#57 |
Drives: Attitude
#58 | |
Typically with a turbo car, you simultaneously increase boost while adding timing with E85. With the supercharged car, you're not increasing boost, only adding timing. |
#59 |
Driving Coach
Which engine oil cooler kit are you guys going with for track usage? I'm still weary of my Perrin OC kit fitting without modification. I also want to see pics of an engine OC and Rotrex OC mounted side by side behind the IC
#60 | |
![]() It'll be a all-in-one radiator oil-to-water oil cooler combo. We believe a space-efficient solution will be key with many FI setups out there. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | ATL BRZ (12-27-2013) |
#61 | |
Drives: 2013 FR-S Ultramarine
![]() The kit looks good. Are any of the other Rotrex kits going to be CARB legal? In looking at the centrifugal kits the Rotrex variety definitely has the most appeal to me. Cheers Nathan |
#62 | |
Kraftwerks says they are seeking CARB approval, but as of now, Jackson Racing is the only CARB legal Rotrex kit. |
#63 |
#64 | |
Driving Coach
Does the kit come with the correct bracketry to make the side-by-side coolers work? I want to see @Jackson Racing 's official engine oil cooling solution for their car. They say in the instructions that an engine oil cooler is needed before tracking the car, and they tracked theirs extensively in development, yet I still haven't seen a single JRSC FA20 pictured running an engine oil cooler yet... ![]() I still have hope that I could adapt my Perrin OC kit without modification to the sandwich plate/adapter/lines should I get this SC kit in the future. If not, I'd like to know what my options are before installing. |
#65 | |
#66 | |
Driving Coach
I understand you can't give details on the JR OC kit before it's released. |
#67 |
It will not. It's in the same location (or very close to) the FMIC. However, it should be pretty easy to redrill the brackets to sit the oil cooler just a little bit further back.
#68 | |
Driving Coach
I was wondering if I could just get the JR side-by-side bracket and mount the Perrin cooler (generic 10 row Mocal) behind the FMIC beside the Rotrex cooler without having to un-install everything and sell it and buy a whole other kit that will presumably be very similar. |
#69 | |
#70 |
Drives: swp brz
Hopefully this isn't too dumb of a question - From a dead stop if you gun it do you feel glued to your seat?
I noticed in the first post you said everything is very linear, but in another post you said you can definitely feel it above 6k rpms. I came from a mazdaspeed 3 w/ minor upgrades and an ecu and obv turbo and sc feeling are different, but the stock engine has really left me a little lacking. I'm in Cali and this is my daily driver in a police infested zone so I'd like to keep things on the up in up... |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Drift-Office : Jackson Racing Supercharger Installed! (Tune Tommorow!) | Drift-Office | Forced Induction | 164 | 06-20-2014 01:43 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
