Old 04-29-2014, 02:27 PM   #281
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by sidetrak06 View Post
Does anyone have access to a thermal imaging camera? We can stop the speculating about where the heat is going and actually see it!
http://www.flir.com/thermography/ame...=830&col=61190
These things sell for $1,500 and are extremely useful for visualizing heat transfer and fluid dynamics. It seems to me that vendors such as Full Blown could greatly benefit from this relatively small investment and put some extremely powerful R&D to work to come up with innovative solutions to these heat issues. Simply modifications such as removing cowls and modifying skid plates could be visualized on a dyno run in minutes.
The organization I work for may or may not own one of these top end cameras from FLIR. Too bad I don't have my car anymore.
Old 04-29-2014, 02:32 PM   #282
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Any updates from the new owner ? How is the car doing ?
Sent from my IBrick
Old 04-29-2014, 02:34 PM   #283
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I talked with one of the mechanics that works at the local Subaru speed shop called Driven Performance a couple weekends ago, and he said the last time he saw it and talked to the new owner that it was still running great.
The Following User Says Thank You to King Tut For This Useful Post:
SmsAlSuwaidi (04-29-2014)
Old 04-29-2014, 04:43 PM   #284
mike the snake
Here's pics of the work I did today on my skidplate.
I used rubber pieces from the front of my old BMW 135i, which with some cutting, fit perfectly.
I cut the skidplate, installed the rubber strips, and it could not have come out more perfect!
I really think this will help to pull more air out of the engine bay.
The Following 5 Users Say Thank You to mike the snake For This Useful Post:
blackfireball5 (05-21-2014), OjiGeorge (05-24-2014), skye67 (02-08-2015), sw20kosh (05-21-2014), The Racers Line (04-29-2014)
Old 04-29-2014, 08:49 PM   #285
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I have access to flir but I'm in a different country right now.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 04-29-2014, 09:48 PM   #286
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
you need a pressure differential for air to flow. A forward facing hood scoop or "ram air" skid plate, will most likely increase the air pressure in the engine bay behind the radiator and hence reduce the flow of air through the radiator. If you look at the stock car its quite carefully designed to make sure that the maximum amount of air flows through the radiator and not around it.
zoth is offline   Reply With Quote
Old 04-29-2014, 09:54 PM   #287
sidetrak06
Drives: 2013 Subaru BRZ - 6MT Ltd
Here is an example of one being used to evaluate a front mount intercooler.
Fluke Thermal Imager Ti32 on Front Mount IC Durin…: [ame]http://youtu.be/E-Dustxk_aU[/ame]
sidetrak06 is offline   Reply With Quote
Old 04-29-2014, 10:01 PM   #288
zoth
zoth's Avatar
Hoping somebody will make a skid plate like this for our cars.
GrimSpeed are you there ;-)
The Following 3 Users Say Thank You to zoth For This Useful Post:
8686 (05-21-2014), OICU812 (05-21-2014), SirBrass (05-19-2014)
Old 04-29-2014, 10:03 PM   #289
SmsAlSuwaidi
Boosted
@GRimspeed pleaseee
Sent from my IBrick
Old 04-29-2014, 10:09 PM   #290
mike the snake
Louvres I think could be added to our stock skidplate to end up pretty close to the one in the pic.
Old 04-29-2014, 10:12 PM   #291
Reaper
Reaper's Avatar
Drives: violent
Seriously. We need a replacement cowl.
Old 05-08-2014, 09:35 PM   #292
ML
ML's Avatar
Drives: 13 White MT FR-S
Saw this on the "super 86". Idk if this could be applied for a track FI car.
...two little sprayers vaporise water onto the core when temperatures get high.
Old 05-08-2014, 10:50 PM   #293
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
@mike the snake colaborate with GrimSpeed!
Old 05-19-2014, 06:09 AM   #294
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
Instead of removing, how about modifying the windshield cowel to allow airflow without completely eliminating its functionality to catch water when it rains? I'm thinking of cutting holes in mine. I'd like to go for the Seibon TS hood, but I've seen ones that fit well and ones that look like shit. Don't think I want to risk it on a part so difficult to return. Even Seibon wont stand behind the fitment of their product :/
OjiGeorge is offline   Reply With Quote
Search this Thread:
Advanced Search
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 04:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 11:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 10:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 07:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 02:18 AM
