#99 | |
Drives: Subaru BRZ Limited
| The Following User Says Thank You to Burrcold For This Useful Post: | Suberman (01-08-2014) |
#100 | |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
![]() I guess I just happened to meet my match with snow in my first winter season with the FRS. I think everybody will eventually. It's part of learning. I just didn't expect it to fail when my other FR cars of the past would've pulled their way through. Albeit, with a struggle. I definitely now know what this car is and isn't capable of. I'm not Tommi Makinen like you guys ![]() Other than the deep stuff, this car does well in winter. Not great but certainly adequate. Like with all FR cars, if provoked enough, your headlights will be pointing in the wrong direction.
#101 | |
Also the STI center differential is a combination (mechanical) limited-slip planetary gear type differential and (electronically controlled) continuously variable transfer clutch. The electronic aspect of it allows the torque split to be altered on the fly or locked as necessary.
2022 BRZ Build 2013 FR-S Build |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | Suberman (01-08-2014) |
#102 |
Drives: FR-S MT
Long time lurker on the forum- but I don't often post. Figured I'd add my two cents to the much debated winter experience.
I bought the FRS with the intention of getting a winter beater, but parking restrictions left me with out an additional parking space. Rather than store the car I decided to throw on a set of winter tires (Nokian Hakkapeliitta r2's) in stock size on the stock wheels. The car in my opinion has been fantastic to drive in the snow and surprisingly far exceeded my expectations- I wouldn't hesitate to drive it anywhere, and I don't. I live in Ottawa and we've had 110cm of snow in the past 2weeks- real winter, no problems. Cheers, ~jcam |
| The Following 4 Users Say Thank You to J-Cam For This Useful Post: |
#103 | |
Drives: 2018 Camry XSE V6
As others have said, deep snow is best handled by turning off all of the nannies; but, I have only realized that through trial and error (not because I am the Stig or Ari Vatenan). Even on ice traveling to Woodstock on Jan. 7th, the back end started to wag and I took the car's advice to slow down. Other cars and trucks are so isolated from the road, their drivers drove at inappropriate speeds. The FR-S certainly isn't perfect, but, I still prefer it over our Sienna. Again, this is an extreme winter, and not at all easy. Even the best of us will get stuck from time to time and certainly not without various profanities being uttered. I hope you stick with the FR-S and catch you at more local meets. |
#104 |
// how hard can it be?
Drives: 10 series frs : 6MT
Second winter so far with our FR-S. Asphalt has 16" i-pikes and the Series 10 is still in summer shoes (shutup, I know, got laid off end of Nov. and have been spending a lot of time at home) and so far, the Asphalt has been an absolutely champ and the Series 10 has been holding it's own. Sort of.
I've definitely found that recovery in a rwd is much more intuitive than in fwd or fwd-bias awd, so trust in your ability (or practice skidding/sliding out and then trust) and trust in your car. To be honest, if I was going to drop cash on another car, I would keep the fr-s as my winter. It takes getting used to but I love that slow speed drift around corners, lol. I vote get through this winter first (bearing in mind that it's been kind of a weird one!) before deciding, and if it's really that awful, perhaps spend a few hundred on a winter beater and store your fr-s over the winter? |
#105 |
Drives: Subaru BRZ Sport Tech Satin White
I had a good drive today now things are settling down out here. The BRZ romped up my icy slushy alley which is very steep. If I can drive up my alley I can drive anywhere in this city.
I have noticed that the lively energetic feel of this car that makes it so exciting to drive on bare pavement encourages the wrong driving style in winter. I tried driving ludicrously slowly away from the curb, out of the curb side drift, expecting to get stuck and found to the contrary this car grips quite effectively if you drive more slowly and steadily than you might normally in this car. I am beginning to think that the Torsen provides better overall low grip performance if you take it slower and let the Torsen do the work. Lateral stability is still crazy but again if you back off the driving style a bit, to say 6/10 instead of 8/10 the chassis behaves much better. The TC also works well to keep the car moving forward in a straight line. I particularly like the TC operation with it switched off, it cuts back in if drive wheel speeds differ too greatly. I love this car in summer time. I'm beginning to like it more in winter now I'm understanding how it works a little better. |
| The Following User Says Thank You to Suberman For This Useful Post: | Burrcold (01-10-2014) |
#106 |
And today we have warm and wet snow on top of warm hard pack, insufficient sand and the BRZ is up to its old tricks.
The challenge is metering out exactly the right amount of torque to the drive wheels which is remarkably difficult to do. At one point I was virtually stationary with the TC going nuts and there was literally nothing I could do to improve things. Parked it. Will take my awd Jaguar back to the office this afternoon. Tough winter but the car should be more capable than it is. |
#107 |
Canadian FR-S Member
Drives: FR-S '10 Series'
This is just a thought because I have an AT. The snow button, with nannies off helps a lot, basically just doesn't allow you to run in 1st gear. Is it possible to just always start in 2nd with a MT?
#108 | |
| The Following User Says Thank You to wparsons For This Useful Post: | Dipstik-sportech (01-13-2014) |
#109 | |
| The Following User Says Thank You to Burrcold For This Useful Post: | Dipstik-sportech (01-13-2014) |
#110 |
I was thinking that starting the manual shift car in second gear and using very slow throttle inputs is essentially how the winter button on the auto works. It helps but in really slippery stuff this car really isn't up to the job. Weird really as a good chassis should be a good chassis regardless of grip levels.
#111 | |
However, the "evil little car and the good little car" is an apt description of its behaviour on winter roads. It's been a loooong time since I got stuck in any vehicle. |
| The Following User Says Thank You to Suberman For This Useful Post: | hmong337 (01-14-2014) |
#112 | |
Emperor JDM
I guess you and I with our lifetime of winter driving just ain't good enough for this car because it's impossible to get it stuck unless you suck (like you and me :-)) Anyways, I actually went out and got me an emergency shovel just in case. I'm not pro like everybody here.
| Tags |
| attention whore, can't drive in snow, intellectual masturbation, just won't quit, suberman chronicles xiv, why people hate laywers |
| Selling an AZ car to someone in CA | tracerit | Southwest | 0 | 10-27-2013 01:39 AM |
| Selling AEM intake | swift996 | Mid-Atlantic | 0 | 07-08-2013 11:17 AM |
| Why are they not selling? | roadtrip1098 | New England | 22 | 01-08-2013 12:46 AM |
| Selling my BRZ | Epictetus | Northwest | 4 | 11-14-2012 08:59 PM |
| Selling FRS in Oklahoma | Blckcobra | Dealer Cars | 8 | 05-19-2012 09:41 PM |
