View Poll Results: Have you blown your stock motor with boost?
Yes complete failure needs rebuild 32 5.39%
No been boosting and running strong 188 31.65%
Nope because I am not boosting my motor 374 62.96%
Voters: 594. You may not vote on this poll
Old 07-28-2014, 07:22 PM   #225
Cross
It's the Mad Cow
Cross's Avatar
Originally Posted by cdrazic93 View Post
What is this VVTi problem? Im assuming it sounds like VTEC gone bad
There are a few cam related issues listed in the Recall Thread but this is the one I was mainly talking about however they all seem to be related.
One fix is a shim, @s2d4 mentioned a part change that I am not aware of and want to know about. If there is a fix I want to know.
This user had a turbo setup and had a similar issue.
http://www.ft86club.com/forums/showthread.php?t=65050
Recall Thread:
http://www.ft86club.com/forums/showthread.php?t=21868
Subaru TSB:
02-132-12 : DTCs Relating to the AVCS (Active Valve Control System)
11-130-13R : Difficulty Starting, Rough Idle, Cam Position, Misfire
Scion TSB:
S-SB-0033-13 : Hard Start, Rough Idle, Camshaft Sensor or Misfire DTCs
My CEL's:
P0300
P0301
P0021
P0014
P000B
P000C
Old 07-28-2014, 10:34 PM   #226
D K
Stig's dark passenger
Originally Posted by fast_dude View Post
If you don't blow your motor your lucky, but evently you will wear the motor out. I will stay away from the boosted application.
Im the same.
Seems like boost is evil.
Im going back to trolling the prom thread.
D K is offline   Reply With Quote
The Following User Says Thank You to D K For This Useful Post:
Sportsguy83 (07-29-2014)
Old 07-29-2014, 12:33 AM   #227
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
I've recently had the motor go on me
Sprintex Supercharger running 70mm pulley on 95rON.
Prior to the engine failure I had the following codes over a 6 month period.
PO351 coil pack
Po372 (I think it was this code for Cam position)
PO300 multiple misfire
At the time of failure I happed to be logging, indication is too much boost (.8 bar) on 95RON.
Busy with rebuild.
Ryan86 is offline   Reply With Quote
Old 07-29-2014, 01:54 AM   #228
D K
Thats like getting on a flght thinking you could crash.
There are many FA20's running around with no cam timing issues.
I would be more concerned in trying to find out exactly what happened instead of saying screw this, time for another motor.
Imagine if you got an LS7 and something happened to the factory dry sump...
Does that make all LS7's bad?
D
I found someone else while searching the forums here, I will see if I can find it again.
My issue is those that had it fixed there was no real parts replacement I was told by the tech so I could face the problem again and being boost when that happens it will result in the same problem if not worse should it happen while I am racing and not just driving normally.
If I could trust the FA20 I would just put in another and shrug it off as a fluke as I seem to face many strange situations. But at this point I do not know that I can.
Old 07-29-2014, 03:46 AM   #229
brianhj
Drives: 2017 Camaro 1SS
PO351 coil pack
Busy with rebuild.
What's the stock pulley on the sprintex? Too lazy to look it up
Also do you have pics of the failure? Did the block just crack or what?
Sorry for your loss And to think the sprintex package is one of the more tame ones out there.
brianhj is offline   Reply With Quote
Old 07-29-2014, 04:42 AM   #230
Dipstik-sportech
Dipstik-sportech's Avatar
PO351 coil pack
Busy with rebuild.
How do u overboost with a supercharger? I'm thinking it was poor quality fuel that caused your failure or a lean condition
Old 07-29-2014, 09:52 AM   #231
Ryan86
Road Warrior
Ryan86's Avatar
75mm pulley is standard for IC version.
The block is fine, melted piston.
Old 07-29-2014, 09:54 AM   #232
Ryan86
Road Warrior
Ryan86's Avatar
I never said over boost, i ran too much boost for the shit fuel we have here.
Old 07-29-2014, 02:02 PM   #233
DennisTheMenace
Drives: 2013 Toyota GT86 FBM
Add me to the list plz :-(
FBM stage 1 premium kit(one of the first, bought september 2013) with all te bells and whistles, GTX30, base map customized by LJ.
Mileage around 1000 miles, ran fine and strong until 2 days ago. After 5 km power loss, E/G knock and finally a lot of smoke. First cylinder rod snapped and knocked a hole in the block.
Had a few small problems with the kit from the beginning, but I have to say top notch service from FBM solved every single one of them in reasonable time. Reported failure @ mail LJ last sunday, received reply yesterday and I'am sure we're working things out as always...
I suspect fuel conditions here in Europe are different than in U.S. I'am going for a fully built block now but before it will run one second, I will bring it to a Subaru and ECUTEC specialist... Pretty sure starvation/running lean lies at the root cause.
DennisTheMenace is offline   Reply With Quote
Old 07-29-2014, 02:29 PM   #234
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
Man this poll is scaring me. As it is now only 100 people who have (or had) FI have voted. You have a 1/10 chance to blow your motor when going FI. 10 votes for yes I have blown a motor and 90 for I have not (have yet) a motor.
Making me think twice
GotBRZ1691 is offline   Reply With Quote
Old 07-29-2014, 02:32 PM   #235
loogs
Drives: on cruise control
this thread made my decision for me. 1 in 10 or 1 in 100 is not worth it. good luck to anyone that does it
loogs is offline   Reply With Quote
Old 07-29-2014, 02:38 PM   #236
GotBRZ1691
GotBRZ1691's Avatar
I'm thinking Phantom Electric Supercharger after seeing this thread. They look like fun. Will use that, because I believe it is safe for stock motor, until I can afford to build a block.
And more importantly, Until I can afford to replace a block if necessary.
Out of all of the blown motors out there. How many people regret going FI and how many loved it, despite the short run at it. Guess im asking if you could change it, would go back in time.
Old 07-29-2014, 03:46 PM   #237
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
Why are people running FI without WB?????
Why are people running their cars without WB with FI???? I don't get it.
If you have FI in any car, you should be running a WB and any time it starts to go lean, you stop and figure out the issue.
Run FI in a car with a 12.5:1 CR and no WB, you're friggin crazy....
Jaden
^------buying WB before even tuning the non FI car, let alone once I go FI...
ok. I might run a shiv tune before having WB...but not for very long though...
Jaden is offline   Reply With Quote
Old 07-29-2014, 04:37 PM   #238
Cross
It's the Mad Cow
Cross's Avatar
Jaden
Are you just running around making ignorant posts to raise your post count or something?
Where are you pulling this crap from first 21k out of thin air and then that people are all not running WB's....
The Following User Says Thank You to Cross For This Useful Post:
raven1231 (05-29-2015)
Search this Thread:
Advanced Search
How much HP can the stock motor handle? FullTuneZN6 Engine, Exhaust, Transmission 34 11-16-2017 02:22 AM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 03:05 AM
FBM 604Hp 472Tq -- Stock Motor Stage 2 Turbo Kit FullBlown Forced Induction 414 07-14-2014 10:52 PM
FRS300 Rebuild Has Begun..Blown Motor to Built Monster FA20Club.com Forced Induction 917 10-20-2013 07:26 AM
Highest HP on stock motor using only 93/94 octane? hmong337 Forced Induction 11 09-09-2013 11:53 AM
