Pat.Thornton
Old 09-30-2015, 12:54 PM   #309
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Mine was pretty bad for a week or two but went away after a 3+hr drive. Now the clutch is smooth as butter. Sure it will blow soon enough
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 09-30-2015, 01:52 PM   #310
Ultramaroon
fabulous
Ultramaroon's Avatar
Originally Posted by rice_classic View Post
People walking on the street look turn their heads because they think I honked at them but it's a rare occurrence and it's only happened a handful of time in the last 6 months (because summer) but recently it reared its ugly head again as the temps have fallen.
Ooo, that's much worse than mine.
Old 10-01-2015, 04:49 PM   #311
Darkazn58
Drives: 2014 Subaru BRZ
I recently brought in my BRZ for a squeaky clutch too. It always squeaked at the bottom of travel after the transmission warmed up. What they did was adjust the clutch engagement point. Their technician stated that the clutch was out of adjustment and that off the factory line the assembly is "too tight".
So now the travel distance & feel of my clutch is completely different. The engagement point is near the bottom of travel unlike before where it was around the middle. Not anywhere remotely as much feedback as before. The travel distance went significantly down from whatever stock was down to 3.5". I measured this from the top of the pedal from bottom of travel to the top of travel. BUT, the squeak is gone.
Has anyone else had their dealership perform this fix? Any experiences you can share?
Darkazn58 is offline   Reply With Quote
Old 10-01-2015, 05:20 PM   #312
Ultramaroon
fabulous
Looks like you found a decent mechanic.
http://www.ft86club.com/forums/showthread.php?t=8040
Unfortunately it doesn't address this issue.
Old 10-02-2015, 12:49 AM   #313
cmihaylov
Mine started doing the same squeak as well at 22k miles. It comes and goes on it's own. I sprayed some white lithium grease on the push rod and it stopped for a couple of days but it's back again. I have a feeling that the clutch fork isn't lubricated enough. What I noticed is that when I push the push rod forward, the squeak completely goes away for some time. Any thoughts on that?
cmihaylov is offline   Reply With Quote
Old 10-11-2015, 12:59 PM   #314
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
Car goes into the shop this thursday to see whats going on
Old 10-12-2015, 09:24 PM   #315
cmihaylov
Dealer said that it sounded like a dry clutch fork. They are sending documents to Subaru corporate to approve the work to be covered under warranty - should be going in the shop this week. When asked them if it's ok to drive the car like that, they said it's fine.
P.s. after picking my car up that same day to fix the tail light condensation issue, the blower fan started making a slight noise. One thing after another but that's what warranties are for.
Old 10-13-2015, 11:20 AM   #316
jcw99
Drives: swp mt '14 brz premium
You say not as much feedback, but I'm assuming the feedback you do get is much better.
jcw99 is offline   Reply With Quote
Old 10-13-2015, 12:43 PM   #317
zonda
Drives: 2014 WRB BRZ
Where is should the clutch engagement point be? I literally just have to push my clutch down about half an inch for it to shift smoothly. Part of me doesn't feel like this is how it should be, but If i push down any further than tha tshifting becomes a hassle. Also, if I just push my clutch down any further, you can hear and feel the squeak. And to start the car, I have to go through the most ultimate sqeaks and crunch feel
zonda is offline   Reply With Quote
Old 10-13-2015, 02:09 PM   #318
strat61caster
strat61caster's Avatar
My clutch pedal is also squeaking, honking, what have you, think mine is internal though in the pedal box inside the car, will investigate there first, add lube and tighten where necessary.
ineedyourdiddly
Old 10-13-2015, 02:55 PM   #319
Ultramaroon
fabulous
Grab the clutch fork and pull it forward to compress the slave.
Hold the pin compressed and jiggle the fork back and forth like you're freeing up an old pair of pliers. Does that do the trick?
strat61caster (10-13-2015)
Old 10-13-2015, 03:00 PM   #320
Ultramaroon
fabulous
Then do this.
Old 10-13-2015, 03:07 PM   #321
strat61caster
Will try in the next few days thanks, like I said though sounds like it's inside the cabin.
Then do this.
Shit 86 owners say:
"Pedal squeak? Replace half the hydraulic system!"
ineedyourdiddly
Ultramaroon (10-13-2015)
Old 10-13-2015, 08:14 PM   #322
Ultramaroon
fabulous
Shit 86 owners say:
Haha... couldn't resist.
But seriously, I've heard a few including mine. They all sound like they're inside. The vibration is tightly coupled through the hydraulics and the firewall is thin enough that it effectively becomes the speaker.
Search this Thread:
Advanced Search
Loud 'Squeak' Noise From Clutch? Brndn704 Issues | Warranty | Recalls / TSB 23 07-20-2020 09:58 AM
Upgraded Clutch Squeak Rybot Issues | Warranty | Recalls / TSB 116 10-09-2019 03:10 PM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 05:08 PM
Clutch Squeak CatDaddysBBQ Issues | Warranty | Recalls / TSB 4 07-14-2015 07:44 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 02:00 AM
