86WORX
Old 05-13-2014, 10:53 PM   #113
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Is there any way to tell what version the ROM is on the OFT? Just curious if the one I received from a vendor had the latest ROM.
Don't want to flash and deal with the stupid gas pedal if I don't have to.
Old 05-14-2014, 12:04 AM   #114
steve99
If you open rom file with hex editor you will see the cali id in the code search for ZA1J as all calid start with this
Andrew025 (05-14-2014)
Old 05-14-2014, 12:07 AM   #115
steve99
Originally Posted by Target70 View Post
<-- an OFT noob.
So the tune version is the numerical value in the a01d? and any higher number would mean a newer tune..ex: a02d, a03d?
Yes except they dont always follw that sequence
Eg usa manual roms
700c
900c
A00c
A01c
B00c
B01c
Dont ask me why i didnt write the code , they are the calid,s issued by manufacturer
Old 05-14-2014, 12:28 AM   #116
steve99
I dont run into gas peddal issue i have flashed 40 times using oft and tactrix
Flash car
Turn off ignition
Turn on ignitio do not start do not touch gass pedal wait 20 sec
Turn off ignition
Turn onn and start do not touch gas pedal
Let idle for couple of minutes till it off cold start and rpm drop to normal idle ie 700 rpm
Turn off ignition
Restart wait for idle to go back to 700 rpm then drive note this is firt time you touch gass pedal , , no lag
Old 05-14-2014, 12:54 AM   #117
Andrew025
Andrew025's Avatar
Flash car
Turn off ignition
Turn off ignition
Turn off ignition
I'll give it a shot.
People were saying to do the flash, turn ignition to on and fully press the gas pedal like 8 times and then turn the car on but that has never worked for me.
Old 05-14-2014, 01:18 AM   #118
SimplePortal
Drives: Hot Lava
So all the OFT tunes would have the idle fix and I would not need to get my stock updated to B01D?
SimplePortal is offline   Reply With Quote
Old 05-14-2014, 01:22 AM   #119
Tromatic
I would like to know as well! DI protection too?
Tromatic is offline   Reply With Quote
Old 05-14-2014, 01:39 AM   #120
phrosty
Yes, OFT tunes all have the DI seal fix. The only reason to ask dealer for an upgrade would be to protect during times you are not running an OFT OTS tune.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 05-15-2014, 12:22 AM   #121
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
So I have just ordered OFT from brz world here in Canada... What programs are going to come preloaded in the tablet? Currently I run a greddy axle back with a perrin drop in filter in my 2013 frs. I have only used shell 91 fuel as it's the only gas around here that is ethanol free.
Sent from my SGH-I317M using Tapatalk
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
Triumphrider is offline   Reply With Quote
Old 05-15-2014, 01:53 AM   #122
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I just got my OFT about 3 days ago, and from my understanding you get every map they have except for special mods like the billet power blocks or Phantom ESC. When you copy your factory tune to the OFT, it will automatically assign 5 different tune variations that are based on your current factory map. These maps are: Stage 1, Stage 2 UL, stage 2 UEL, then I think it is stage 2 UL E85, and stage 2 UEL E85.
with your current mods, I think you should run the stage 1 that it assigns when you "marry" or download your stock tune to the OFT. but as a complete noob myself, that's about all I have figured out.
The Following User Says Thank You to Target70 For This Useful Post:
Triumphrider (05-15-2014)
Old 05-15-2014, 02:28 AM   #123
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Hi guys,
Just to let you know, we are working on an update that will allow us to preload up to 10 OTS maps (instead of 5) per ROM type. This would allow us to preload FI maps, Crawford PB maps, and anything else that we can think of that would be helpful to our customers. We are still several weeks away from release so don't expect the auto-udpate for a little while
Cheers,
Shiv
The Following 7 Users Say Thank You to Shiv@Openflash For This Useful Post:
Chauntalei (05-16-2014), Mytoyo (05-17-2014), RehabJeff86 (05-15-2014), Sojhinn (05-15-2014), solidONE (05-22-2014), Triumphrider (05-15-2014), WRB5titch (05-15-2014)
Old 05-22-2014, 05:55 PM   #124
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
@shiv@vishnu , Is there a reason why my flkc values are logged in values of 0 and 100? http://datazap.me/u/solidone/maft100...zoom=4700-4986
Old 05-22-2014, 06:26 PM   #125
Shiv@Openflash
Drives: 2013 FRS
FLKC isn't being logged correctly in some CAL IDs. It was a project I was working on a couple weeks ago but the whole marriage thing got things sidetracked bit. Right now I'm working on OTS v1.60 map release. After that we will get back to wrapping up some of those extra datalog channels.
Shiv
Old 05-22-2014, 07:00 PM   #126
8686
8686's Avatar
Drives: 86
Shiv
would really like to get some info about the new release.
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Search this Thread:
Advanced Search
Key FOB programming milkesfrs Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 10-21-2015 04:56 PM
Anybody have any experience programming MiniDSP? mid_life_crisis Electronics | Audio | NAV | Infotainment 2 12-02-2013 10:07 AM
