| View Poll Results: Have you blown your stock motor with boost? | |||
| Yes complete failure needs rebuild |
32 | 5.39% |
| No been boosting and running strong |
188 | 31.65% |
| Nope because I am not boosting my motor |
374 | 62.96% |
| Voters: 594. You may not vote on this poll | |||
#393 | |
Drives: Moped
A good tune is always a necessity for a car boosted by the aftermarket, it's the apparent necessity of internals (even at low boost levels) that seems troubling for the 2013 motors. |
#394 | |
Drives: 2013 SWP BRZ
I ran an innovate kit on my brz for close to 15k miles, and now have made the transition to a turbo kit. Will be putting more power down, so i'm crossing my fingers I don't get added to the list. But I already accepted the fact that this motor may one day blow up regardless and am prepared for it in case it does happen. I probably wouldn't have even touched my setup if my car stopped being my daily and I had to drive it everyday. |
| The Following 3 Users Say Thank You to xxscaxx For This Useful Post: |
#395 |
Drives: 2013 FR-S, HKS V2 S/C
| The Following 5 Users Say Thank You to Scott@HKSUSA For This Useful Post: | Astroboy (05-14-2015), Billion (05-14-2015), Drift-Office (05-14-2015), Fiebruz Motorsports (05-27-2015), raven1231 (05-14-2015) |
#396 | |
Drives: 2013 "AVO Orange" FR-S
We keep the standard rev limit on our base maps and tunes, even Ross's race car sticks to the standard rev limit since he is running a standard block and heads. |
#397 |
Drives: 2014 Scion FRS (Ultramarine)
I seriously doubt any of these engines that have popped are the result of a bad tune from any of the reputable tuners around. They pop for any number of reasons more then likely related to stress... Either too much boost, too much engine stress from tracking, mechanical errrors or a whole myriad of other possible issues. The tune is only one factor in boosting a car. Even a near perfect tune isn't going to save you if your rods are weaken due beating on the car or running ridiculous amount of boost. The reality is that these engine were not designed for boost and getting them to run boost while possible is just opening it to risk. Its a risk i've chosen to take... I'm running AVO kit, 8psi, E85 on stock fuel system... With a tune from Delicious Tuning and a previous tune from Drift Office. I don't track and this is my daily. I know the risk, can you boost it? Yes, can it be reliable? somewhat... Its just risky and up to you to accept that risk.
| The Following 2 Users Say Thank You to solus For This Useful Post: | raven1231 (05-14-2015) |
#398 |
Junior
Drives: a car
Bearings, people money shifting, rocker arms designed on the back burner.
#399 |
Drives: 2014 Black BRZ Limited
Just my little input: stock motor, kraftwerks c38 kit, 550cc injectors, tuned
by Moto-East. Around 3k miles put on and still running damn strong. No issues or CEL, planning on running the smaller 70mm pulley soon. |
#400 |
Drives: toyota mr2/ Toyota GT86
I'd be interested to poll just how far the boosted set of motors have run for ?
as OEM's pass off an engine spec typically with a mix of looong dyno tests like 100hours at full throttle and full rev's or 400 hours mixed running or the thermal shock test where the engine is chilled down to -10 deg C and then started, idlied for 30 seconds tehn given full power and revs for a minute then stopped and chilled down again - and this process repeated for 100 times so to say that my motor has done 3000 miles on the road ( where you are rarely on full load for more than 10 seconds at a time) and then say these motors are fine boosted well........... time will tell gentlemen, its too early to say otherwiseas I don't think anyone has put big miles on a boosted motor yet |
#401 |
Drives: 2013 Toyota 86
This guy has put a fair few miles on his car running 19psi
http://www.ft86club.com/forums/showthread.php?p=2248340 |
#402 |
Drives: Asphalt FRS <3
FA20CRAP TURBO KIT
Garrett T3/T4 57 TRIM 25 XXX KM on the turbo Still good, no cel or anything. No track days, done some drifting though
#403 |
What PSI and power levels are you at?
#404 |
Running 9psi on 94 oct (haven't been dynod)
299whp on e85 @ 7psi
| The Following User Says Thank You to Scalzo For This Useful Post: | raven1231 (05-28-2015) |
#405 |
@King Tut
Add me to the list... AVO Turbo Kit - full 3" catless exhaust -Ecu Controlled boost 10-15psi -Overboosted to 22psi in 5th gear on the highway and developed a knock (all vacuum lines intact) -23,000km with no issues up until this
#406 |
Drives: 2013 Scion FR-S, 1993 Lexus SC300
| How much HP can the stock motor handle? | FullTuneZN6 | Engine, Exhaust, Transmission | 34 | 11-16-2017 02:22 AM |
| Full Blown 521hp Stock Motor @ 20psi | FullBlown | Forced Induction | 276 | 08-31-2016 03:05 AM |
| FBM 604Hp 472Tq -- Stock Motor Stage 2 Turbo Kit | FullBlown | Forced Induction | 414 | 07-14-2014 10:52 PM |
| FRS300 Rebuild Has Begun..Blown Motor to Built Monster | FA20Club.com | Forced Induction | 917 | 10-20-2013 07:26 AM |
| Highest HP on stock motor using only 93/94 octane? | hmong337 | Forced Induction | 11 | 09-09-2013 11:53 AM |
