#15 |
Drives: 2013 Asphalt FRS
Vid will be up later tonight. My tunner actually reduced the timing under 3.5k RPMs so there wold be less knock. Look at the top end though. With the last set up the car was loosing power at 7k. Now it holds HP strong till redline.
2013 Sion FRS
2014 Subaru WRX 2014 Subaru XV |
#16 |
Drives: 2013 Asphalt FR-S
Also the stock stuff has a slightly smaller ID than the aftermarket parts... larger dia = more volume.
~Namaste~ |
#17 | |
2013 Sion FRS
#18 |
blowhard
Drives: frs, project forester
Some people prefer smaller parts
| The Following 2 Users Say Thank You to utekineir For This Useful Post: | SDIAZ (03-08-2014), SKELLINGTON (01-22-2014) |
#19 |
2013 Sion FRS
#20 |
Add lightness!
Drives: 17' WRX
This probably is the case here since you can't easily turn up the boost to compensate for reduced back pressure or increased scavenging from a free flowing exhaust.
#21 |
boost is dependent on pulley size. Charger ftw.
2013 Sion FRS
#22 |
Add lightness!
Drives: 17' WRX
Not really that simple. If you unbolted your supercharger from the engine and just ran it into open air it would generate 0 boost. Likewise, changes to engine VE like reducing back pressure or improving scavenging will decrease boost pressure since a non-waste gated supercharge just pushes a fixed cfm.
| The Following User Says Thank You to industrial For This Useful Post: | jamesm (01-28-2014) |
#23 |
Mr. Cranky Pants
Drives: 2013 Argento FR-S
1 pull in July, 1 pull in January. In Portland, right? What is that, 30-35 degrees F difference in temp and a huge change in atmospheric moisture (humidity)?
I'd honestly like to see what they look like with weather correction. Good to see, but let's not start making conclusions just yet... |
#24 | |
![]() If you put a more free flowing exhaust or intake all you will be doing is changing the AFR's. In which case you can pull more power. Adding an exhaust to a charger doesn't make it generate more boost. Twinscrews work way differently then turbo's.
2013 Sion FRS
#25 | |
Add lightness!
Drives: 17' WRX
![]() Reread what I'm saying. If you open up the exhaust on a non-wastegated/clutched supercharger system like the innovate, you will LOSE psi but gain VE. That maybe why it seems like exhaust mods aren't worthwhile on these systems. You may have to add a smaller pulley to make up for the lost boost. I will not respond again here...I know where science isn't wanted. |
#26 | |||
I'm not disagreeing with you. Lol.
2013 Sion FRS
#27 |
Drives: FRS(sold), AP2, R35, FJC, ED9
how did you gut the stock header?
#28 |
| catted header or catted front pipe? | gabeg86 | Engine, Exhaust, Transmission | 28 | 10-13-2015 01:32 PM |
| Gains from aftermarket catted front pipe vs stock front pipe? | Vmax911 | Engine, Exhaust, Transmission | 4 | 01-20-2014 02:42 PM |
| FS: Tsudo header back exhaust w/catted front pipe | Opposed | Engine, Exhaust, Bolt-Ons | 4 | 11-19-2013 02:01 PM |
| Revworks UEL header + Nameless OP/DP combo | BRZPDX | Engine, Exhaust, Transmission | 5 | 10-11-2013 09:00 PM |
| P&L Catted headers and Nameless catted Front pipe. Also is this cricket noise? | Xdragonxb0i | Engine, Exhaust, Transmission | 23 | 04-24-2013 01:29 PM |
