Old 12-18-2013, 03:03 PM   #15
scionfrs2014
Drives: Scion FRS
Thank You
When you're on the floor you know the clutch is fully disengaged, if for some reason the system loses pressure you have extra travel to hopefully get the transmission disengaged.
Also with a high engagement point you don't have to go all the way to the floor to shift, it should be theoretically faster than just going blindly to the floor and back off, unless you have it adjusted perfectly but even then human nature will tend to go 'to the floor - realize you're on the floor - lift off' instead of one fluid motion when not going to the floor.
I await the responses about how wrong I am.
Thank you for your good information. (Let me know if there is an efficient way to send my thank-you message.)
scionfrs2014 is offline   Reply With Quote
Old 12-18-2013, 03:27 PM   #16
scionfrs2014
Drives: Scion FRS
Old 12-18-2013, 05:03 PM   #17
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
i like how the clutch positioning is.
bkblitzed is offline   Reply With Quote
The Following User Says Thank You to bkblitzed For This Useful Post:
scionfrs2014 (12-22-2013)
Old 12-18-2013, 06:11 PM   #18
DarkSunrise
DarkSunrise's Avatar
The clutch adjustment was one of my favorite mods. Much more intuitive to drive now.
2022 BRZ Build
2013 FR-S Build
Old 12-18-2013, 10:41 PM   #19
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Funny enough the FRS has the stiffest clutch of the cars I've driven
Been driving wusswagons then. 86 is silk smooth and fluffy comparable to a clutch that gives you a workout.
The Following 2 Users Say Thank You to bcj For This Useful Post:
scionfrs2014 (12-22-2013), SirBrass (12-26-2013)
Old 12-18-2013, 11:04 PM   #20
strat61caster
strat61caster's Avatar
I never made any claim to the contrary.
All econo boxes and trucks.
ineedyourdiddly
Old 12-23-2013, 02:42 PM   #21
355rockit
Drives: Sci FR-S, Fer F355, Toy Highlander
My Ferrari F355 was in the shop at the time I got my FR-S. When I picked up the F355 after the repair a week later, I mentioned that the clutch was harder to press than usual... the tech said that I am too used to driving the FR-S. Going back and forth between the cars takes a bit of getting used to since the F355 clutch is tighter, engages lower and is more responsive. I kind of like the easier to press in clutch of the FR-S, but would like it to engage lower like the F355.
355rockit is offline   Reply With Quote
Old 12-23-2013, 09:52 PM   #22
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
Wow I had no idea that we can adjust the engagement point. I have def been pretty annoyed with the "late engagement". This is awesome!
dave77 is offline   Reply With Quote
Old 12-23-2013, 10:29 PM   #23
Mikem53
Drives: FR-S 6MT
It's not without its drawbacks.. You loose pedal resistance when you adjust it for shorter travel.. You get a dead spot on top and the resistance is less and mushy,
With less feedback.. I tired it for awhile and put it back to stock..
My experience and .02
Mikem53 is offline   Reply With Quote
The Following 2 Users Say Thank You to Mikem53 For This Useful Post:
dave77 (12-23-2013), Jond63 (05-02-2014)
Old 12-23-2013, 10:33 PM   #24
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
The F355 is an awesome car. Epic exhaust note. Have you needed to change the timing belt yet?
Braces is offline   Reply With Quote
Old 12-23-2013, 10:39 PM   #25
mxrcmxlendon
mxrcmxlendon's Avatar
The clutch pedal is subjective... I find the FR-S clutch to be perfect... but then again, my previous manuals where a mustang and an M3 and both had high clutch engagement... much much higher than the FR-S
Agree, it's subjective.
mxrcmxlendon is offline   Reply With Quote
Old 12-23-2013, 10:53 PM   #26
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
Hmm thanks that's interesting. I don't quite understand how lowering the clutch pedal would make a "dead spot" on top, and why it would decrease the resistance. So why does that happen?
Old 12-23-2013, 11:37 PM   #27
355rockit
I have the tubi exhaust. The F355 is still one of the best sounding engines. Amazing formula one howl at WOT. I had the timing belts changed ~2 years ago. I am good for another 3 - 4 years and the engine comes out again and my wallet gets drained again.
now back to our normally scheduled program..
Old 12-24-2013, 02:12 AM   #28
humfrz
I find it interesting that on the miata forum, most folks felt the clutch engaged too low; on the FR-S forum, many folks feel the clutch engages too high ... why can't "they" get it in the "center" ...?? ...
humfrz
catching, clutch, point
whining/whirring noise during high load/rpm clutch engagement 7thgear Issues | Warranty | Recalls / TSB 105 06-19-2017 12:04 PM
Clutch realeses really high jonbonazza Issues | Warranty | Recalls / TSB 12 12-02-2013 09:12 PM
What are you catching? Amadeus Engine, Exhaust, Transmission 9 05-01-2013 09:47 PM
TriState Toyotas meet sept 9 high point park nj EvilCelica NY / NJ / CT / PA 0 08-26-2012 12:55 AM
