86WORX
Old 12-31-2013, 03:20 PM   #15
spark elusive
Drives: DGM BRZ
Originally Posted by MethBear View Post
*Update*
Got her back from the dealer, for some reason the CEL was "off" when the tech looked at it even though I was on when I brought it in. Anyway, they did a computer check and noted in the history that there was error code, referring to a "cylinder 1-coil malfunction". so they gave it back to me after they reset the CEL and everything and it seems to drive just fine. Soooo all for naught I guess. Still its good to have her home
Just an FYI, the reason the CEL was off when the tech looked at it is because the car (this goes for almost all modern vehicles) goes through a series of tests on routine intervals. When a problem is found with a sensor the CEL comes on and a code is logged. If after a set period of time the sensor is no longer reporting the problem the CEL will turn itself off. The code will still be logged which is why the tech was able to see why it was on in the first place.
I would continue to monitor the problem, but it sounds to me as if the "jolting" is unrelated to the CEL.
Did they take the car out for a test drive and where they able to reproduce the problem?
spark elusive is offline   Reply With Quote
Old 01-03-2014, 04:01 PM   #16
Wheelsoffracing
Wheelsoffracing's Avatar
Drives: 2013 Firestorm FR-S
I too have noticed a "thunk", just a few times, when the transmission downshifts into first. I thought maybe I was imagining this.
Wheelsoffracing is offline   Reply With Quote
frs, jolt, shifter
Subtle rear diffuers, what's out there? wparsons Cosmetic Modification (Interior/Exterior/Lighting) 12 10-11-2013 07:43 PM
Subtle Polyurethane Lip for FRS/86? DriftEightSix Cosmetic Modification (Interior/Exterior/Lighting) 32 09-23-2013 06:41 PM
Subtle Lip Spoiler - where is it? DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 44 10-12-2012 03:18 PM
MT Shifting n8dog11914 Engine, Exhaust, Transmission 4 08-28-2012 04:28 PM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 06:09 PM
