Pat.Thornton
Old 08-27-2015, 03:51 PM   #239
zonda
Drives: 2014 WRB BRZ
2014 brz with only 14k miles has a crunch feeling whenever im an inch from pressing the clutch all the way down. its not a pleasant feeling nor sound.
zonda is offline   Reply With Quote
Old 08-27-2015, 03:52 PM   #240
JS + BRZ
Drives: 2010 MS3
Same here.
And a lot of people are having the same issue. haha
JS + BRZ is offline   Reply With Quote
Old 08-27-2015, 04:00 PM   #241
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
At this point it should be a recall. I`ve had it fixed when the car was at 20k miles, and now at 50k miles it`s back and now I`m out of warranty...
mokinbird87 is offline   Reply With Quote
Old 08-27-2015, 04:06 PM   #242
Brzerker
Brzerker's Avatar
Drives: World Rally Blue BRZ
I just got mine solved, changed out the release bearing (Part No. 30502AA051) and took it out for hard drive and well, the crunchy feel/squeak is gone! And yes, the old bearing was in quite a bad shape...
Brzerker is offline   Reply With Quote
Old 08-27-2015, 04:09 PM   #243
JS + BRZ
Drives: 2010 MS3
Which dealer? Do you think you can post up the service sheet for it?
Old 08-27-2015, 04:12 PM   #244
Brzerker
Brzerker's Avatar
As much as I would like to share, I'm halfway around the world from you :P
Anyway, I did the replacement on my own... Got real tired of playing ping pong with my dealer over on this side... They kept insisting it was the clutch fork or lacking of grease...
Got the bearing at ~$35 USD at the stealership.
The Following User Says Thank You to Brzerker For This Useful Post:
JS + BRZ (08-27-2015)
Old 08-27-2015, 05:13 PM   #245
zonda
took my car to santa monica subaru. manager definitely felt it and said he would check on it. told me to come back when it gets worse since im still on warranty. at the time i didnt know what to look for, but they seemed pretty cool about it. might go back there and see if they can check the bearing.
Old 08-27-2015, 05:21 PM   #246
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
This is a bad news. This is similar to the tail light condensation. They originally were just replacing the tail light over and over. Then they found that the root cause is the body panel. They started to flatten out the body panel when replacing the tail light and the leaking stopped. This noise is caused by throw-out bearing, clutch fork, pressure plate, slave cylinder, or whatever is damaged buy "something" (root cause) no one knows. Replacing the damaged parts stops the noise, for now, but that "something" damages them again and the noise will come back.
mokinbird87, maybe they would cover yours under power train warranty. You should have power train warranty until 5 years or 60k miles whichever comes first. Might be worth the try.
Sigh-on-Rice is offline   Reply With Quote
The Following User Says Thank You to Sigh-on-Rice For This Useful Post:
mokinbird87 (08-27-2015)
Old 08-27-2015, 08:56 PM   #247
mokinbird87
BOXER FR
oh I forgot about that. I`m gonna give that a try.
Old 08-27-2015, 08:57 PM   #248
mokinbird87
BOXER FR
how many petitions was needed for a recall to happen again? I mean, what do I do when I run out of the powertrain warranty?
Old 08-27-2015, 11:44 PM   #249
gravitylover
Originally Posted by MastasmurF View Post
Tell them to check your throwout bearing even if it costs a diagnostic fee. It takes them about 4-5 hours. If they find it to be defective then you shouldn't have to pay and it should be covered under warranty. I should be getting mine back today...
I'm just having a hard time committing to a $500 bill if they decide that it's ok. I know it isn't but...
Old 08-28-2015, 10:29 AM   #250
MastasmurF
Drives: Black 2013 Scion FRS
Ouch... I guess my dealership is cheap. I think they only charge around $150.. Usually they won't make you pay until after they check, not up front. At least this is how my dealership does it.
MastasmurF is offline   Reply With Quote
Old 08-28-2015, 11:18 AM   #251
MastasmurF
Man, I had my tail light replaced 3 or 4 times over the 3 years I've owned the car. This is very concerning though... I don't want to have to go through this again in another 20k miles. I wonder if after market clutches are worth looking in to just to avoid this. Or perhaps if it does happen again I'll do that.
Update 4: I picked my car up from the dealership yesterday. My clutch is now SILKY SMOOTH... It actually feels smoother than when the car was brand new or maybe I just don't remember the feeling because mine has been defective for a while now. I will post my service sheet below in case anyone else needs some reference. Also, after they replaced my clutch assembly they found that the flywheel was defective as well so they kept my car for an extra day while those parts were ordered.
Edit: P.S. Toyota is claiming the whole issue is from the driver resting his or her foot on the clutch pedal too often... Duno...
The Following 2 Users Say Thank You to MastasmurF For This Useful Post:
8R6 (08-28-2015), Sigh-on-Rice (08-28-2015)
Old 08-28-2015, 04:09 PM   #252
Sigh-on-Rice
View Post
I wouldn't recommend to pay for that. My throw-out bearing got replaced, but that didn't get rid of the noise. So, it can very well happen that you pay $500 and the noise still doesn't go away. I would try different dealers until they say they will take care of it under warranty. If you can't find any dealer near you to do so, I would contact Toyota. Toyota should already know that there are many warranty work for this issue.
JS + BRZ (08-28-2015)
Search this Thread:
Advanced Search
Loud 'Squeak' Noise From Clutch? Brndn704 Issues | Warranty | Recalls / TSB 23 07-20-2020 09:58 AM
Upgraded Clutch Squeak Rybot Issues | Warranty | Recalls / TSB 116 10-09-2019 03:10 PM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 05:08 PM
Clutch Squeak CatDaddysBBQ Issues | Warranty | Recalls / TSB 4 07-14-2015 07:44 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 02:00 AM
