#351 |
Drives: Whiteout FR-S
There must be some water or moisture getting underneath the boot where the clutch fork meets the slave cylinder. Every time it rains for a long period of time the clutch will squeak louder.
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
#352 | |
Waited 5 years for this
Drives: '18 MX-5 Club
#353 |
Drives: 2014 WRB BRZ
notice mine gets worse as i drive for longer periods of time. i sometimes get scared pressing my clutch in driving home from work now ):
#354 |
Drives: 2022 Subaru BRZ
Maybe this Technical service bulletin from Subaru will help.
12-190-15R, Oct. 30, 2015, "Elimination of Creaking Sound from Clutch Pedal Assembly." "This BRZ bulletin provides a procedure to address customer concerns of a creaking sound heard when operating the clutch pedal. The cause of the sound has been identified as a very slight amount of movement between the 2 layers of metal (circled in yellow) which form the specific clutch and brake pedal assembly mounting bracket shown in the illustration and photos." |
| The Following User Says Thank You to track junkie For This Useful Post: | bhbnuckle (06-29-2016) |
#355 |
Boosted
Drives: Sideways
Sooooo spray some lithium grease on the clutch fork and call it a day?
#356 | ||
| The Following User Says Thank You to Sigh-on-Rice For This Useful Post: | Ultramaroon (12-02-2015) |
#357 | |
| The Following User Says Thank You to Sigh-on-Rice For This Useful Post: | ZZT86 (12-02-2015) |
#358 |
fabulous
That one isn't the creak. It's a clicking sound. I have it. DGAF because I recognize it. A friend had it. We both laugh now because after giving him a hard time about sweating it, I helped him re-seat his bracket.
It worked for a week or so.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | Sigh-on-Rice (12-02-2015), ZZT86 (12-02-2015) |
#359 | |
fabulous
ConocoPhillips Multiplex Red #2 is an equivalent. Focus on Lithium complex, extreme pressure, high temperature, high tack. There are plenty of similar products out there.
#360 |
Drives: 2014 Firestorm Scion FR-S
Bought mine pre-owned in October, just started squeaking last week. Here we go. At least I work at a Toyota Dealership.
#361 | |
Drives: BR86
#362 | |
fabulous
#363 |
Drives: 2013 FRS
Subbed
#364 |
I'm starting to think that the spring, master cylinder push rod, or the master cylinder piston assembly is what is causing the squeak noise. I've searched other cars online that have this noise while the car is off and on. The clutch squeak noise in those videos sounds identical to my problem and I'm sure many others here as well. I will try and get some videos tomorrow if the squeak decides to be loud tomorrow. I have also upgraded my clutch slave and that did not fix the problem.
[ame="https://www.youtube.com/watch?v=UmMCdWJczIA"]2009 WRX Squeaking Clutch - YouTube[/ame] [ame="https://www.youtube.com/watch?v=WJ8v9ajrf9I"]Worst 350z Clutch Pedal Squeak/Creak - YouTube[/ame]
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 Last edited by Tt3Sheppard; 12-11-2015 at 10:11 PM. |
| The Following User Says Thank You to Tt3Sheppard For This Useful Post: | radroach (12-12-2015) |
| Loud 'Squeak' Noise From Clutch? | Brndn704 | Issues | Warranty | Recalls / TSB | 23 | 07-20-2020 09:58 AM |
| Upgraded Clutch Squeak | Rybot | Issues | Warranty | Recalls / TSB | 116 | 10-09-2019 03:10 PM |
| Clutch pedal adjustment gone wrong? Clutch issues. | PulpBrah | Engine, Exhaust, Transmission | 12 | 03-06-2017 05:08 PM |
| Clutch Squeak | CatDaddysBBQ | Issues | Warranty | Recalls / TSB | 4 | 07-14-2015 07:44 AM |
| Clutch pedal squeak. | merino_frs | Engine, Exhaust, Transmission | 1 | 08-25-2014 02:00 AM |
