#15 |
AutoX-10/10ths every run
I wouldn't think doing it early could be bad. I had mine done at 1500 miles just to be sure.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
| The Following User Says Thank You to whataboutbob For This Useful Post: | scionfrs2014 (12-22-2013) |
#16 |
Drives: Subaru BRZ Sport Tech Satin White
| The Following User Says Thank You to Suberman For This Useful Post: | scionfrs2014 (12-22-2013) |
#17 |
In the event there was any casting sand or tiny metal chards floating around I changed at 1000 miles. It might have been unnecessary but since it made me feel better it was worth it.
| The Following 2 Users Say Thank You to whaap For This Useful Post: | Gords_zenith (01-03-2014), scionfrs2014 (12-22-2013) |
#18 |
Drives: Nevermorange FRS
All lubricants replaced at 1500 miles. Engine/Tranny/Diff. But that's because I have the tools and means to do it quickly and easily myself.
SCCA T4 - FRS
| The Following User Says Thank You to rice_classic For This Useful Post: | scionfrs2014 (12-22-2013) |
#19 |
is better than you
Drives: 2013 raven FRS
I did mine at 1050 and the drain plug was covered with shavings.
| The Following User Says Thank You to bkblitzed For This Useful Post: | scionfrs2014 (12-22-2013) |
#20 |
Drives: 2010 MS3
Which engine oil/diff oil/tranny and oil filter do you guys use?
#21 |
Drives: 2014 WRB BRZ Limited
#22 |
Drives: 2013 FR-S, 2012 MCS
There was a test done that found metal shavings in the first oil change, and not after that. I went ahead and did mine at 3700 because it was free. Ill start my regular 7500's at the 10k mark. Currently at 6800.
| Tags |
| break-in, change, oil |
| BRZ Engine Break In | Brahsbrah | BRZ First-Gen (2012+) -- General Topics | 10 | 06-17-2013 04:31 PM |
| oil change after break in? | its_the_biz | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 02-22-2013 12:26 PM |
| Fluids change after break-in | yomny | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 08-05-2012 02:18 PM |
| Oil change after break in? | oops86 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 32 | 08-03-2012 01:09 AM |
| How did you break in your engine? | WolfsFang | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 06-05-2012 02:12 AM |
