Old 01-25-2014, 08:30 PM   #43
Spicer66
Spicer66's Avatar
Drives: Raven 6 MT
I get the exact same thing you have, no idea what causes it. until the car gets up to the middle of the temp gauge i hear the knocking when the car is at idle. Sometimes it's cold enough that it doesn't get up to that temp on my whole 20 minute drive home and at every stop light I can hear it.
Spicer66 is offline   Reply With Quote
Old 01-26-2014, 12:15 AM   #44
Evil Jesus
Evil Jesus's Avatar
Drives: '13 FR-S Raven 6MT
Originally Posted by AllStar0419 View Post
I've heard knocking when my car was idling in less than 10 degree temperatures Both times it was before the car was warmed up and the knocking went away when the engine reached normal temperature. Here are 2 videos I took, one from inside and one from outside with the hood open. Is this the same as yours?
That second video sounds a lot like mine.
Evil Jesus is offline   Reply With Quote
Old 01-26-2014, 06:25 PM   #45
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
Mine sounds like the 2nd clip when the engine is still warming up.
Muaddib is offline   Reply With Quote
Old 01-26-2014, 11:33 PM   #46
Moe23
Drives: 2014 Scion FRS MT
Yes thats the exact same noise, Im glad I'm not the only one.
Any idea as to what is causing the knocking?
Moe23 is offline   Reply With Quote
Old 01-28-2014, 11:37 AM   #47
whtchocla7e
Drives: 2013 FR-S Hot Lava
Push the clutch in to see if it goes away.
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 01-28-2014, 09:35 PM   #48
Moe23
I tired it, the sound the goes away every time I push the clutch in
Old 01-28-2014, 09:50 PM   #49
AllStar0419
AllStar0419's Avatar
Drives: 2013 FR-S Asphalt
I'll have to try that next time to see if it's the same for me. If so, what does that mean?
Sent from my Galaxy S4 using Tapatalk Pro
AllStar0419 is offline   Reply With Quote
Old 01-28-2014, 09:52 PM   #50
chas3wba0
chas3wba0's Avatar
Drives: Yes
Possibly that the small amount of load from the transmission shaft in Neutral causes/contributes to the sound
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 01-28-2014, 10:54 PM   #51
Xabiss
Drives: 2013 - RBZ
I have an automatic and I have the noise. I will try and put it in neutral next time I hear it.
Xabiss is offline   Reply With Quote
Old 01-29-2014, 01:39 AM   #52
whtchocla7e
It was once speculated that it's the flywheel that makes this noise. It should go away after you drive for a while and the car is fully warmed up. It goes away for me at least.
Old 01-29-2014, 02:58 AM   #53
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
Maybe this noise is the fuel pump? Since the fuel pump does the "chirping" maybe it does this too haha.
But only thing related to this that I've noticed is when starting sometimes for a few seconds the engine is kinda shuttering/jittering and seems to kinda cut out. Almost like it's running on 3 cylinders. But it only lasts a few seconds till it warms up slightly.
dave77 is offline   Reply With Quote
Old 01-29-2014, 08:41 PM   #54
HapaHaole
Drives: Grocery cart
I have it also, usually when the temp is around the 40's. It goes away when I push in the clutch, so it has to be related to the transmission. Let us know what the dealer says
HapaHaole is offline   Reply With Quote
Old 01-29-2014, 09:25 PM   #55
fasterthanu
Drives: 2014 R32
I had this problem last winter,did not notice it until I added the exhaust. Almost like a cold backfire pop. It would do it a few times until the idle became stable.It did not help when I had a lot of load on the engine during idle either.eg (defrost frt and rear/radio running lights) make sure any electric accessory is off when you first start it.
fasterthanu is offline   Reply With Quote
Old 01-30-2014, 03:16 PM   #56
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
I'm almost at 22,000 miles and have heard my car make this same noise since late November.
Darryljr11 is offline   Reply With Quote
Search this Thread:
Advanced Search
Knocking sound from what sounds like rear suspension husker741 Issues | Warranty | Recalls / TSB 12 04-24-2017 06:26 AM
Cold weather knocking during start ups. JDMenrique Issues | Warranty | Recalls / TSB 38 01-13-2015 12:53 AM
Knocking/Rattle on start up. jimbobrand Issues | Warranty | Recalls / TSB 18 01-13-2014 12:34 PM
Bubbling/knocking (but not liquid) sound aside from chirping mike_ekim1024 Issues | Warranty | Recalls / TSB 22 05-05-2013 04:20 PM
Knocking sounds from lowering springs? bbaik Issues | Warranty | Recalls / TSB 7 03-08-2013 12:50 AM
