86WORX
Pat.Thornton
Old 06-30-2016, 08:17 AM   #421
ZZT86
ZZT86's Avatar
Drives: BR86
Was it poor grease or something else ? Is it common in cars generally ? A nice "How To" with tips would be awesome as I can see myself doing this but not every year :|
ZZT86 is offline   Reply With Quote
Old 06-30-2016, 11:30 AM   #422
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
TOB failure is a real thing but this creak/squeak has nothing to do with that. All the people that are having them replaced is because the plastic bushing in the center wears down enough to warrant replacement. Now that I've had the trans out I know I can drop it, clean the parts, and reinstall in an afternoon. I'll be doing this annually.
So I guess nothing to worry about for now.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 06-30-2016, 02:14 PM   #423
Ultramaroon
fabulous
Ultramaroon's Avatar
No, it's not common. In fact, it's unacceptable. This is not "wear and tear," it's the consequences of a poor decision. They picked a grease that wasn't up to the task.
If mine doesn't start squeaking again in a year, I'll still get in there to inspect at least once to see how my choice of lube holds up.
I did come up with a couple nice tricks for removing the transmission and I applaud Subaru for keeping serviceability in mind. Of all the drivelines I've done, this one is by far the easiest but it's still a transmission swap. I'm a big guy so my technique involves physically bench-pressing it into place.
ZZT86 (07-01-2016)
Old 06-30-2016, 02:16 PM   #424
Ultramaroon
fabulous
Nah. It's not the end of the world.
Old 06-30-2016, 07:29 PM   #425
bhbnuckle
bhbnuckle's Avatar
Drives: 2013 Asphalt FR-S/2003 Honda Accord
Hey guys. Im planning to put somr lubrication in clutch fork inside tranny.
Slave xylinder need to be removed in order to spray inside pivot point?
Sent from my Nexus 5X using Tapatalk
bhbnuckle is offline   Reply With Quote
Old 07-01-2016, 12:04 AM   #426
Tt3Sheppard
I kind of wonder if the lithium grease I used cleaned up the grit/tar like lube that you pictured. I know it has some dirt cleaning/grabbing properties.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
Old 07-01-2016, 03:00 AM   #427
Ultramaroon
fabulous
Nah, just added to the mess. It all cleans up ok.
Old 07-01-2016, 11:54 AM   #428
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
So since the creak doesn't annoy me too much (yet) would a good idea be to let it go until I get closer to the end of the powertrain warranty, so that I can wait and see if I have throwout bearing issues too, and THEN bring it in and just hopefully have a bunch of stuff replaced in one fell swoop? I only have 32,000 miles at the moment so I've got another year-and-a-half or so before I approach the 60,000 mile mark. I HATE having people work on my car, so the less times I bring it in, the better, lol.
Stang70Fastback is offline   Reply With Quote
Old 07-01-2016, 12:16 PM   #429
Readytoxplod
Tire Destroyer
Drives: Firestorm+snail
My squeak returned damnit. All dealership did was spray lube in there rather than replacing anything.
322whp/273wtq
Readytoxplod is offline   Reply With Quote
Old 07-01-2016, 01:29 PM   #430
Ultramaroon
fabulous
I think the only real concern is if the TOB starts to bind on the snout. That's the crunchiness people feel at the bottom of the throw. At that point it's possible to break the clutch fork.
Old 07-01-2016, 01:32 PM   #431
Ultramaroon
fabulous
"Nah" two posts in a row does not read well. Nah nah nah nah...
Old 07-01-2016, 01:34 PM   #432
Stang70Fastback
A.K.A. Starlord
Hmm. The "crunch" I'm feeling is just a lack of perfectly smooth pedal travel that aligns itself with each individual creak. Do you thin that's the TOB binding on something, or just the lack of lubrication causing the fork to slide a bit unevenly. I would assume the latter. The "crunch" doesn't occur when I first start the car, as there is also no creaking noise until it is warmed up.
Old 07-01-2016, 01:58 PM   #433
Ultramaroon
fabulous
Remember that the whole arrangement is a huge force multiplier. We haven't seen a rash of broken forks so I'll guess that it's not a problem. The inside diameter of the TOB is some sort of high-density polymer so it would really have to be out of whack before it jammed hard.
What used to be grease is really sticky; more like rosin now. There is definitely some binding. I guess just keep that in mind and be careful if it seems to get worse.
Stang70Fastback (07-01-2016)
Old 07-01-2016, 02:33 PM   #434
Stang70Fastback
A.K.A. Starlord
Yeah, I think I'll let it go for now. It isn't causing any drive-ability issues, and the creak isn't that bad. Since this seems to be a common issue, I'd rather let it go as long as possibly before replacing it so that I don't have to deal with fixing it out of warranty as soon. (Though being halfway through my power-train warranty, maybe it makes sense to get it fixed now on the premise that I can get it fixed again right at the 60k mark, lol.
Search this Thread:
Advanced Search
Loud 'Squeak' Noise From Clutch? Brndn704 Issues | Warranty | Recalls / TSB 23 07-20-2020 09:58 AM
Upgraded Clutch Squeak Rybot Issues | Warranty | Recalls / TSB 116 10-09-2019 03:10 PM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 05:08 PM
Clutch Squeak CatDaddysBBQ Issues | Warranty | Recalls / TSB 4 07-14-2015 07:44 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 02:00 AM
