and trd kit flow nicely together in real life? Looks great in pictures. Great taste.
trinitron is offline   Reply With Quote
Old 12-04-2012, 09:10 AM   #222
stevo_12v
stevo_12v's Avatar
Modellista flows with TRD..
Originally Posted by trinitron View Post
Great looking car!
I got my kit from Import Monster. I was hoping they would have sent it as soon as they had received it on their end. As I was already waiting over 6 weeks at that point in time.
They had even asked me what my SHIPPING address was so they could calculate freight.. I was a bit pissed off in that regard because:
1) I stated my address weeks before - so they can calculate the total amount.. and
2) I paid in FULL for both the product PLUS shipping.
So when he emailed me asking for shipping address PLUS payment, I was a little bit peeved. This added yet ANOTHER week to the delay.
The Modellista pods flow very nicely with the TRD Skirts. It's nice because you don't have to cut up the rear diffuser(if you want to go for TRD) - but if you go for the TRD back, you have to have dual exhausts to complete that 'look'.
I'm most probably looking to get rid of them though. After looking at this picture from a recent cruise..
I feel the back end doesn't look 'aggressive' enough. So I am looking for the Greddy RB diffuser.
It makes the rear end have a wider stance, and doesn't taper off vertically down the bottom like the Modellista pods do. Also, since I have my HKS Spec-L installed.. I've noticed that the extremity of the tip actually goes past the stock rear bumper(which is defectable here) so If I get the RB Diffuser my car will be legal.. that's my reasoning
The Greddy Rocket Bunny diffuser adds another 60mm to the back of the bumper apparently.
I'll probably be hitting up @BPAuto if they have the diffuser ready NOW to ship. I got quoted $955 shipped to Perth, West Oz a month or two ago - and they had it in stock.
Hopefully they do. I like dealing with SUPER FAST vendors and I hate waiting.
EDIT: Hit up two vendors for parts, both have replied that they cannot sell the diffuser by itself
[CENTER]
Build thread
trinitron (12-06-2012)
Old 12-04-2012, 06:56 PM   #223
Hawk77FT
Drives: GTS 86
Oh ok, I want to do a hybrid between the KDT926 and the Perrin 'stiffy' so I hope it all goes well. Someone said that it might not fit properly as in I will have to make the KDT926 hole slightly bigger to accomodate the Perrin shaft. I will check tonight. If that is the case, than I will have to find the best possible way to make the hole larger. Any suggestions? I was thinking a very fine knife or hot hole puncher or something.
Old 12-04-2012, 10:35 PM   #224
KAOS86
Drives: Magna V6
Smile Cheap here...
Mate go to http://www.japanparts.com/ select subaru BRZ as the car.
Direct Link:
http://www.japanparts.com/db/parts_d...&SEARCH_page=4
Cost $505 and shipping said $87 to Perth!
I was looking at get this myself (Still waiting for my Car ) if you do get it can you please show lots of pics of how it's fitted together as it says something needs to be cut, but I think one could design a work around.
Good Luck!!
KAOS86 is offline   Reply With Quote
The Following User Says Thank You to KAOS86 For This Useful Post:
stevo_12v (12-05-2012)
36yroldvirginscar, keyboardwarrior, trd
Search this Thread:
Advanced Search
Dumb idea to get auto tranny? tinnyms3 BRZ First-Gen (2012+) -- General Topics 85 06-22-2012 06:22 PM
After this last winter is RWD such a bad idea Nate219BRZ Great Lakes 3 03-14-2012 06:03 PM
Any Idea of U.S. Pre-Order Numbers? markemark24 Scion FR-S / Toyota 86 GT86 General Forum 1 02-21-2012 01:29 PM
I have a great idea! ftw-86 Scion FR-S / Toyota 86 GT86 General Forum 56 07-24-2011 12:14 PM
Marketing Idea for the FT-86 JDMluv Scion FR-S / Toyota 86 GT86 General Forum 21 05-02-2011 06:29 AM
