86WORX
Pat.Thornton
Old 08-13-2015, 10:04 AM   #183
MastasmurF
Drives: Black 2013 Scion FRS
Originally Posted by CatDaddysBBQ View Post
It took the dealership a few days to fix mine - the had to order clutch parts. That squeak ended up being a whole new clutch, master cylinder and shift fork by the time they worked their way down to the actual problem.
Were you still under warranty and did they provide you with a rental car free of charge if so?
MastasmurF is offline   Reply With Quote
Old 08-14-2015, 10:23 AM   #184
MastasmurF
Originally Posted by MastasmurF View Post
So I'm having this same exact problem on my 2013 FRS. I did some reading in these forums and found the threads relating to the throw out bearing being worn out etc. So I brought mine in to the dealership. I mentioned to my service rep that it may be the throw out bearing but I don't think he paid any attention to my suggestion. They called me back a few hours later and told me that it was fixed. Here is what they put on my report.
" Driveability Concern:
Clutch is making a loud squeaking noise. Pin-pointed noise to Slave Cylinder. Greased clutch slave cylinder and abnormal noise is not heard."
About 200-300 yards after driving off the lot I started to feel a physical "crunching" feeling when pushing the clutch all the way in. The squeaking noise came back in full force and it is actually more audible now. I'm dropping it off again this Friday.
This is my first full-time standard transmission daily driver. I don't think I "ride the clutch" either. So I can't see it being my fault with only 17,400 miles on it. Is it a whole day job for them to check the throwout bearing?
Update 1: I dropped my car off this morning and spoke with the mechanic who will be working on it. I told him about the throwout bearing issue that some people have and he said it can't be that because the noise is happening when the engine is turned off. I don't know the fine details on how those parts work so I don't know how true that is. He mentioned that someone else brought theirs in earlier this week with the same issue. He said that there is most likely some rust build up in the slave cylinder that needs to be greased. I'll post an update when I get my car back.
Old 08-14-2015, 11:02 AM   #185
CatDaddysBBQ
Drives: '13 FR-S
Under warranty. Came in with 35,4xx miles on the clock, lol. Honestly I think that would be under the 4/48 power train coverage, but it's still funny to think I slipped in with like 500 miles to go.
I got a rental for free, they had the car for about 6 days. I'll look for the paperwork and try to upload it if i can.
CatDaddysBBQ is offline   Reply With Quote
Old 08-14-2015, 03:55 PM   #186
MastasmurF
Update 2: I picked up my car from the dealership and they said that it was the Slave Solenoid connections that were causing the noise. I mis-quoted the tech in my earlier post. They removed the solenoid connections and greased them. I could not hear the sounds while I was in the parking lot but after I drove back to my house which is only 2 or 3 miles away it started making the same noise again... I'm not really sure what to do here... Oh and I also did a test and it makes the noise whether the engine is running or not. I feel like they are really trying to avoid breaking the clutch down to find the issue. Any suggestions?
Old 08-14-2015, 04:19 PM   #187
Ultramaroon
fabulous
Ultramaroon's Avatar
It's your throwout bearing carrier binding/grinding against the transmission front cover. Print the image on this post and show it to your service dept.
gonzo (11-05-2015), JS + BRZ (08-17-2015), SuperDave (08-20-2016)
Old 08-15-2015, 07:15 AM   #188
tracerit
Drives: '13 SSM BRZ Limited 6MT
I'm picking my car up today. I had the same issue, squeaky sounds from the clutch after its been warmed up. It also felt a bit crunchy (think wet rubber like) when fully pressed in.
They attributed the issue to the throw out bearing. I'll try to put more details once I get the receipt.
tracerit is offline   Reply With Quote
Old 08-15-2015, 03:26 PM   #189
Ultramaroon
fabulous
15K miles and I'm starting to feel a little rumble in my clutch pedal when the engine is running.
I'll crack it open soon. Pics to follow.
Old 08-15-2015, 10:34 PM   #190
tracerit
Here's my invoice. Drove 30miles home and it's perfect. Warranty covered everything.
The Following 2 Users Say Thank You to tracerit For This Useful Post:
JS + BRZ (08-17-2015), Sigh-on-Rice (08-15-2015)
Old 08-15-2015, 10:57 PM   #191
Ultramaroon
fabulous
Man, imma have to check my axle nuts.
Old 08-15-2015, 11:04 PM   #192
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Pretty sure my throw out bearing is causing my clutch to squeak as well. I already had both axle nuts replaced and turqued up. Which fixed all clicking sounds
Sent from my SM-G900V using Tapatalk
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 08-15-2015, 11:10 PM   #193
Ultramaroon
fabulous
Guess we can drop our trannys together.
...wait, wut?
Aztec (08-15-2015)
Old 08-15-2015, 11:16 PM   #194
Aztec
Aztec's Avatar
...wait, wut?
Let's do it some weekend coming up. You got the tools?
NEW CAR!🚨🏎️⛽
Old 08-15-2015, 11:28 PM   #195
Ultramaroon
fabulous
Does a bear shit in the woods? Srsly, tho, it would probably be best to split it up. We're both eligible for warranty. I just can't handle the idea of someone else potentially half-assing the job.
Old 08-15-2015, 11:31 PM   #196
Aztec
Aztec's Avatar
My car has a cat less header, lowered, wheels, tuned.
I'm not too sure I want to deal with them haha. They refused to fix my clicking axles nuts because I was lowered ha
EDIT: They blamed the clicking noise on the lowering springs. I'm like wat...
NEW CAR!🚨🏎️⛽
The Following User Says Thank You to Aztec For This Useful Post:
Ultramaroon (08-15-2015)
Search this Thread:
Advanced Search
Loud 'Squeak' Noise From Clutch? Brndn704 Issues | Warranty | Recalls / TSB 23 07-20-2020 09:58 AM
Upgraded Clutch Squeak Rybot Issues | Warranty | Recalls / TSB 116 10-09-2019 03:10 PM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 05:08 PM
Clutch Squeak CatDaddysBBQ Issues | Warranty | Recalls / TSB 4 07-14-2015 07:44 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 02:00 AM
