| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#29 | |
Drives: 2005 Toyota Camry
It doesn't matter if you run +100 offset or -100 offset wheels, there is no way the car will know what wheels you have on the car unless you have physically swapped out the hub assembly. -alex |
#30 | |
Night Raid
Drives: '14 CBS BRZ
#31 |
Drives: Dark Grey BRZ
I'm not sure if this would affect your warranty or not (seems unlikely but it could depend on the dealership) but they'd charge you a lot of money to do something you can do for cheaper.
#32 |
#33 |
Night Raid
Drives: '14 CBS BRZ
Well I guess we'll have to see.... its 175 for a speed sensor but we don't know which one it is. My speedo doesn't work and my fuel gage is acting up. I think it was throwing up a instrument cluster code as well.
#34 |
Try and swap with a local to see if it fixes your problem. Should only take a few minutes.
#35 | |
-alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | BRZ21 (01-21-2014) |
#36 |
Night Raid
Drives: '14 CBS BRZ
#37 |
I had this problem after installing my ground control coilovers and rear LCAs. It went away after a (very precise) alignment.
If you're still having trouble after an alignment then maybe something is wrong with the speed sensor, but make sure the toe and camber are even before you assume something else is broken. |
| The Following User Says Thank You to ubersoph For This Useful Post: | HATED1 (01-20-2014) |
#38 | |
Drives: 2013 GBS BRZ Limited
As others posted, it will not "void" the warranty. If you say: "I had these guys put coilovers on and they must have broken my speed sensors, will you replace them for free? " What do you imagine they will say? |
#39 | |
Night Raid
Drives: '14 CBS BRZ
#40 |
If you had this done at a shop they should be taking care of this without you needing to go to a dealership.
#42 |
| Door Unlocked dash light coming and going after installing subwoofer | tbertran | Electronics | Audio | NAV | Infotainment | 0 | 01-01-2014 11:22 PM |
| BEWARE when installing aftermarket tail lights, you must seal the area ! | Kayzer Soze | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 08-27-2013 02:52 PM |
| All RED interior dash lights and hvac ? | Mrqb22 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 06-05-2013 10:41 PM |
| Holy crap tail lights!! | raul | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 10-05-2012 08:11 PM |
| HELP!!! FR-S Shutdown all lights on the dash came on!!! | tric | Scion FR-S / Toyota 86 GT86 General Forum | 68 | 09-15-2012 03:57 PM |
