| View Poll Results: Have you blown your stock motor with boost? | |||
| Yes complete failure needs rebuild |
32 | 5.39% |
| No been boosting and running strong |
188 | 31.65% |
| Nope because I am not boosting my motor |
374 | 62.96% |
| Voters: 594. You may not vote on this poll | |||
#211 | |
Road-hole
Drives: 2013 Whiteout FR-S
anyone who's running boost...
Jaden |
#212 |
Boosted Member
Drives: 2013 SWP BRZ Limited
I'm just running a boost gauge currently, and reading the AFR through the factory O2 sensor with Scanguage II. Although the factory sensors can only see to 12.0 ish to 20.1, won't that range be good enough? I know when I go WoT, it will be at 12.0 for a while, knowing its below that. Cruising, about 14.7 to 14.0, idling/coasting at 20.1 to 19.8.
Are widebands more accurate, or is it better just seeing a wider range of AFR's?
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12 |
#213 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#214 | |
It's the Mad Cow
Since there is no real fix I choose not to go with another FA motor, not that any other would have been better I think these motor's take abuse well but I could not risk running into the same problem again. I have found myself asking though if there is a way to do a VVTI delete kit to prevent the problem... I am still at the point I could sell the LS and everything else and put in another FA20 and be back up and running... I just don't know that I would ever trust it.
05 GTO 408 Stroker \ 13 FRS 210 Twin Screw Supercharger on E85 \ 14 F-150 5.0L |
#215 |
I Love custom Turbo kits
Drives: Limited BRZ
Might as well just get a different motor. Removing VVTI is equivalent to castrating it...
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | D K (07-29-2014) |
#216 |
It's the Mad Cow
But if the VVTi is going to cause failures at unknown times like mine then it just becomes a ticking time bomb until they finally make a replacement part that stops the issue from happening.
#217 |
Drives: Limited BRZ
VVTI is an integral system of the car making power, there is no way around it to "detele it" and it still being a good motor for making power.
#218 | |
It's the Mad Cow
![]() I am not disagreeing with you but it's a double edged sword it seems, without it the car has no power. Yet having it there is a TSB for a known problem with it but no real fix.
05 GTO 408 Stroker \ 13 FRS 210 Twin Screw Supercharger on E85 \ 14 F-150 5.0L Last edited by Cross; 04-15-2015 at 06:09 PM. |
#219 | |
Drives: Limited BRZ
Also, there is no pattern or lots of failures of motors because of the VVTI. In general, cars that initially had the issue get it fixed at dealer and it never comes back. It has been very rare for a car to have had no problems with VVTI from the start and develop it later. Your motor is the first one I've actually read it happened.
#220 | |
It's the Mad Cow
My issue is those that had it fixed there was no real parts replacement I was told by the tech so I could face the problem again and being boost when that happens it will result in the same problem if not worse should it happen while I am racing and not just driving normally. If I could trust the FA20 I would just put in another and shrug it off as a fluke as I seem to face many strange situations. But at this point I do not know that I can.
#221 |
Junior
Drives: a car
What is this VVTi problem? Im assuming it sounds like VTEC gone bad
#222 |
Drives: 2014 Scion FRS
If you don't blow your motor your lucky, but evently you will wear the motor out. I will stay away from the boosted application.
2014 Scion FRS- Kw2 suspension, Openflash headers, Openflash tablet, Invidia N1 exhaust, Invidia Overpipe, Nameless catted front pipe, TRD intake, Enkei RPF1s with Hankook RS3 tires, carbon fibre front lip, TRD knockoff spolier, SPC lower control arms.
#223 | ||
Drives: Limited BRZ
#224 | |
| How much HP can the stock motor handle? | FullTuneZN6 | Engine, Exhaust, Transmission | 34 | 11-16-2017 02:22 AM |
| Full Blown 521hp Stock Motor @ 20psi | FullBlown | Forced Induction | 276 | 08-31-2016 03:05 AM |
| FBM 604Hp 472Tq -- Stock Motor Stage 2 Turbo Kit | FullBlown | Forced Induction | 414 | 07-14-2014 10:52 PM |
| FRS300 Rebuild Has Begun..Blown Motor to Built Monster | FA20Club.com | Forced Induction | 917 | 10-20-2013 07:26 AM |
| Highest HP on stock motor using only 93/94 octane? | hmong337 | Forced Induction | 11 | 09-09-2013 11:53 AM |
