#43 |
Drives: Subaru BRZ Limited
They did much more than grease mine I believe. They had to take the whole transmission out to fix it apparently. I'd play it safe and just let them fix it for you. I don't think it's something you can just grease and be done with it. They had my car for over a week.
#44 | |
#45 | |
Boosted
Drives: Sideways
Thank you
| The Following User Says Thank You to Synack For This Useful Post: | Hawaiian (05-07-2014) |
#46 |
Super 86
Drives: Red 86 GTS
Don't know if it's the same, My clutch pedal is making a click at the begining of it's stroke. Sounds to be coming from the Clutch cylinder
230rwhp/184ftlb on 98RON/93AKI
Build thread Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can |
#47 |
Drives: 2013 FR-S MT Firestorm recd 5/31/12
Firestorm Red MT FR-S received 5/31/12 at 11 AM Novato Ca. Novato Scion, so long 1993 Lexus SC300 MT, you served me well for 18 years ![]() |
#48 |
#49 |
Drives: BMW 228i TPK , 13 BRZ (LemonLawed)
I had the same problem and they used grease, which fixed it for a little, but it came right back. They just recently replaced the clutch fork and that seemed to get rid of it—at least for now. I have heard of other people on the nasioc forum having the clutch fork replaced on their WRX and that seemed to fix the problem for them as well. I hope that helps.
#50 |
Drives: frs
Got the sqeakey noise with crunchy pedal feel during the last inch or two before clutch is fully depressed. Pretty disappointing for a 25k mile car considering I never hard launch and always sit in N at lights.
Assuming it needs more than a lube job what are my chances of getting the shift fork (or whatever needs to be) replaced under warranty with a rear tranny mount and whiteline insert? Edit: going in today so I'm about to find out Last edited by gonzo; 06-02-2014 at 04:44 PM. |
#51 |
Boosted
Drives: Sideways
We greased/lubed up the clutch fork and input shaft really well and all noises went away.
#52 | |
Drives: WRBrz
How'd it go?
EBSC - dt.FF - MXP CompRS
#53 |
Drives: frs
I went there asking them to lube the shift fork because of what I read on this forum. They made me wait 3 hours and said it's something "internal" so they can't just lube it. Said they'll contact toyota then get back to me. They called a few days later telling me that toyota doesn't know what's causing it yet so bring it in for a lubing (which they wouldn't do the first time I asked). Instead of taking it back I raised my clutch pedal so that it's now barely higher than the brake pedal. The noise went away and I haven't gone back to the dealer yet. |
#54 |
Drives: 2014 Subaru BRZ Aimgain GTF
Hi Folks, I picked up my brand new BRZ 10 days ago, and shifting from 1st to 2nd is a bit rough and there is a clanking noise. .....
From 3rd to fourth is very smooth and all other shifting is ok.... I just sent an e-mail to my sales guy to see what he recommends. In the meantime, what do you guys recommend?
#55 |
BOXER FR
Drives: WRB BRZ Limited
I had this sound:
[ame]http://youtu.be/Xu8cEgt6_eY[/ame] and got my throw-out bearing replaced. sound is completely gone and the crunchy feeling at the bottom of the clutch is also gone. get it taken care of while you have the warranty.
Build Thread of the "STI theme BRZ"http://www.ft86club.com/forums/showthread.php?t=61522
#56 | |
Drives: frs
Nevermind it's back -_- |
| Loud 'Squeak' Noise From Clutch? | Brndn704 | Issues | Warranty | Recalls / TSB | 23 | 07-20-2020 09:58 AM |
| Upgraded Clutch Squeak | Rybot | Issues | Warranty | Recalls / TSB | 116 | 10-09-2019 03:10 PM |
| Clutch pedal adjustment gone wrong? Clutch issues. | PulpBrah | Engine, Exhaust, Transmission | 12 | 03-06-2017 05:08 PM |
| Clutch Squeak | CatDaddysBBQ | Issues | Warranty | Recalls / TSB | 4 | 07-14-2015 07:44 AM |
| Clutch pedal squeak. | merino_frs | Engine, Exhaust, Transmission | 1 | 08-25-2014 02:00 AM |
