Old 01-07-2014, 09:17 PM   #71
Jason@DSG
Jason@DSG's Avatar
Drives: 1997 Eagle Talon TSi AWD
I have 9.0:1 @ 30psi with boost on at 3,050rpm making 500whp in daily driver.
I'm also not saying everyone has to run 9.0:1 here, I was using that as an example. But 12.5 is way too high to make safe power is the point. 10.5 would be good IMO, 9 for very high boost.
The pistons are customizable in both diameter as compression. I'm just trying to prove a point that high compression with a boosted engine on pump gas is a recipe for disaster. Trust me, I've built many engines for this reason over the years.
So to stop the back and forth:
CP and JE pistons are now available to run lower than stock compression and with the addition of also available Darton Sleeves, up to 90mm possible
Forged rods from BC available in both I as H beam
Lowering the compression will allow safer and higher boost as the OEM compression at 12.5 doesn't have much room to play with
Jason@DSG is offline   Reply With Quote
Old 01-07-2014, 09:20 PM   #72
diss7
Drives: AE86, 2x GT86, TE27
Also making a point of mentioning that lower compression effect response, driveability, spool, and you'll need more boost to make the same power.
diss7 is offline   Reply With Quote
The Following 2 Users Say Thank You to diss7 For This Useful Post:
FreshFRS (01-07-2014), wparsons (01-08-2014)
Old 01-07-2014, 09:23 PM   #73
Jason@DSG
Jason@DSG's Avatar
Originally Posted by diss7 View Post
Settle down guy.
No one is saying 12.5CR is okay for crazy power.
9.0CR is ideal if running CRAZY boost, for CRAZY power. Like the examples you have listed above. But is this really your target audience? No of course not. Anyone with pockets that deep isn't getting off the shelf parts.
Your target market just selling pistions and rods is to people trying to get a built motor on the cheap. Maybe 400 - 500whp. They're not R35 owners, or 1600whp owners.
Set whatever CR you want, its your business. Just don't expect to put out information on a public forum, then get butt hurt when you get differing opinions.
Not butt hurt bud, just don't want people chiming in with opinions that can mislead other people.
I even clarified in my original post that I was using those compression and boost levels as theoretical and as reference.
I don't recommend 9.0:1 on this car (unless for a high hp/high boost application). I think 10 or 10.5 would be good and allow the boost to be ramped up/not affect drivability or spool
The only good thing about maybe going lower is keeping the option open to big after and only suffering a bit of lag when not in boost in the meantime
Good luck to all, no hard feelings! Just want to get the info out and make sure guys who may not know, make the right decision with proper info
Cheers!
J
Old 01-07-2014, 09:28 PM   #74
diss7
My (and others) intention was not to mislead anyone. Opposite infact. We were putting out the information about the negative aspects of the trade off that is lowering your static compression.
I still dont like the "I think this is ideal and it won't affect driveability" They're generic comments.
Lowering the comp a little bit, will affect things a little. Lowering it a lot, will affect them a lot.
Edit - although I actually agree that 10.5CR would be a good starting point for a 400whp FA20 build on pump. But it may turn out that it could've been 11.0, or 11.5. Only time will tell, via trial and error.
Old 01-07-2014, 09:32 PM   #75
Jason@DSG
Jason@DSG's Avatar
10.5 on a boosted application won't make a huge difference in drivability, especially with a smaller quick spooling turbo.
9.0 would make a difference yes, it would drive like my car laggy at 2000, but I have a medium sized turbo and spools very quickly (it's also ported with a 3" non anti-lag inlet to really emphasize spool). So I barely notice anyway.
Old 01-07-2014, 09:32 PM   #76
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
this was exactly my intention.
FreshFRS is offline   Reply With Quote
The Following User Says Thank You to FreshFRS For This Useful Post:
Jason@DSG (01-07-2014)
Old 01-07-2014, 09:37 PM   #77
diss7
Yes, but you're missing the point. Saying it will make no difference, and saying it wont make a huge difference are two different things.
Also, seeing as you have changed your mind about what CR is ideal, you should edit Post 7.
The Following User Says Thank You to diss7 For This Useful Post:
Old 01-07-2014, 09:38 PM   #78
Jason@DSG
Jason@DSG's Avatar
Same here. I was just putting an explanation out there to those who may not know about the effects of lower lowering compression for a boosted application, especially on a non-factory turbocharged engine.
I appreciate everyone's input, I think we got off track and we're working together for the greater good of the info on here. One of those we're all saying the same thing in a different way lol
Sorry if things seemed overly direct, wasn't my intention. Hopefully everyone can take away good info from here as some bigger power builds start happening!
Old 01-07-2014, 09:41 PM   #79
Jason@DSG
Jason@DSG's Avatar
Good call, I added for big boost applications. Thanks for spotting that
The Following User Says Thank You to Jason@DSG For This Useful Post:
diss7 (01-07-2014)
Old 01-07-2014, 09:43 PM   #80
diss7
Admitidly, I get a bit defensive when I feel that someone is leaving out information that could be seen negaitively, and only focusing on the positives. Particularly when this is a vendor.
But agree, no hard feelings at all. Just trying to keep all points discussed.
Old 01-07-2014, 09:47 PM   #81
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
nah no worries everything sorted itself, and hey directness is usually the best way to get things across on the interwebs.
Old 01-07-2014, 09:47 PM   #82
Jason@DSG
Jason@DSG's Avatar
I appreciate it very much! Always good to get the info out, I think I missed out a few things but we definitely went over it here. I'll take care of revising my first post on here to recap everything we talked about for easier access. I'm sure very few people will get passed page 2 unfortunately haha
Cheers guys, thanks for the valuable input @diss7 @FreshFRS
The Following 3 Users Say Thank You to Jason@DSG For This Useful Post:
diss7 (01-07-2014), FreshFRS (01-07-2014), Sportsguy83 (01-08-2014)
Old 01-07-2014, 09:49 PM   #83
diss7
Thats why porn sites do so well.
Jason@DSG (01-07-2014), Sportsguy83 (01-08-2014)
Old 01-07-2014, 09:50 PM   #84
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Aint that the truth!
TESTING WATERS: 18x10 MATTE BLUE XD9 mr. slim Wheels and Tires 8 10-18-2013 10:31 PM
Testing Waters: Stivo Wing in asphalt gray DarkCard Exterior Parts (Aero, Lighting, Etc.) 3 10-08-2013 01:49 PM
Testing Waters - Ful LED changeover $105($109 With Switchbacks for FRS) eljefe Interior Parts (Incl. Lighting) 11 08-09-2013 03:23 AM
