#141 |
#142 | |
Purely a guess of course
| The Following User Says Thank You to CSG Mike For This Useful Post: | 1086 (02-20-2014) |
#143 | |
![]() There is absolutely power to be gained with E85... especially when you compare the octane and cooling differences vs CA 91! |
| The Following User Says Thank You to CSG Mike For This Useful Post: | *LongFella (02-19-2014) |
#144 | |
If you want less boost, you'll need a restrictor, a very creative tune, a wastegate welded onto the charge pipe, or a smaller pulley. 280whp dynojet would definitely require breathing mods. |
#145 | |
The reason for running more gas is that you use fuel at a higher rate boosted. Additionally, if you fuel starve while under boost, your chances of damaging the engine when you lean out is much higher. It's better to run more gas, and suffer a 20 lb weight penalty, than to be replacing an engine. |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#146 | |
Drives: 2014 Scion FR-S|Whiteout
Any recommendations on which Flex Fuel Kit is the most reliable and easy to install?
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt |
#147 |
#148 | |
I stumped the Almighty Mike! Haha! jkjk I'm not sure I'm game on the flex fuel kits though. A good E85 tune should be sufficient
#149 |
The purpose of the zeitronics unit is so that you can just put E85 in the tank when you have it, and 91 when you don't. It'll automatically analyze your fuel, and adjust accordingly, so that you don't have to dry up the tank, change calibrations, and then switch fuels.
| The Following User Says Thank You to CSG Mike For This Useful Post: | *LongFella (02-21-2014) |
#150 | |
CounterSpace Garage 2014 BRZ (aka BRZ 2.0) Street Concept build journal
Makes sense, but it's a lot harder to remove a flex fuel kit if you want some warranty work done. The other way is simply flashing back to stock and putting 91 in
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt Last edited by *LongFella; 02-22-2014 at 12:36 PM. |
| The Following User Says Thank You to *LongFella For This Useful Post: | CSG Mike (02-21-2014) |
#151 |
Drives: WRB Premium
we want updates!!!
#152 |
Vtec Jesus
Humm in for read later.
OFT Remote, OFH, Motiv OP & FP, Perrin 3' CB & 3' IT, Setrab/MoCal cooler, STI motor mounts, Wilwood 6/4 plot F&R 12.8 kits, Brake ducts, complete Whiteline catalog, complete bushing replacement, OSGiken clutch & Diff, 4.556 FD, Stance W/Spec valving 8/9 Swift.
#153 |
All quiet on the western front.... for now.
#154 |
Drives: Really slow
This car is on the stock clutch yes?
Do you plan on upgrading before the stock one starts slipping? |
| CounterSpace Garage (CSG) | juliog | User/Vendor/Sponsor Reviews, Feedback, Comments | 11 | 10-21-2013 05:08 PM |
| Track day giveaway by CounterSpace Garage | CSG Mike | Southern California | 43 | 04-19-2013 12:12 PM |
| CounterSpace Garage | forwallblakmail | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 04-12-2013 05:31 PM |
| CounterSpace Garage BRZ 2:00 lap at Buttonwillow 13 CW | CounterSpace Garage | Tracking / Autocross / HPDE / Drifting | 11 | 03-07-2013 11:07 PM |
| CounterSpace Garage A++++ | Asphalt~86 | User/Vendor/Sponsor Reviews, Feedback, Comments | 2 | 01-29-2013 02:18 AM |
