#127 | |
The thing that keeps me coming back to Jackson is your comment about them extensively track-testing the car, but it seems like Innovate kits have been used on the track as well with some success.
2022 BRZ Build 2013 FR-S Build |
#128 |
Datalog from lap 5 on RS3 and Jackson Racing Supercharger (this is to make sure everything is nice and toasty).
The system runs COOL. We still need an engine oil cooler, however. This was in about 75F (24C) ambient. Datalogs are in F. Lines are: - Coolant temp (never gets over 200F) - Intake Air Temp (as measured by the car) - GPS speed (proof we're not putzing around the track) - Throttle body position - Brake pedal position
#129 | |
That being said, can you point me to ANY FI car that is heavily tracked? The fact of the matter is that 99% of the kits out there are only being used for the street, and likewise, the kits are being designed for street use. Coming back to your question, are there any dynos of what the Innovate makes when the kit is heat soaked? How about 5+ back to back runs on the dyno? Frankly, I don't care what the kit makes at peak on a dyno, in a single run. I want to know what the output is going to be when I've been flogging the car for 5 minutes straight on track. Every kit we've been testing on the dyno has had multiple back to back runs, and they ALL heat soak to some degree. We'll post results when we finish our analysis and have solid results. Our previous Innovate volunteer unvolunteered, so we do need to find another Innovate car to test on the dyno. For the time being, refer to this post: http://www.ft86club.com/forums/showp...7&postcount=17 and my above datalog. |
#130 |
Drives: Scion FRS (Asphalt)
#131 |
Correct. If you already own EcuTek, then you can purchase JUST the CARB tune if you wanted to. Otherwise, all you'd need to do after getting FI is just a retune (tow to the dyno!)
#132 |
Apart from Robispec and Innovate, I think Abbey Motorsport was testing a twin-screw innovate/sprintex setup on their track car. I know a handful of innovate owners have also trackedtheir cars, including Swift996.
I agree with you on heat-soaked output being more important, but is there a reason to think the Jackson sc will be less prone to heatsoak than the ic innovate sc? That's an honest q, I really don't have enough data on these kits to know which would be better able to resist heat issues on the track.
#133 |
Drives: 2013 BRZ, WRB
@CSG Mike
That's IAT measured just ahead of the throttle body, yes? What were you seeing for oil temp? Nice numbers, thanks a bunch. |
#134 | ||
From Kenne Bell (Positive displacement supercharger manufacturer): http://kennebell.net/KBWebsite/Commo...efficiency.pdf Quote:
| The Following User Says Thank You to CSG Mike For This Useful Post: | DarkSunrise (12-31-2013) |
#135 |
Ah that makes sense. From that article, I take it that the rotrex is both efficient/cool and makes most of its power up top so it sounds ideal for what you guys needed. If it proves reliable under your track testing, I will definitely consider it. Thanks!
#136 | |
The Rotrex rivals turbochargers in terms of compressor efficiency.
#137 | |
Oil temps were high. We need an oil cooler. Output was lowered due to the ECU pulling timing.
#140 |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Drift-Office : Jackson Racing Supercharger Installed! (Tune Tommorow!) | Drift-Office | Forced Induction | 164 | 06-20-2014 01:43 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
