Pat.Thornton
Old 11-08-2015, 05:44 PM   #337
BRZ_F
BRZ_F's Avatar
Drives: 2013 WRB BRZ
Clutch peddle loud squeak
Hey all. I started hearing a creaking sound when I would press down on the clutch specially after the car was warm. The noise was coming from the transmission housing so I took it in to Subaru and they are replacing my clutch right now under warranty. It's a 13 BRZ.
So if anyone is having this problem and you are still under warranty, go ahead and take it in for a new clutch!
BRZ_F is offline   Reply With Quote
Old 11-08-2015, 10:12 PM   #338
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
I'm starting to have this issue again as well. I made a warranty claim a long time ago when I had this issue. Subaru ended up replacing some bearing. The issue was fixed for over a year until recently when it started squeaking again. I'm out of warranty now.
ericmpena is offline   Reply With Quote
Old 11-09-2015, 01:40 AM   #339
zonda
Drives: 2014 WRB BRZ
Hey i was wondering which dealership you took it to? I live in Culver city and would like to go to a dealership that wont give me an issue with this problem.
zonda is offline   Reply With Quote
Old 11-09-2015, 10:48 AM   #340
BRZ_F
BRZ_F's Avatar
I took it into Subaru Pacific in Torrance. As long as you haven't done any modifications that would void your warranty it will be covered. I'm also having my tail lights swapped out under warranty for the water leakage issue. They should give you a loner as well while your car is there.
The Following User Says Thank You to BRZ_F For This Useful Post:
zonda (11-09-2015)
Old 11-09-2015, 12:45 PM   #341
zonda
awesome. scheduled an appt at 8am for saturday. hopefully itll be a smooth process. i used to live right across the street from subaru pacific and the service center always seemed packed.
Old 11-09-2015, 01:25 PM   #342
BRZ_F
BRZ_F's Avatar
It should be. They are busy so your car will most likely have to stay the a few days. Request a loner and they'll find one for you. I'm hoping to pick up my car in the next few days to try out the new clutch.
Old 11-09-2015, 01:38 PM   #343
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
I have this, as does every manual BRZ I've ever driven (+30 different cars). Not sure what the cause is, but it seems like this affects every car sold with a manual, and the only people reporting they don't have this issue are people who haven't heard it before and don't know what they're listening for.
xxBrun0xx is offline   Reply With Quote
Old 11-10-2015, 07:19 PM   #344
frs_firestorm
Drives: 2013 FRS
is this covered under basic or powertrain warranty?
frs_firestorm is offline   Reply With Quote
Old 11-11-2015, 05:25 PM   #345
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
i`m in the exact same boat. guess it`s time to sell the car when it needs another replacement...
mokinbird87 is offline   Reply With Quote
Old 11-11-2015, 05:26 PM   #346
mokinbird87
BOXER FR
Originally Posted by Tt3Sheppard View Post
Has anyone tried using Lithium grease on the clutch rod that is above the gas pedal that goes into the firewall. I can't remember if this had some grease on it when I purchased the car.
This location ^
i sprayed WD40 but no luck.
Old 11-11-2015, 05:31 PM   #347
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
36 36 warranty b2b
Mine is at dealer. Replacing bearing. I hope they check pressure plate as it can contribute to odd sounds and squeaks too.
Btw only present in mine when warm.
Packofcrows is offline   Reply With Quote
Old 12-02-2015, 12:35 AM   #348
RavioliG
Poor Adult Male
RavioliG's Avatar
Drives: 2013 Subaru BRZ
I had the crunchy pedal feel, and a squeak for a couple thousand miles, when my TOB totally went out and starting making a high pitched whine.
So I dropped my tranny and put in an ACT clutch kit (with a new TOB), lubed the fuck out of everything, and the squeak was gone. All was fine.
~1,000 miles in and the dreaded squeak is starting to come back.
RavioliG is offline   Reply With Quote
Old 12-02-2015, 12:36 AM   #349
Synack
Boosted
Synack's Avatar
Drives: Sideways
Same here. Not sure what to do.
Old 12-02-2015, 06:15 AM   #350
ZZT86
ZZT86's Avatar
Drives: BR86
3 months ago I cleaned/lubed the point where the slave actuator rod meets the clutch fork & it worked a treat . . . . up until now :/ Strange thing is that it's stopped squeaking again but I'm sure not for long.
I'm no expert on this but I'm guessing as it gets so damn dusty/dirty under hood so quickly on these cars that the paint/coating on the fork receptacle has scratched & started to corrode where the ball end of the actuator meets/touches as a result of scuffing which I reckon is causing the squeak. Cleaning the area of all contaminated grease & re-greasing it seems a temporary fix unless I protect the area of dirt.
When that squeak comes back I will clean/lube as done previously (see foot of p13 as per quoted @Ultramaroon instructions) & figure out a solution to prevent anymore dirt attaching itself to the fresh grease - worth a try I guess.
ZZT86 is offline   Reply With Quote
The Following User Says Thank You to ZZT86 For This Useful Post:
Ultramaroon (12-02-2015)
Search this Thread:
Advanced Search
Loud 'Squeak' Noise From Clutch? Brndn704 Issues | Warranty | Recalls / TSB 23 07-20-2020 09:58 AM
Upgraded Clutch Squeak Rybot Issues | Warranty | Recalls / TSB 116 10-09-2019 03:10 PM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 05:08 PM
Clutch Squeak CatDaddysBBQ Issues | Warranty | Recalls / TSB 4 07-14-2015 07:44 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 02:00 AM
