#100 | |
Set the shift light at 3500 RPM for break-in, but haven't changed it since. On a side note, we put over 100 miles on track yesterday.
| The Following User Says Thank You to CSG David For This Useful Post: | B L U E S L A T E (12-29-2013) |
#101 |
Grip>Slip
#102 | |
There isn't much to gain from fast shifts, other than accelerated wear for a minor drop in lap times. Learning to shift properly without mashing on the gas also improves driving smoothness. In fact, Mike's driving has improved dramatically since we got CSG BRZ 1.0. |
#103 |
Drives: 2013 Subaru BRZ Sport Tech
I recently saw that ECUTek has some features on their tune that allow you to keep the throttle down while shifting, would this hurt the DI seals?
Performance Parts: Innovate Motorsports Supercharger, Mishimoto Oil Cooler, Borla UEL Header, Perrin Cold Air Intake, Perrin Cat Back Exhaust, Perrin Crank Pulley, Perrin Rear Shifter Bushing, Perrin Transmission Bushing, Perrin Master Cylinder Brace, Billet Pro Short Shifter. Handling Parts: Perrin Control Arm Braces, Perrin PSRS Offset Steering System, Perrin 22mm Front & 22mm Rear Sway Bars, Perrin Spherical Rear Endlinks
#104 | |
#105 |
Drives: Something fun.
How long you expect the stock clutch to last? Street and mild track driving?
Reaaaaaaaaaaaaaaaaaaaaaally interested in this once I get my car out of storage in March(I cry myself to sleep every night, until I remember that my Yaris outside getting eaten by salt while my BRZ is tucked away in a heated garage). |
| The Following User Says Thank You to Skyllz For This Useful Post: | Calum (12-30-2013) |
#106 | |
Drives: '20 Hakone 86
It's just that its a $5,000 modification and from that video, it doesn't APPEAR to be that much of a difference through the first couple gears. Hopefully somebody does a video where they go all out through the gears. I don't drag race or anything either but with a bit of a launch and more expedited shifting, I think the difference between stock and this kit would be more apparent.
#107 |
Drives: 2013 Hot Lava FR-S 6 MT
If you were looking for just straight line speed you'd have to have a built engine or a swap really ...
On the track, you are going to spend most of your time in 3rd and 4th gear at 5k plus rpms ... downshifting to 2nd more rarely and hitting 5th gear if the track has some decent straights ... so the power band for Superchargers or Turbos works out nicely ... You are likely to be in a nice boost level all the way around the track .... The advantage of the supercharger is the near immediate addition of increased power - albeit in a less dramatic fashion than a turbo. It's a predictable application of power, where as flooring a spooled up turbo can have you sideways before you know it lol. The current superchargers all seem to stay within what seems to be a level of power the stock engine internals can handle. The clutch might not handle 280hp or more for any length of time. There's also a concern at that power level of the rear axles failing especially if you are lowered significantly ... 5k is a lot of money ... agreed ... But adding 80 to 100 HP to this car and its low weight makes a really quick car in the turns ... Sent from my SAMSUNG-SGH-I337 using Tapatalk
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
#108 | |
Drives: 2016 STi DGM
http://www.ft86club.com/forums/showp...&postcount=180
-2014 SSM BRZ MT
#109 | |
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
#110 | |
#111 | ||
Drives: Attitude
#112 |
The dyno pasted in this thread showed 70 HP gain on a carb tune ... there's more there than 60 HP ....
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Drift-Office : Jackson Racing Supercharger Installed! (Tune Tommorow!) | Drift-Office | Forced Induction | 164 | 06-20-2014 01:43 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
