#169 |
Drives: 2013 Black FR-S
This 91 octane test car doesn't happen to just be using stock injectors does it?
#170 |
Drives: White FR-S
#171 |
Drives: 2013 Ultramarine FR-S
Question regarding this 91 octane tune (and your base map in general).
If someone were to purchase your turbo kit, along with the fueling package, but were unable to visit your shop for tuning, and/or doesn't have a trusted tuner local, What would you recommend for getting the car up and running, and safe for daily use (and 'spirited abuse')? Would you consider the base map that you currently provide (and will for 91 octane, I'm assuming) trustworthy and safe as a final tune solution? Would you say its necessary to visit a trusted tuner/dyno for fine tuning and/or monitoring? Or only recommended? Would 'e-tuning' be a reasonable solution? Thanks in advance, and I'm looking forward to seeing the 91octane results!
![]() '13 Ultramarine 6MT FR-S || K&N Drop-In, SpeedFactory V1 Cat-Back || Moto-East tuned Join the 86 Owners Clan on Clash of Clans: "86 Owners" Password: "fa20" || Help us take over the world || Thread |
#172 | |
#173 | |
Drives: 2JZ FRS
The drive down Friday night and a hotel room, or super early drive Saturday morning is well worth the peace of mind when it comes to having a perfect, in person tune by someone who really knows their stuff. I'm not as far as you but I still drive 3 hours in traffic to have toan tune my car because there are far to many horror stories on this site of destroyed motors from poor tunes. Some are even in person tunes, not just e tunes. Hell, my car is at Ptuning right now getting the flex fuel tuning finished up
| The Following User Says Thank You to spitfire481 For This Useful Post: | ptuning (04-03-2014) |
#174 |
Drives: 2013 Subaru BRZ
#175 |
Drives: GT86
what would be the highest PSi one could run with the base map?
and if WMI is added what PSI ? |
#176 | |
#177 |
That is what they do. They use both MAF and SD. But you can't just use MAF since it will be maxed out with this setup.
| The Following 2 Users Say Thank You to sw20kosh For This Useful Post: | AllDayJonRay (04-03-2014), ptuning (04-03-2014) |
#178 | |
Drives: White FR-S
Due to the many variables involved with tuning this platform, especially considering that we are converting an originally NA car to FI, we recommend final tuning for optimum results. We do offer base maps that will allow you to drive your car to a local tuner or to start your etuning, but the only truly safe base map would need to be somewhat watered down and will not give you the results that our turbo system is fully capable of. - Toan |
| The Following User Says Thank You to ptuning For This Useful Post: | lucid215 (06-25-2014) |
#179 | |
#180 | |
Drives: White FR-S
With that said, 99% of FI companies run a blow-thru MAF for the reasons listed above. Most of us also weld our MAF housing to the intercooler pipe. We do not want to to run a 3", 3.5", or 4" upper intercooler pipe, just to keep from overrunning the MAF sensor as we up the power. Doing so is plain silly, not to mention the MAF readings totally suck when you run a blow-thru MAF housing larger than a 2.5". The central TB location on an FA20 engine doesn't allow you to build a proper 3" blow-thru MAF with a straight section that allows for non-turbulent MAF readings. A 2.5" MAF pegs 5 volts at around 260whp on our dyno on pump gas. This is not going to cut it for us. We can go to a 3" to try to achieve 300-350+whp, but the MAF readings will NOT be stable. You'll go around in circles trying to zero in on your fuel trims. So with that said, what's wrong with a running hybrid MAF/speed density tune? - Toan |
| The Following User Says Thank You to ptuning For This Useful Post: | andrew20195 (04-03-2014) |
#181 |
Drives: White FR-S
#182 | |
Drives: White FR-S
- Toan |
| The Following User Says Thank You to ptuning For This Useful Post: | AllDayJonRay (04-03-2014) |
| Tags |
| ptuning, turbo kit |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| AVO Turbo Kit Owners Topic | Sportsguy83 | Forced Induction | 1935 | 02-20-2023 11:46 AM |
| Full Blown Turbo Kit Owners Topic | King Tut | Forced Induction | 2637 | 12-27-2020 04:44 PM |
| FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 01:36 PM |
| P&L Turbo Owners Topic Thread | GTB/ZR-1 | Forced Induction | 4 | 09-01-2013 07:27 PM |
