Old 05-21-2014, 02:08 PM   #309
mike the snake
On my car, with FB radiator, Spal fans, and shroud, IMO the majority of the cooling is coming from the fans and shroud. Quite a bit of air is moved by the fans and the shroud utilizes All of the radiator. I feel a LOT of hot HOT air being blown by the fans.
This is fine for street and canyon driving, but I think when we get to extended WOT conditions (track use) it is a Lot more important to re-install the ducting/air dams.
It becomes super important for air-exchange, and proper pressures to help draw cool air in, and exhaust hot air out of the engine bay.
I've installed a different crash bumper bar that lets a lot more air in, along with cutting holes in my bumper, which helps with air IN at the high pressure area, and my skidplate and trip-strips mod helps with the low pressure air-OUT area.
Once I install the air dams/ducting around the radiator I hope my car will be able to handle track duty without cooling issues.
For me, it's about addressing ALL aspects of cooling. Simply bolting in a big radiator won't cut it I don't think.
Old 05-21-2014, 02:08 PM   #310
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
But, in modifying the radiator, such companies (possibly assuming the wrong way) would think that the customer would say "hey my old radiator had these ductile thingys on both sides of it, why doesn't this one? Maybe I should go buy one."
But yes, always assume the customer is an idiot. At the same time it's like knowing that all the vaccum hoses will pop off >10 psi. No one knew that until the inspection was taken place, maybe they thought the increased size would negate the need for ducting? Idk I like playing devils advocate.
Old 07-14-2014, 06:22 PM   #311
sw20kosh
Drives: 2013 Black FR-S
Any ideas on how to duct the front radiator/condenser with a crash beam and intercooler/piping in the way?
Old 07-14-2014, 06:39 PM   #312
mike the snake
I'm planning on just getting in there with pieces of foam, cutting them oversize and stuffing them into position. Maybe using some adhesive to hold the foam in place.
This is what the factory uses on the OEM radiator.
Old 07-14-2014, 11:03 PM   #313
Synack
Boosted
Synack's Avatar
Drives: Sideways
Found it:
Originally Posted by VCMC-STC View Post
Hey guys,
Sorry I couldn't get back to you sooner, spent the day at the track.
The heat issue was solved by ducting away heat better and upgrading the stock rad.
From stock there is quite a bit of plastic around the windshield wiper area, we removed this and saw a big improvement in heat dissipation.
Of course upgrading the radiator was a massive piece of the puzzle. In the /Drive video there were a few reasons working against us other than limited testing time. Mainly it was about 20 deg (c) hotter in at the track than in Canada at the time. While it was a shame we had a heat issue that day, he could do 5 hot laps before 1 cool down and back at it for another 5 laps. Which realistically makes it more that capable for any street driving.
That being said, today at track, it was 15 deg (c) and I did numerous sessions, each over 15 minutes and not once did the needle move above 1/4 on the gauge.
Just like the Team VCMC FR-S, the Fullblown kit keeps improving and good golly its quick :P
If you guys have any other questions about our car, the turbo, whatever, I'd be happy to respond!
Richard
I took his plastic removal idea and modified it a bit because my car is daily driven and I wanted to give it function AND form. It might not do quite as good as his mod but I believe it still helps 50-75% of what he managed to do.
Before
After
The Following 2 Users Say Thank You to Synack For This Useful Post:
CSG Mike (07-15-2014), GT86_PRAGUE (08-03-2015)
Old 07-14-2014, 11:24 PM   #314
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
you can now reach your hand into the interior of your car from your engine bay. I drove with that piece off for a day and although it works very well my catch can is there and my car still smells like ethanol. Its also louder when you have the air set to outside. I removed all my clips and slotted my cowl around the wipers so if I ever have on overheating problem somewhere I can slide the entire cowl out. But I don't dd it like that. And theres the water issue.
Old 07-14-2014, 11:37 PM   #315
Synack
Boosted
Synack's Avatar
Drives: Sideways
I designed the cuts after carefully looking at the angles for a while and it looks as though it will still be difficult for water to get in, but air can escape easily. I can't quite stick my hand in there. Maybe half a hand height could fit so it's not terribly prone to outside water or sabotage. It also looks like not much has changed from the outside so it doesn't look all cut up. If there is a problem with that bigger hole then I can put the rubber seal back on in that area, and that would give it less than an inch opening.
Overall I'm happy. Especially because the turbo is right there.
Old 07-15-2014, 07:12 AM   #316
Reaper
Reaper's Avatar
Drives: violent
what i was getting at is thats the intake for your blower motor (HVAC). Turn your air to vent from outside and there will be a flap in there near your battery and the cut you made that opens. You will be venting your turbo heat into your blower motor. It was sucking vapors from my catch can into my car interior in the same spot.
Old 07-15-2014, 11:00 AM   #317
Synack
Boosted
Synack's Avatar
Drives: Sideways
Ah yes I see, my catch can is in the front. It's like our setups are reversed. My turbo is by the battery and my catch can is up front. I have yet to try outside air. I did see that vent when I was cutting the plastic and that's pretty much where I drew the line for cutting. It will still probably pull a decent amount of turbo air, but it won't be completely direct thankfully.
On a side note, my normal drive from Buckhead to Alpharetta this morning showed 10 degrees Fahrenheit colder in the engine bay. And the car didn't feel as bad as it normally does in the summer.
Old 07-15-2014, 01:13 PM   #318
Reaper
Reaper's Avatar
Drives: violent
well thats good. Ive said it over and over and over again that removing that cowl works. It just also sucks engine bay fumes into the car.
Old 07-15-2014, 02:40 PM   #319
Synack
Boosted
Synack's Avatar
Drives: Sideways
I just tried outside air, it wasn't terrible but it was slightly noticeable. I only ever used it before to defog the windows and then immediately put it back to inside air.
My hot weather traffic with little movement test also saw about 6-7 degrees cooler too. It hasn't really been a concern yet, just the car acts more sluggish in traffic. I'm interested to see how this holds on a track.
Old 07-15-2014, 06:03 PM   #320
sw20kosh
Does anyone know where that post is of the AVOturboworld car showing the foam ducting they did for the radiator? @AVOturboworld
Old 07-15-2014, 06:04 PM   #321
sw20kosh
Only if the Recirc button is not pushed in? Or all the time?
Have you tracked the car with the cowl removal? Does it truly evacuate hot air?
Old 07-15-2014, 06:20 PM   #322
Reaper
Reaper's Avatar
Drives: violent
I will say yes from highway tests, but im pretty sure I ended up trying to defrost my window with hot ethanol vapors
The Following User Says Thank You to Reaper For This Useful Post:
DC2R (07-15-2014)
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 04:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 11:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 10:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 07:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 02:18 AM
