Old 01-26-2014, 05:02 PM   #155
BobRickel
If you have a problem with their offer just call an attorney. Their fees will usually be covered by the other guys insurance. I have an attorney friend who worked as an adjuster for State Farm for 7 years and as a fraud agent for Allstate for 6 and then decided to become an attorney. He tells me that they laugh about something call the 3 D's @ the insurance companies. DELAY/DENY/DISCOURAGE. The actuaries tell them that if you do this 42% of the people will give in and take their offers.
BobRickel is offline   Reply With Quote
Old 01-26-2014, 05:52 PM   #156
Dingle049
Drives: cruze
Did you ask the dealer what their hourly labor rate is? I know mechanical repair is usually close to 100/hr, but you were quoted at 42/hr by the adjuster, is that the same rate your dealer's body shop charges? Maybe its some sort of standard rate that I'm just unaware of
Dingle049 is offline   Reply With Quote
Old 01-26-2014, 06:14 PM   #157
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Could someone explain that graph?
Old 01-26-2014, 06:33 PM   #158
FRSure
Drives: Toyota
The rates are standard across all body shops.
And for the offer... There is really nothing I can do if it won't reach the 75%...
I found a link on the Internet, but still can't understand much.http://www.framefacts.com/HowItWorks.aspx
FRSure is offline   Reply With Quote
Old 01-26-2014, 06:46 PM   #159
Pickleahoy
Drives: 10 Series #1617
According to your link the machine can read accuracy to the millimeter so Im guessing that the numbers displayed are deviations in mm and which direction they are not to spec.
Anything other than 00 or OK means your shit is crooked. Now why there's a L and R reading per corner I dont quite get
Pickleahoy is offline   Reply With Quote
Old 01-27-2014, 03:05 PM   #160
Gearbanger
Gearbanger's Avatar
Drives: Lexus is300 celica gts
lol damn son.
Gearbanger is offline   Reply With Quote
Old 01-27-2014, 06:04 PM   #161
FRSure
Drives: Toyota
Update:
Called the Body Shop..
They said because my car is so new.. They don't even know the EXACT labor and the price of the parts. Call back tomorrow.
However, they did say that what they discovered right now so far is that they will have to replace sheet metal from almost middle of the car to the end of my car.
They will also use a frame straighter to meet OEM specification.
They also said there is buckling of the roof. (What exactly does that mean?) (Repairable they say)
Old 01-27-2014, 06:45 PM   #162
FRSure
Drives: Toyota
Also, just a few question. When they use a frame straightener, wouldn't the chassis be weakened? You're pulling on all side of the car. Sure, it meets OEM specification of length and height. But it won't be as strong as before when it crashes.. Because there is work done to the frame, wouldn't airbag deployment also be off as the airbags timing would be off.
In addition, the FRS is a unibody car. Once the crumple zone are damaged, they are no longer predictable how they will react during the next crash or accident.
Take a soda can for example, crush it, pull it back. Sure it's the same length and height, but it won't be strong anymore. It'll have ripple.
If I'm correct, the car will NEVER drive the same as before right?
Old 01-27-2014, 06:52 PM   #163
thill
I have had three cars involved in accidents that required significant work. All I can tell you is that none of those cars were the same afterwards. They looked really good, but little issues seemed to constantly be popping up and I am very leery of any insurance company fixing a car with any significant work done (which sounds like your car). I would wait and see what they come back with, but stand your ground if they still insist that the car can be repaired. Express your concerns and threaten to get a lawyer. I bet 90%+ of people out there never say a word and just go forward with the repair.
The Following User Says Thank You to thill For This Useful Post:
FRSure (01-27-2014)
Old 01-27-2014, 07:05 PM   #164
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Just let it go....
Old 01-27-2014, 07:15 PM   #165
dnieves
Drives: FR-S 10 Series
I had a car with less damage that no wheel alignment on earth could fix and not to mention the weird tire wear pattern. I would take it to the most expensive dealership possible, I don't trust a shop in bed with the insurance company only because I feel they are beholden to the insurance company for referrals/steady revenue stream.
dnieves is offline   Reply With Quote
Old 01-27-2014, 07:17 PM   #166
FRSure
Drives: Toyota
If I were to threaten with a lawyer but not get any... That'll make me look very pathetic.. And lawyers are expensive.
They keep insisting is repairable because it does not hit 75%..
The body shop I used is a certified Toyota body shop. (Dealer)
^ They will use New OEM Toyota Factory parts
The shop told me they will get a correct estimate after they check out the part prices and labor.
Old 01-27-2014, 07:31 PM   #167
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
Do they know the roof is aluminum? And replacing the whole back of the car sounds sketchy. You might want to get a second opinion on how safe this repair is.
Sent from my SCH-I545 using Tapatalk
Fett4Real is offline   Reply With Quote
Old 01-27-2014, 08:52 PM   #168
ericw2k
Man, I feel so sorry about this
I drive slow!
ericw2k is offline   Reply With Quote
My FRS Totaled.... FRS is down... jgonx213 Southern California 70 03-11-2014 01:42 PM
Sigh... I knew better! DOH! KONVERTER Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 09-04-2013 01:57 AM
sigh... another attempt jarviz Scion FR-S / Toyota 86 GT86 General Forum 10 10-05-2012 01:39 PM
I knew it was bound to happen....sigh calis5nest Off-Topic Lounge [WARNING: NO POLITICS] 70 08-20-2012 11:42 PM
First brz broken into...sigh zex CANADA 74 08-04-2012 06:17 PM
