#15 | |
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
if you want to do such a thing, do it... but don't spread it out like it's a good advice.... this car is easy to handle, and putting more weight at the rear will only let you believe that you control it more... |
#16 | |
Drives: 2013 GBS BRZ Limited
If you want to help the car in the snow by adding weight,put it in the back seat. |
#17 | |
Señor Member
1974 TA22 Celica
2013 86 GT |
#18 | |
Drives: Lightening Red BRZ Ltd.
Even with pressing the TC button down for 3+ seconds, the electronic nannies are still there. I've held the TC button down for 3 second and I still electronic intervention once the revs jumped over 1500rpm and you felt the rear brakes clamp down- causing me to nearly shall and cease momentum. I just hate the fact that I have to fight with this system when I am trying to do other things. |
| The Following User Says Thank You to himbo For This Useful Post: | enjoyminutemaid (01-06-2014) |
#19 |
Then you did it wrong. Start with everything on the way it is when you turn on the car then hold the TC button down until two lights light up on the cluster. If you do it right you can slide and spin as much as you want and it won't turn off until you either push the TC button again or turn off the car.
With the TC/VSC disabled properly (no pedal dance) the only electronic nannies left on are EBFD and ABS
#20 |
Hicas Thread Basher
snap faster than let's say, a S14 or any rwd with 3000lbs or more!
the more weight you put at the rear the harder it will be to recover. each time you tink (and you have) more traction at the rear because of the extra weight, you will have more difficulty to bring it back once you lose it (just as stugray said, polar inertia) it is a car easy to correct, and to handle in the snow... i just personally think that it's better to gain experience with the way it handle, than adding weight at the back... (and i'm from Quebec... if anyone was wondering... but i assume my english already told ya all!) |
| The Following User Says Thank You to Walla Walla For This Useful Post: | Turdinator (01-06-2014) |
#21 |
Drives: Pavement MT GR86
The car is 55 front 45 rear split ...adding 120 lbs to the rear won't even make it neutral much less 70's porche style.
Yes putting weight in the back seat would keep the balance but you're not affecting it that much.
GR86 MT premium
#22 |
Also unless you have no throttle control or your car is broken you should use "sport mode" on the TC not full off. Don't know anything about the autos and the extra crap they have.
GR86 MT premium
#23 |
/dev/null
Drives: Uphill
I drive on snow and ice on a regular basis, and I have the following comments:
1. Sandbags in the back only helps if you have problems getting up a steep hill (and only on RWD cars, of course). I avoid messing with the weight distribution if I can, especially on such a beautifully balanced car as this. 2. I only turn off TC/VDC when having fun in safe places, never on public roads. It may help if you're stuck in a ditch or something. I haven't been in a pickle like that with my GT86 yet so I don't know if turning off the TC will make much difference. Hopefully, I'll never find out, because if I'm that stuck I will most likely have damaged my car severely. 3. WINTER TIRES. Get good ones. The difference in grip is HUGE. If you expect to drive on ice a lot, get studded winter tires. Otherwise, studless are better. I got Nokian Hakkapeliitta R2 215/55R16 studless and they are serving me well. I have no sympathy and no respect for anyone driving on winter roads with inferior tires.
#24 | |
It's well documented that the the electronic nannies DO NOT shut off after hitting the TC button for 3 seconds. Seem like the pedal dance is the only way to remedy this. I was wondering if any tuners can "program" this pedal dance sequence when you hit the TC button to truly turn off the nannies. So once again - you CAN NOT deactivate the nannies unless you do the pedal dance. Which again goes back to my first question - if it was possible to "tune" the pedal dance at the press of a button. Last edited by himbo; 01-06-2014 at 12:06 PM. |
#25 |
^^ Wrong, wrong, wrong. The ONLY thing that the pedal dance disables that turning the TC/VSC off doesn't do is the EBFD.
If you properly disabled TC/VSC and you're still getting brakes applied it's because you have zero traction on one wheel and the EBFD is applying a touch of brake stop the diff from unloading power to the wheel with zero traction.
#26 |
Drives: SSM LT MT BRZ
@wparsons please shut up you are not well informed on this your posts even self contradict
Ebfd is a Nannie, it is used to prevent spins, and yes you can do donuts with the 3. Second hold but there is a level at which it still steps in and shuts down the fun check the track experiences all over this forum |
#27 | |
Are you talking about it going into "ice mode" and locking up the rear brakes? That's the EBFD at work. EBFD is Electronic Brake Force Distribution. If your foot isn't on the brake, it isn't coming into play at all. If you're coasting or on the gas it has no effect. Now if you're trying to trail brake too much or are running staggered pad compounds you might have issues, but ONLY under braking. Sounds like you're the one that isn't well informed.
#28 |
Drives: Attitude
| How to disable the 120 kph warning - UAE | captaindubai | ASIA | 25 | 05-21-2023 04:54 PM |
| How to disable DRL in FRS | whitefrs | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 12-13-2016 03:11 PM |
| Dealer won't disable Ecu features? | DBacon1052 | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 01-09-2014 09:30 AM |
| Dealer refusing to disable DRL's? | zaptorque | Scion FR-S / Toyota 86 GT86 General Forum | 64 | 09-17-2013 05:20 PM |
| Is there a way to disable the immobilizer? | schtebie | Issues | Warranty | Recalls / TSB | 5 | 09-22-2012 07:09 PM |
