#127 |
Drives: 2014 Scion FR-S|Whiteout
CounterSpace Garage 2014 BRZ (aka BRZ 2.0) Street Concept build journal
Any updates on this build? I need my fix... ;-)
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt |
#128 |
Well... I did some heat stressing at SoWS yesterday, and then proceeded to drive back through ACH in snow with bald RS3's.
![]() New radiator prototype is in the car, and the car runs substantially cooler. When the fans kick in, the coolant drops 20F so fast that I can watch it in real time on our display.... I also drove a mildly tuned Fiesta ST and walked away rather impressed. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Anthonytpt (02-04-2014) |
#129 |
Anymore details on the radiator prototype? Is this a CSG future part or am I jumping the gun :-)
#130 | |
This is a part that we will be offering. From our installation experience.... do the radiator before you put on the Supercharger, or you're in for a world of hurt later. Okay, it's not THAT bad, but it certainly takes a lot more effort to install when you have a supercharger and piping in the way. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | *LongFella (02-03-2014) |
#131 | |
Yeah... it was a loaded question ;-) Going to need pics now... LOL!
#132 |
#133 | |
Drives: 94 Jeep
I know this pic is from a while ago, but what is that? Do you use any aftermarket sensors, or are you just pulling data from the CAN (do I have that right?) is it a plug and play affair? Sent from my Nexus 4 using Tapatalk |
#134 | |
It's a unit that we sell; they retail for $700. |
#135 | |
Drives: GR86
What kind of aftermarket sensors can it take? |
#136 |
Drives: UM86 - 6MT
Any details on the JR kit running an e85 tune? With what you have solidified on the 91 tune (i.e. reliability, oem-like drive-ability), can we expect the same on an e85 tune? What hp/tq numbers can we expect?
#137 | |
I'll think there will be a good increase in hp/tq with a proper e85 tune with this kit. In addition, If you look at the speed the rotrex's is running at with the current JR set-up, there's a lot of room for growth even in that area... Get the JR CARB Kit, run the base CARB tune, get a custom e85 tune and flip the "cruise control" switch when you want to run e85... or not when you just want the base map. You get the CARB sticker for us CA folks and an option of e85 power. Win win
#138 | |
Drives: UM86 - 6MT
(sorry long question reply
) perhaps @CSG Mike or David could respond too?The cruise control 'flip feature' is nice, but I would like to have cruise control for strictly cruise control when I take trips, which in that case 91 isn't a big deal and when I am in my city I can run E85. If I have it correctly, the JR kit is making roughly 280 WHP on 91 @ 10psi (give or take some breather exhaust mods) .... So would you say that with the JR kit running E85, we would be seeing 310-320 whp @ 10psi? Can the flywheel and clutch take that? That is like 300 bhp (91) / 350 bhp (e85) at the crank roughly right? What if I only wanted to have the JR kit @ 5 to 7 psi to keep it modest? THEN run E85 at 5-7 psi as well to keep it safe and under 300, at least at first. I like baby steps in these situations. My goal is to get the kit by end of May/ beginning of June. I know people have stated that Tada San said this car could easily handle more power. Has it been confirmed how much added power can be handled? AVO Turbo world breaks down the FA20 being more solid than previous generation of subaru engines... which is encouraging when looking to boost the FA20... Quote:
#139 | |
Drives: Used to Drive:Grand-Am GS #54 E36M3
It seemed unusual that JR stated categorically that 100 octane should be the go-to fuel at the track. Generally, I could understand it for W2W, TT, or the dedicated track rat, but I wonder if the average owner is prepared to go that route, separate from the issue of which octanes are actually available at any given track. Away from the track, how many drivers are prepared or able to put in a tank of 100 before going out for a fun day on the back roads? All that aside, the kit looks very attractive on a bang-for-the-buck basis. Thanks for the detailed review. "100 Octane (R+M/2) Unleaded Fuel - It is important to run fuel designed for abuse at the track. Even stock FA20 engines should run 100 Octane when at the racetrack to ensure consistency and reliability. The additive packages in 91 Octane fuel are designed for emissions and shelf life, while 100 Octane is designed for the high cylinder pressures and full load/throttle conditions you will experience on the racetrack. When at the track, we REQUIRE running a minimum of 50% 100 Octane fuel. We highly recommend running 75-100% 100 Octane when at the track." Source: http://jacksonracing.com/pdf/instruc...brz_manual.pdf - page 3 ------------------ In that same document, JR states that FI'd FA20 engines in the twins are going to encounter fuel starvation (and therefore potential catastrophic engine damage) when in high-G corners with the fuel level between 1/2 and 1/4 tank. They don't say whether this occurs in left-handers, right-handers, or in both. I'm wondering if this has been your experience. If so, do you begin your runs with 1/2 tank or more and then make sure you come in before reaching 1/4 tank of fuel? Or have you successfully addressed the underlying problem - if you have, can you share your solution with us? |
#140 | |
Drives: 2013 Scion FR-S, Raven, Manual
| CounterSpace Garage (CSG) | juliog | User/Vendor/Sponsor Reviews, Feedback, Comments | 11 | 10-21-2013 05:08 PM |
| Track day giveaway by CounterSpace Garage | CSG Mike | Southern California | 43 | 04-19-2013 12:12 PM |
| CounterSpace Garage | forwallblakmail | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 04-12-2013 05:31 PM |
| CounterSpace Garage BRZ 2:00 lap at Buttonwillow 13 CW | CounterSpace Garage | Tracking / Autocross / HPDE / Drifting | 11 | 03-07-2013 11:07 PM |
| CounterSpace Garage A++++ | Asphalt~86 | User/Vendor/Sponsor Reviews, Feedback, Comments | 2 | 01-29-2013 02:18 AM |
