#239 | |
It's great that a race team told you this, but I'd love to see ANY reliable evidence of this being true. That is, an accelerometer used as a hard cap to ABS. Link to those tuners and software developers you mentioned? Here's a manual that seems to focus on Toyota systems. http://www.autoshop101.com/forms/brake09.pdf Of note is probably page 10/23 (p. 118) which calls out a 'deceleration sensor' used for AWD systems and determining road conditions, likely snow or gravel vs. smooth surface. The rest of the document focuses on wheel speed sensors being the primary input for ABS, you can see it in the wiring diagrams. Unless you start coming up with evidence you're just spouting crap on the internet. As an aside, I really wish SAE articles didn't cost like $24 a pop, should have downloaded a fuckton when I was in school. Edit: realized you never credited an engineer. I know all too well that racers usually find the fastest way around the track but they don't always get the science behind it right.
| The Following User Says Thank You to strat61caster For This Useful Post: | bestwheelbase (01-08-2014) |
#240 | |
Drives: AE86, 2x GT86, TE27
I started this thread to provide my feedback/impressions of what removing the aids achieve. If you need more data to satisfy your own doubts, I've stated numerous times how you can do it. If you can't, thats fine. But it doesn't then become my responsibility to provide this for you. |
#241 |
Scrape Master
Drives: Goal: Oldest FRS State Side
There is no way the abs uses a g force sensor. How will it know if you are on ice or snow.
Sent from my XT1060 using Tapatalk |
| The Following User Says Thank You to WolfsFang For This Useful Post: | strat61caster (01-08-2014) |
#242 | |
#243 | |
If works to G or slip. If you're on ice or snow, its going to be slip that triggers it. If you are on a dry road, with stickier tyres, you will reach the g limit before lockup, this is when its the g that is activiating the ABS. |
#244 | |
Scrape Master
#245 |
Drives: 2014 Scion FR-S ハチ
This thread is like the Energizer Bunny. Going, going, going...
Sent from my SGH-T999 using Tapatalk
#246 | |
That headunit though...
Drives: 2013 Subaru BRZ Limited SSM
Disabled the driving aids. Here are my impressions.
I think the recent posts in this thread have all been pretty civil and full of general curiosity. We're no longer talking about just @diss7 and instead learning about how ABS is working on our cars. I know I'm definitely not trying to change his mind, just trying to learn. Far from definitive, but http://www.toyota.com/esq/glossary.html mentions g-sensors are on cars with VSC, but are tied to VSC and sort of implies they aren't part of the ABS system. But we may never know without talking to someone at Toyota/Subaru directly, or seeing some manuals/techdocs. Really interesting stuff here. That definition of VSC and @diss7 experience makes me lean toward g-sensors affecting ABS, which makes me feel even more understanding of disabling it. Sent from my iPhone using Tapatalk
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300 Eibach Pro-Kit + Michelin PSS (stock size) |
| The Following 3 Users Say Thank You to enwave For This Useful Post: |
#247 |
Drives: 2013 asphalt frs
No aids here! Daily driven for 16 years. While disabling everything isn't the best idea, it's not exactly a death sentence either |
| The Following User Says Thank You to sanmarcosfrs For This Useful Post: | enwave (01-08-2014) |
#248 | |
Are you talking about bald road tyres, or motorsport slicks. Were they even warmed up? It's contrary to what I have experienced if this is legitimate. |
#249 | |
Scrape Master
#250 | |
My issue is your describing a system in a way that goes against everything I know to be true and people are believing you without asking for evidence besides your butt sensor. I'm curious though how you think this works, the wheel speed sensors make sense: -wheel speed drops very quickly -wheel is locked up -release brake pressure -wheel unlocks, speed increases -reapply pressure -repeat What happens when a the accelerometer trips? -max acceleration detected -release brake pressure -accleration drops -reapply brake pressure when acceleration drops below braking level? In my experience I would not trust an accelerometer to regulate my brake system, they're finicky even when set up properly and to get the kind of fidelity, consistency, and longevity out of a unit you'd have to spend a considerable amount of money, a far cry from the LED system outlined in the manual I posted. Every technical paper I've found focuses on wheel speed sensors, this goes back to the 60's, any mention of accelerometers is meant for acquiring road conditions (ice vs. tarmac as mentioned previously) and nothing more. http://papers.sae.org/2000-05-0236/ http://papers.sae.org/2002-01-2229/ http://papers.sae.org/2008-01-2985/ Thanks for the discussion, I never bothered to look up wheel speed sensors until today, you learn something new! Again, I'd love to see some evidence of an ABS system utilizing accelerometers for anything other than determining road conditions.
#251 |
Drives: 2013 FRS / 2013 427 Vert
I have 4 track days running Khumo V710's (30 UTQG) HP+ fronts HPS rears. I use the 5 sec Track Off (because I can never remember the pedal dance sequence or I'm late as usual for a session). Two heavy braking points 130-70 and 105-45 and I have not felt the slightest bit of ABS modulation. In my AMG the ABS was so pronounced the vibration could be seen in go pro videos. This car however had DTC 70 all around and was braking from 155 into the first turn.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
| The Following 3 Users Say Thank You to Deep Six For This Useful Post: |
#252 | ||
Thats a semi slick not a full slick. Just driving around town, it will almost certainly not be at optimium temperature. I also note that you appear to live in quite a cold state. Your ride height suggestes less than ideal alignment, with respect to grip under braking. If you're driving around the street on those tyres, you almost certainly have them at too high a tyre pressure, which will drastically affect their performance. Finally, a quick stap on the brakes as you describe could indeed lock a cold, poorly aligned semi slick. Go do some big braking off the front straight of your local race track, with 30psi warm (so probably 24psi cold depending on local conditions and your driving style) with a known alignment (you may already have this) and see if the results are the same. Try it with the fuse installed, and with it pulled. Quote:
I'd really like it if someone decided to try to replicate my findings, independantly from myself. |
| The Following 2 Users Say Thank You to diss7 For This Useful Post: | enwave (01-09-2014), strat61caster (01-08-2014) |
| Subaru BRZ tS Driving Impressions (Japanese) | Gaiakai | BRZ Photos, Videos, Wallpapers, Gallery Forum | 7 | 09-13-2013 02:44 PM |
| Electronic Driving Aids | trackmagic | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 03-07-2013 08:45 PM |
| Initial Driving Impressions - BRZ Limited 6MT | ShoNUFF | BRZ First-Gen (2012+) -- General Topics | 17 | 12-21-2012 03:09 AM |
| FR-S Driving impressions | Guaruja | Scion FR-S / Toyota 86 GT86 General Forum | 30 | 02-29-2012 06:20 PM |
| Kota Sasaki Subaru BRZ Driving Impressions | illmatic | BRZ Photos, Videos, Wallpapers, Gallery Forum | 31 | 01-14-2012 01:24 PM |
