#197 | |
Drives: Scion FRS
| The Following 4 Users Say Thank You to xlid007 For This Useful Post: |
#198 |
Drives: Scion FRS
My car has full bolt-ons and tune. i guess that depends on the dealer. My dealer called me and told me that they had to remove my exhaust to get to the transmission and since it was aftermarket, they would not be responsible if it didn't line up. That's the only thing you would encounter. I knew they weren't going to have any issues since my exhaust lines up perfectly.
#199 |
Drives: FR-S Whiteout
Good to see this thread... I'm having the same problem. Barely made it into the dealer. By the time I got there they couldn't get it into first gear without stalling the car. They had to push the car into the shop. They're telling me that I may have to pay them $1500 for tear down and inspection if they find that it's not a factory defect.
What a relief I'm not the only one with the same problem.
Intent > Content
cowardice is the mother of cruelty. |
#200 | |
Waited 5 years for this
Drives: '18 MX-5 Club
#201 | |
Intent > Content
| The Following 2 Users Say Thank You to solidONE For This Useful Post: | JS + BRZ (08-17-2015), Sigh-on-Rice (08-17-2015) |
#202 |
#203 |
fabulous
Yeah, THAT squeak is from a seized throwout bearing. It's a quick trip to full meltdown from there.
#204 |
That's a legit claim; lowering your car puts a bit more strains on your axles, and accelerates wear. The driver side is notorious for going out.
#205 | |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
My car is otherwise heavily modded, but it's still the stock clutch Sent from my SM-G900V using Tapatalk
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread ![]() |
#206 | |
If the pedal is squeaky, I'd recommend checking your slave fork, and grease it with high temp grease if the grease is gone. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | JS + BRZ (08-17-2015) |
#207 |
Drives: '13 SSM BRZ Limited 6MT
Mine wasn't just squeaky, it was also "crunchy" as well. The tech described it as a dry throw out bearing which makes sense.
#208 | |
Drives: 2010 MS3
Mine started to squeak back in May I believe. I've done two track days and a lot of hard canyon cruises. Subaru Pacific just didn't want to open up the transmission and check it. They just told me to come back when it gets worse saying that I still have a lot of warranty miles left....
#209 |
Turning is for Nerds
Drives: 35 characters is not enough
Let me know when you do (assuming you get to it before me) this is something on my to do list for winter.
| The Following User Says Thank You to Decay107 For This Useful Post: | Ultramaroon (08-17-2015) |
#210 | |
Even with a bad bearing, the car should run for quite a while, but it's better to get it replaced sooner, rather than later. The bearing is cheap, but the labor is $$$. |
| Loud 'Squeak' Noise From Clutch? | Brndn704 | Issues | Warranty | Recalls / TSB | 23 | 07-20-2020 09:58 AM |
| Upgraded Clutch Squeak | Rybot | Issues | Warranty | Recalls / TSB | 116 | 10-09-2019 03:10 PM |
| Clutch pedal adjustment gone wrong? Clutch issues. | PulpBrah | Engine, Exhaust, Transmission | 12 | 03-06-2017 05:08 PM |
| Clutch Squeak | CatDaddysBBQ | Issues | Warranty | Recalls / TSB | 4 | 07-14-2015 07:44 AM |
| Clutch pedal squeak. | merino_frs | Engine, Exhaust, Transmission | 1 | 08-25-2014 02:00 AM |
