#211 |
Drives: 2010 MS3
What's like the usual service/replacement cycle for the bearing? Do you know, Mike?
#212 | |
On my S2k, my throwout bearing was starting to make noise at about 80k. At 116k, the splines on my clutch disk failed, as a result of heat from the throwout bearing, necessitating a clutch replacement. The clutch disk still had about 60% material left (as measured by thickness). You can imagine how many of those miles were track/canyon. |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#213 | |
fabulous
1. Squeak from dry clutch fork pivot. That only squeaks while the pedal is in motion. 2. Squeak from the seized throwout bearing. This is intense and heard as soon as the throwout bearing comes into contact with the pressure plate. I've experienced throwout bearing seizure in past vehicles. Cascade faliure of the pressure plate occurs almost immediately after. If you don't know how to drive without using the clutch. Park it and call a tow truck.
#214 | |
fabulous
Drove home tonight and didn't feel a hint of rumble in my left foot. Grrrr...
#215 | |
#216 | |
fabulous
Lazybones.
#217 | |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
Sent from my SM-G900V using Tapatalk
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread ![]() |
#218 | |
fabulous
Locate the point where the slave actuator rod meets the clutch fork. Have a little grain-of-rice sized dab of grease ready on your thumb. With the same hand carrying the grease, pull the clutch fork forward, collapsing the slave actuator a little bit. Then, while holding the rod with the other hand, squish that little dab of grease into the mating receptacle and let the rod seat itself back in. If that doesn't do the trick, it's time to drop the tranny.
#219 |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Ultramaroon (08-17-2015) |
#220 | |
Drives: FR-S Whiteout
Intent > Content
cowardice is the mother of cruelty. |
#221 |
fabulous
I'm just a guy who has had nothing but bad experiences whenever I've turned anything over to someone else. Be it repair, installation, construction, anything, my satisfaction rate is exactly 0%.
#222 |
Drives: Scion FRS
This is what was replaced on my claim so you guys have an idea.
https://www.dropbox.com/s/srv7z9a71l...%20PM.jpg?dl=0 ![]()
#223 |
Drives: Whiteout FR-S
This thread seems more active in the summer time. Now that I'm out of warranty feel like this is just a ticking time bomb. I've only had the noise come back on very hot and humid days. Will keep an eye on it as the temps decrease
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
#224 |
Drives: 2010 MS3
| Loud 'Squeak' Noise From Clutch? | Brndn704 | Issues | Warranty | Recalls / TSB | 23 | 07-20-2020 09:58 AM |
| Upgraded Clutch Squeak | Rybot | Issues | Warranty | Recalls / TSB | 116 | 10-09-2019 03:10 PM |
| Clutch pedal adjustment gone wrong? Clutch issues. | PulpBrah | Engine, Exhaust, Transmission | 12 | 03-06-2017 05:08 PM |
| Clutch Squeak | CatDaddysBBQ | Issues | Warranty | Recalls / TSB | 4 | 07-14-2015 07:44 AM |
| Clutch pedal squeak. | merino_frs | Engine, Exhaust, Transmission | 1 | 08-25-2014 02:00 AM |
