#253 | |
Drives: AE86, 2x GT86, TE27
Edit - It would be interested to hear your feedback from first removing the abs fuse, and finding your new braking points / lockup points, and then reinstalling the fuse and seeing if these points are the same. I don't blieve they will be. |
#254 | |
| The Following User Says Thank You to strat61caster For This Useful Post: | diss7 (01-08-2014) |
#255 | |
Drives: 2013 FRS / 2013 427 Vert
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#256 | |
It could be the auto LSD feature, or EBD, both still work using the setting that you are. Without the auto LSD, you'll feel the car 'spring' out of corners more. Its hard to describe. Basically, its not dragging the rear inside wheel. |
#257 |
Drives: 2013 GBS BRZ Limited
WHY?? what could that possibly accomplish except make you NOT stop when you are already stopping. Use logic. There is absolutely zero reason for the ABS to do anything unless it detects wheel slip.
#258 | |
When you mentioned that you can feel braking in cornering that could be the ebd. If you can eliminate ebd and abs you will be free of the aids. ![]() Disabling abs on a dd? Not for me. I have professional drivers training and first thing you learn is emergency braking. Find, know, and learn what lock up feels like and you will never need to rely on ABS. |
| The Following User Says Thank You to Byebye For This Useful Post: | enwave (01-09-2014) |
#259 | |
It doesnt change the fact that it does do it. My assumption was that it is seen as a precursor to lockup, so it chimes in early. But I don't know the reasoning, I didn't design the system. |
#261 | |
Why would the system release the brakes 'as a precusor to lockup'? Logic (and the engineer in me) says this is not possible. If it IS doing what you say, then it sounds like a bug/flaw in the system. That is kind of like a smoke detector that bursts into flames if it detects a fire. |
| The Following 2 Users Say Thank You to stugray For This Useful Post: | bestwheelbase (01-08-2014), enwave (01-09-2014) |
#262 | |
But again does turning of vsc disabled ebd? |
#263 | |
#264 |
#265 | |
If you logged x,y,z accels (on the phone and car if available) & all 4 wheel slip rates, then you could do some test runs. If the ABS kicks in before any wheel slip and the G-force reaches a repeatable value, then that would show G-force alone can engage ABS. If however: regardless of G-force the ABS kicks in at a particular wheel slip value, then we would show G-force is not used to engage ABS. I'll have to look through the list of PIDs default in the Torque app. I dont recall seeing wheel slip or velocity in the list. If we knew the custom PIDs they could be requested. I'll look into it. |
| The Following User Says Thank You to stugray For This Useful Post: | strat61caster (01-09-2014) |
#266 |
Drives: 1985 P-Type
What's the story about the damaged car in post 181?
| Subaru BRZ tS Driving Impressions (Japanese) | Gaiakai | BRZ Photos, Videos, Wallpapers, Gallery Forum | 7 | 09-13-2013 02:44 PM |
| Electronic Driving Aids | trackmagic | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 03-07-2013 08:45 PM |
| Initial Driving Impressions - BRZ Limited 6MT | ShoNUFF | BRZ First-Gen (2012+) -- General Topics | 17 | 12-21-2012 03:09 AM |
| FR-S Driving impressions | Guaruja | Scion FR-S / Toyota 86 GT86 General Forum | 30 | 02-29-2012 06:20 PM |
| Kota Sasaki Subaru BRZ Driving Impressions | illmatic | BRZ Photos, Videos, Wallpapers, Gallery Forum | 31 | 01-14-2012 01:24 PM |
