| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
#85 |
The S2000 has a tilted I4, although not extremely so. It's CG height is around 18.7" I believe.
2022 BRZ Build 2013 FR-S Build |
#86 | |
Drives: (formerly) 2013 Raven FR-S
As for the 911 motor, I don't know. I don't know Porsches too well, but I used to own an LS3. |
| The Following User Says Thank You to malave7567 For This Useful Post: | Calum (02-04-2014) |
#87 | |
Drives: Whiteout FR-S MT
I stated a straight drop (not accounting for geometry or other factors *hence black magic), does not equate to better handling. You can't just cut your springs and say instant better handling is what I meant. The person I was responding to was talking about straight 1" - 2" drops that majority of people do mainly for looks, somehow equates to better handling. Obviously lower COG car will be better, but I would sacrifice some of that for a better engine. |
#88 | |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | AsianStyle (02-04-2014) |
#89 | |
See all of Porsche's racing success (continued to this day). Compare the ridiculously successful 917 (with a flat engine) in 1970: ![]() To the ridiculously successful Lotus 72 introduced the same year: ![]() The packaging is entirely different and is the inherent drawback to boxer engines. F1 designers didn't ditch boxers because they could get similar c.g. out of a V, there were a multitude of factors which were more easily solved on the V's. Edit: To be clear this is only a couple years after Ferrari tried a flat 12 in F1 (1965 Ferrari 1512), note the widest point of the car besides the tires: ![]() And I guarantee you can feel half an inch of c.g. movement, I know when I was racing I was adjusting suspension in increments of 1/8th of an inch per corner and I knew exactly what I was doing and why I was doing it. Agreed that the flat engine isn't the magic bullet for lower c.g. better handling, I'm just being a pedantic asshole on the internet. ![]() And I'll concede defeat on the emissions requirements, I don't care enough to work it out. |
| The Following User Says Thank You to strat61caster For This Useful Post: | Marchy (02-11-2014) |
#90 | |
Drives: '13 BRZ, '06 997, Other Things(TM)
#91 | |||||
Drives: '23 BRZ
![]() Considering how low the car sits, 18.7" isn't terribly impressive! But the car's handling is pretty much sublime (aside from AP1 rear toe shenanigans!). Quote:
Agree that aero and packaging were major considerations as well. Quote:
c.g. height is important, but I think that the FT86's is down to a LOT of attention to the design of the entire car and not just the flat engine. Judging from pics of how the engine is situated, it looks to me like the engine and trans had to be mounted quite high in order to have room for the exhaust for the flat engine. I would still bet that a 45-degree laid-over I4 or a 90degree V4 would be able to have the crank much lower, and could have a similar c.g. height. Vs. an upright inline-4, I'm betting 1/2" reduction in overall vehicle c.g. height. Which is certainly nothing to sneeze at. Last edited by ZDan; 02-10-2014 at 05:41 PM. |
#92 | |
Also that's an interesting diagram of the x-bone frame on the S2000. Never realized it sat that high!
#93 | |
I would absolutely take that bet.
#94 | |||
Drives: '23 BRZ
It's not valid to assume that a flat engine as mounted in a car is going to have a lower c.g. A widish-angle V has greater potential for having a lower c.g. height. Quote:
Possible to do, but not exactly practical (and it would take some doing to *ensure* that the driver can't tell which configuration from visual cues or from "tells" from the crew). You might do better than 50/50, but I doubt better than 65/35. Again, this is for a stock car, not a race car. |
| The Following User Says Thank You to ZDan For This Useful Post: | fatoni (02-11-2014) |
#95 | |
![]() FYI the Lotus 72 I posted utilized a 90 degree 2.5L V8. |
#96 |
i believe the cog thing is going to be clouded for a while since its impossible to look at the difference exclusive considering different cars are different. i think the bigger issue is that a v motor is built in a way that there is significantly less material and more strength. it kind of makes the cog debate less valuable when you think about it. i mean yeah, you might potentially be able to get a lower cog but if youre throwing another 100lbs into the equation, im sure a ballast bolted to the floor pan will lower the cog as well.
its also probably worth noting that many times, its not a theoretical perfection cars are built upon but a host of real life constraints. does that lotus use mac strust? defitely not ideal but if it allows you to fit more motor in a smaller car, there can be a feature that benefits the car more than the struts inhibit. |
| The Following User Says Thank You to fatoni For This Useful Post: | strat61caster (02-11-2014) |
| WANTED: Cylinder Heads | Zach3794 | Southern California | 1 | 11-18-2013 06:24 PM |
| cylinder numbering? | ElectronSpeed | Engine, Exhaust, Transmission | 2 | 02-05-2013 04:21 PM |
| BRZ/FR-S master cylinder brace - $60 | Turn in Concepts | Brakes, Suspension, Chassis | 35 | 01-26-2013 01:17 PM |
| Cylinder 4 ringland issues? | feldy | BRZ First-Gen (2012+) -- General Topics | 8 | 08-13-2012 12:57 PM |
| Will we ever see a 6 cylinder engine? | Bristecom | Engine, Exhaust, Transmission | 146 | 03-13-2012 08:37 PM |
