#57 |
Drives: '13 FR-S Raven 6MT
Just so we're clear: The sound OP is talking about is NOT the start-up-dance backfire lump.
| The Following User Says Thank You to Evil Jesus For This Useful Post: | strat61caster (01-31-2014) |
#58 |
Drives: Yes
I listened extra hard today. It does sound like it's coming from the flywheel area, and comes and go with the clutch in/out
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
#59 |
Drives: 2013 BRZ Limited AT
Cars with automatic trans do the same thing. You might notice that if you put the car into gear, push in the clutch, or otherwise get rolling it goes away immediately. I've been told by several tuners that the noisy startup is due to the way the car tries to heat up the catalytic converter. There isn't much they can do to change the startup sequence.
#60 | |
Drives: 2014 Scion FRS MT
| The Following User Says Thank You to Moe23 For This Useful Post: | strat61caster (02-03-2014) |
#61 |
Just drive it
Drives: 13' FR-S
Happened to me few times when it was extremely cold. The engine would make bap bap sound for 2-3 times and it goes away after it warms up. Never happens during warm weather.
#62 | |
I've chatted with a few tuners about startup and this is my best guess as to what's going on. I can reproduce it just about every time I start up when it's under 40F out IFF I just let the car idle to warm-up. If I go into gear a few seconds after start-up, the revs immediately drop and the car smooths out. |
| The Following User Says Thank You to kuhlka For This Useful Post: | Bristecom (02-03-2014) |
#63 |
Boosted Member
Drives: 2013 Subaru BRZ
Wow glad I found this thread..
I just recently turbo'd my car so I have been paying extra close attention to every little noise the car makes. I heard this at idle and was getting worried.. but it goes away as soon as there is any load on the engine. I had my tuner raise my idle a tiny bit and now it doesn't do it at idle, but it still does it when I give the gas pedal the tiniest little tap. The car wants to studder and then "knock". I have a hunch it is something to do with the idle/not under load timing.. or piston slap... but whyy..
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG 2011 Honda CBR1000RR 2010 Subaru Impreza WRX PRM SSM Last edited by woode; 02-05-2014 at 10:20 PM. |
| The Following User Says Thank You to woode For This Useful Post: | Moe23 (02-06-2014) |
#64 | |
#65 |
Boosted Member
yes, and no the noise I am talking about isn't the flywheel - that definitely makes it's own rattle
2014 Subaru XV Crosstrek Hybrid TRG PG 2011 Honda CBR1000RR 2010 Subaru Impreza WRX PRM SSM |
| The Following User Says Thank You to woode For This Useful Post: | Moe23 (02-07-2014) |
#66 |
Don't care
Drives: 2013 Whiteout FRS
Also glad i found this thread, we have been having cold mornings in houston as of late and my car started making this noise. First i thought it was rod knock but realized it wasnt following RPM. My guess is it has something to do with the engine rocking/shaking when it hasnt warmed up yet. I first noticed it after adding the positive shift bushing into my transmission, but not sure if this is related.
#67 |
Mine was definitely flywheel/clutch rattle. Goes away with the clutch pushed in.
#68 | |
#69 |
Drives: 13 Firestorm FR-S
1800 miles on the clock, and heard it the first time today.
Mine matches the noise from the outside in the second video DEAD-on. 6-spd manual, but other posters were saying they were hearing it on the auto as well. I was also having idle hunt a little more than usual as well. Nothing to bring it to shudders or throw a code/light, but just varied a bit more. -Rich H.
Current: 16 Porsche Cayman, 09 Tacoma 4WD, 13 Highlander 4WD, 12 Yamaha WR250R
Past: 13 10-Series FR-S, 13 FR-S, 11 S4, 07 Corolla, 98 Tacoma 4WD, 03 Corolla, 89 Camry, 90 Celica GT-S, 87 Celica GT-S |
#70 |
Drives: Yes
So my first BRZ was totaled and I got a new one in March, and this one doesn't make the sound.... hmmmm
| Knocking sound from what sounds like rear suspension | husker741 | Issues | Warranty | Recalls / TSB | 12 | 04-24-2017 06:26 AM |
| Cold weather knocking during start ups. | JDMenrique | Issues | Warranty | Recalls / TSB | 38 | 01-13-2015 12:53 AM |
| Knocking/Rattle on start up. | jimbobrand | Issues | Warranty | Recalls / TSB | 18 | 01-13-2014 12:34 PM |
| Bubbling/knocking (but not liquid) sound aside from chirping | mike_ekim1024 | Issues | Warranty | Recalls / TSB | 22 | 05-05-2013 04:20 PM |
| Knocking sounds from lowering springs? | bbaik | Issues | Warranty | Recalls / TSB | 7 | 03-08-2013 12:50 AM |
