Old 07-15-2014, 07:42 PM   #323
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
Originally Posted by sw20kosh View Post
Does anyone know where that post is of the AVOturboworld car showing the foam ducting they did for the radiator? @AVOturboworld
http://www.ft86club.com/forums/showp...postcount=2931
AVOturboworld is offline   Reply With Quote
The Following User Says Thank You to AVOturboworld For This Useful Post:
sw20kosh (07-16-2014)
Old 07-16-2014, 01:44 AM   #324
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by AVOturboworld View Post
So in stock form only one fan comes on to cool hot coolant? The other fan is 100% dedicated to the A/C? Can this be altered in ECUTEK so that both come on when coolant gets hot?
Old 07-16-2014, 01:52 AM   #325
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Not sure if this can be altered in Ecutek, but I know this is actually very common on many many vehicles out there today.
Sincerely,
Zach
Old 07-16-2014, 02:52 AM   #326
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
as ambient temps continue to climb, I'm really having some heat issues in traffic or stop and go driving. If I don't turn on my heater full blast, I see coolant temps to 218F. Once the car gets moving on the freeway, everything is fine.
What are people seeing temp wise in traffic in hot weather? I'm going to get a vented hood soon but I have a feeling that is not going to be enough. I saw a heat shroud thing on the engine forum, do you think that will help?
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 07-16-2014, 12:25 PM   #327
sw20kosh
It will climb to 216 and then the fan will kick in full blast and bring that down to 206'ish in a few seconds... then it will climb back up to 216 and repeat...
I want both fans to kick in. hmmm
Old 07-16-2014, 12:59 PM   #328
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
rewire. Ill work on it when I get my car back from paint.
Old 07-16-2014, 01:24 PM   #329
mike the snake
I have my fans set to run basically all the time while the car is running.
Temps stay steady at 200-204 regardless of load or conditions, even in 100 degree heat in traffic..
I have the FB radiator, Spal fans, and FB shroud.
Old 07-16-2014, 02:05 PM   #330
sw20kosh
Is re-wiring the stock fans really as simple as it sounds?
Old 07-16-2014, 03:49 PM   #331
Reaper
Reaper's Avatar
Drives: violent
that depends. If the factory wiring/fuse/relay can handle double its intended load then sure, slice the other fan into the first fans wiring harness but I doubt it. You would most likely have to either run a new wiring harness with a relay that is triggered by the primary fan OR removing the trigger wire for the secondary fan and splice the primary fan relay trigger wire into it so the thermostat triggers both relays. The aforementioned probably the best-easy options. The best hard option involves wiring it in a way that turns on both fans with the thermostat and one fan when the ac is on. I need the car to figure that one out as electrical stuff isn't really my favorite thing to do.
Old 07-16-2014, 04:05 PM   #332
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Has anyone thought about louvers on top of the front fenders?
The Following User Says Thank You to cdrazic93 For This Useful Post:
skye67 (07-20-2014)
Old 07-16-2014, 06:32 PM   #333
sw20kosh
Actually just talked to Ptuning's tuner Toan. He says both fans are activated in response to coolant temp. No need to re-wire.
Old 07-16-2014, 08:34 PM   #334
BRZPDX
Boosted Member
BRZPDX's Avatar
well if I put my heater on full blast without the A/C, i can get my coolant temp to hover around 190 ~ 195F which is awesome for the motor but not for me lol. I've been driving with the heater on HI and full blown and it sucks bad.
How do you rig the fan to stay on? I think when the heater is on, maybe both fans are on full blast?
Old 07-16-2014, 09:50 PM   #335
mike the snake
The AC triggers one of the fans.
Running the AC (and subsequently, the other fan) helps keep the temps down better than running the heater.
I think the AC fan also is triggered by higher temps as well.
Not sure, but Ecutek might be able to turn both fans on at a low temp. With both fans running all the time your temps will stay solid and not go up or down.
Especially on a front mount turbo car, both fans running really helps.
Old 07-16-2014, 10:11 PM   #336
sw20kosh
@ptuning says that fans being on when the car is at high speed is detrimental to the fans. Something about over spinning them due to high air velocity through them?
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 04:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 11:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 10:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 07:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 02:18 AM
