#267 |
I'm going to get the cord so I can plug my laptop into my ECU. I'll be able to read IAT's then.
#268 |
Junior
Drives: a car
#269 |
That hood will probably hinder more than help air flow. You want air to come out of the engine bay not force more into it.
The Frozen North
#270 | |
Trust me, I'm the Doctor
Same here, and the principle is the same, but using the vehicle's velocity as the "fan": evacuate the hot interior air and replace it constantly with cooler outside air.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#271 |
Yes but that air has to then escape the bay. That hood style just forces more air in and actually might pressurise it enough to actually decrease air flow across the radiator due to pressure equalisation. What you need is a rear facing vent or a slash cut style to create a low pressure area over the hood drawing the hot air out
The Frozen North
| The Following User Says Thank You to Dipstik-sportech For This Useful Post: | OjiGeorge (04-29-2014) |
#272 | |
Mr. Cranky Pants
Drives: 2013 Argento FR-S
#273 | |
If you've got air coming in, you've got air going out. The more air coming in, the more air that is going out. Otherwise your engine bay would inflate like a balloon and pop.
#274 | |
Mr. Cranky Pants
Adding places to get air IN doesn't help us. Not even a little bit. Because we need that air going through the radiator on its way into the engine bay. |
#275 |
Airflow will do that anyway. It's the air that is diverted around the radiator which could be used to blow out hot air.
A properly vented hood & an air ram on the aluminum skid plate could do that. Air there wasn't going to the radiator anyway. On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
#276 | |
#277 | |
#278 |
Junior
Drives: a car
I still think actually making the side vents functional is the cheapest and best way to release the trapped hot air in the engine bay.
#279 |
Our intercoolers cover almost the entire front grill, which I think might also restrict a lot of the air that normally would flow through the radiator.
Tomorrow, I am planning on cutting on my metal skidplate to enlarge the engine bay exhaust opening size, and adding my rubber "trip strips", which I hope will help pull extra air from the engine bay. I want to retain some of the protection of the skidplate, otherwise I'd just remove the skidplate altogether. This, coupled with the holes I've cut into the front bumper, I'm hoping will increase the air exchange. I plan to do some "smoke bomb testing" after that. |
| The Following User Says Thank You to mike the snake For This Useful Post: | cdrazic93 (04-29-2014) |
#280 |
Drives: 2013 Subaru BRZ - 6MT Ltd
Thermal Imaging Camera
Does anyone have access to a thermal imaging camera? We can stop the speculating about where the heat is going and actually see it!
http://www.flir.com/thermography/ame...=830&col=61190 These things sell for $1,500 and are extremely useful for visualizing heat transfer and fluid dynamics. It seems to me that vendors such as Full Blown could greatly benefit from this relatively small investment and put some extremely powerful R&D to work to come up with innovative solutions to these heat issues. Simply modifications such as removing cowls and modifying skid plates could be visualized on a dyno run in minutes. |
| any serious benefit Heat Tapes? | Djen | Engine, Exhaust, Transmission | 22 | 02-18-2014 04:20 PM |
| Heat bad for your car? Ways to cool it? | BushMan | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 08-01-2013 11:15 PM |
| Misfire with heat? | bigjake | Issues | Warranty | Recalls / TSB | 2 | 04-28-2013 10:02 PM |
| Do I Need a Heat Shield? | arleewa | Engine, Exhaust, Transmission | 1 | 01-08-2013 07:37 AM |
| Overpipe Heat question | Amadeus | Engine, Exhaust, Transmission | 5 | 12-19-2012 02:18 AM |
