#43 |
Drives: '13 BRZ Ltd WRB
#44 | |
Add lightness!
Drives: 17' WRX
| The Following User Says Thank You to industrial For This Useful Post: | SirBrass (03-20-2014) |
#45 | |
Drives: 2008 Civic Si
It's INCREDIBLY complex and you could spend ages finding the right setup. But i'm sorry, you won't find ANY race car without an equal length header, and there's damn good reasons for that you will find in any book explaining why. But the main one? Testing methodology (explained a bit below). You can't tune a header for a specific rpm range (or broad rpm range) when you make all the piping lengths different. When you speak of UEL vs EL headers you will ALWAYS be stuck with a million threads and posts turning up before you find anything actually explaining the reasoning behind it. But if you must know? The unequal length header will make some cylinders better at scavenging than others, while others are worse. And how do you know? You don't. The gain as a whole might be better, but it can always be better with an EL header. Scavenging is all about piping length to time your pressure wave to suck in the next cylinders air (valve overlap) with negative pressure to increase VE in an rpm range that you want. This gets so insanely complex when you bring a variable cam angle into play that it could take ages to find the right combo. You realize that there are aftermarket headers with anti reversion chambers in specific spots to prevent reversion that affects power in specific rpm ranges poorly? On the ones i'm currently thinking of they are there to prevent poor reversion characteristics at high rpms. Otherwise, the pulses are bouncing back at valve overlap events at those specific rpms, resulting in lower volumetric efficiency. tl;dr: exhaust tuning is SUPER complex and there's no answer to everything, but there's a reason they don't make UEL's when they actually care about making power. |
#46 |
Drives: DGM BRZ Limited
Why all this talk of reversion in an NA thread? The stock cams aren't going to have overlap values high enough to experience reversion. It would be rare to experience it.
I suppose it could be possible if scavenging really was that terrible, or if the exhaust was poorly engineered. UEL outperforming an EL is nearly unheard of. Everyone sees EL as the superior because it allows you to get the best scavenging when things are perfectly symmetrical. But as we all know here, an EL can still suffer from scavenging issues if pipe diameter, collector, or bends are not completely ideal. I'm going to check out the build thread now. |
#47 |
Coheed: variable cam timing should allow some overlap and to be tunable at that!
This is the beauty of it, there's zero overlap when you have the cams at 0 cam angle so idle and low rpms are smooth and make torque, but once you get to higher rpms you increase those cam angles allowing some overlap to increase horsepower. |
#48 |
Add lightness!
Drives: 17' WRX
While I appreciate a good technical discussion, it's essentially meaningless because we are generally saying the same thing.
I think you are overstating the importance of el vs Uel runners in a header design. Things like the actual runner lengths (which affects velocity, heat, harmonics) and proper merge collectors are far more important than just ensuring all the exhaust pipes are the same length in my opinion. If all things are the same, el will be better than Uel. But with so many variables this isn't the case at all. |
#49 | |
Once you find the proper piping length for the car it doesn't change from cylinder to cylinder. Hence... equal length. |
#50 |
Fixed that for ya.
| The Following User Says Thank You to 2point0 For This Useful Post: | kuhlka (01-16-2014) |
#51 |
lmao, if you say so.
#52 |
Drives: 2013 FR-S Argento
#53 |
I hear you there. My previous cars were a WRX and an STi, so I guess I'm a bit biased.
It's good that we don't all like the same things. Otherwise, there'd be no uniqueness.
| The Following User Says Thank You to 2point0 For This Useful Post: | bfrank1972 (01-09-2014) |
#54 |
[ame="http://www.youtube.com/watch?v=drzwLPYPwXs"]2007 Civic Si Greddy Turbo - YouTube[/ame]
log manifold turbo civic si. Sounds like... what's that?
#55 | |
Add lightness!
Drives: 17' WRX
And Uel sounds much better on a 4 banger. That alone is worth the 1% difference in power between the two.
#56 | |
as for the endless uel/el debate, it's really simple: the ideal header design probably has equal length runners, certainly so if we're talking about a turbo manifold. many people have managed to package an equal-length header into the bay, and the 'best power producing' header around by far now is equal length (nameless). uel's also make great power. really if you're buying a header you're probably staying na, and if that's the case i'd be more concerned with the sound preference, because you're not going to be making much power regardless of what header you buy. s/c guys might put a bit more thought into it, but even then i doubt there's much between them in real life. |
| The Following 2 Users Say Thank You to jamesm For This Useful Post: | bfrank1972 (01-09-2014), w00t692 (01-10-2014) |
| My SWP BRZ: light tuned- stay tuned! | Badaab | Member's Car Journals | 28 | 09-06-2013 01:35 AM |
| Plastic Moisture barrier replacement | AL008 | Electronics | Audio | NAV | Infotainment | 1 | 06-19-2013 09:48 PM |
| Scion FR-S / FT-86 / Subaru BRZ Specs and Options. 200hp / 151 lb-ft tq | Nardi330 | Scion FR-S / Toyota 86 GT86 General Forum | 510 | 09-03-2012 07:39 AM |
| 200hp / 2700lbs - Really? | Rickster | Scion FR-S / Toyota 86 GT86 General Forum | 385 | 04-18-2011 03:47 PM |
