Old 03-24-2014, 08:28 AM   #253
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Originally Posted by pmccut View Post
Interesting. Are your headers/downpipe ceramic coated, wrapped, etc? My experience was completely the opposite, and in even colder weather on redline 10w30 with stock oil pan.
ceramic coated from FBM and wrapped with DEI titanium wrap. Its raining today but the next hot day ill take an engine bay ambient temp. I think its the extra oil.
The Following User Says Thank You to Reaper For This Useful Post:
pmccut (03-24-2014)
Old 04-02-2014, 12:03 AM   #254
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
@mike the snake did you ever get pictures of what you did to the lower radiator mounts ? i might be doing this and wanted to know how much of a hassle it is
Old 04-02-2014, 12:53 AM   #255
mike the snake
I'm sorry, I didn't get pics personally. I'll see if the shop took some pics.
It's pretty straightforward though. With the front end off, you can see where the new holes for the lower posts can go, and there's some metal tabs that need to be ground down so the radiator can move forward, and that's about it.
The Following User Says Thank You to mike the snake For This Useful Post:
SmsAlSuwaidi (04-02-2014)
Old 04-06-2014, 07:54 PM   #256
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
After putting my FMIC last week, engine bay temp significantly increased. Does the BRZ have a smaller opening in the front cowl compared to the FRS?
Need advice regarding getting more flow in the front.. Take off Mustache? I don't think upgrading the radiator is going to help with flow in the front. Does the radiator shroud help with cooling? Or do I need to get like a Ings bumper or somethin.. I know APR makes one as well with a bigger opening.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 04-06-2014, 08:09 PM   #257
Dipstik-sportech
Dipstik-sportech's Avatar
A vented hood or maybe some ducting to funnel more air to the rad. Taking the mustache off won't help much because the crash beam is right behind it, that's what it covers up.
The Frozen North
Old 04-06-2014, 09:58 PM   #258
mike the snake
I installed a different crash bar that allows a LOT more air in after also cutting holes in the "moustache" with wire mesh.
You also have to deal with getting the engine bay heat OUT!
Vented hood is probably the best, but I plan to cut on my skidplate and install rubber strips that hang down, basically upside-down "Gurney Strips" to help pull air out from under the engine.
Sportsguy83 (04-07-2014)
Old 04-07-2014, 12:59 AM   #259
BRZPDX
Boosted Member
BRZPDX's Avatar
How is the engine bay heat after getting the crash bars? man those holes.. all function, no form lol..
Old 04-07-2014, 01:24 AM   #260
mike the snake
I'm going to paint the screens black so it's not as noticeable.
I personally don't like the moustache on the BRZ anyways, so I didn't have an issue with cutting the holes.
I think after I do my mods to the underside (cut the metal skidplate and add the rubber trip-strips), that the engine bay heat will be lowered when the car is moving. More air coming in, and more air going out.
Old 04-07-2014, 09:27 AM   #261
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Enjuku drift bar?
I will eventually install that crash bar. I might in the future do mustache holes too.
Old 04-07-2014, 09:31 AM   #262
mike the snake
Yes, I got it from Enjuku. It's the Drift Armor crash bar. Nice piece and priced right.
My intercooler mounted right up with 2 holes and some short standoffs.
My AC also blows nice and cold because I believe there's more airflow getting to the condensor.
Old 04-07-2014, 10:15 AM   #263
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
http://www.ft86club.com/forums/showthread.php?t=57792
looks like the links may have died on the pics, I'll re-post tonight.
Ironsquid is offline   Reply With Quote
Old 04-07-2014, 12:56 PM   #264
mike the snake
In the pics in this link, it shows the lower rubber grommet that the lower radiator mounting posts stick into.
You can drill the new holes in the forward part of the grommet, and gain a little clearance, or you can drill new holes well forward of the grommets in the frame and gain like 1.5'' to 2''.
The lower radiator hoses easily stretch. Using the Upper tabs, the upper radiator hoses have a hard time giving up any extra length, so a new hose might be needed.
There's also a couple of tabs on the frame that need to be ground down to allow the lower radiator forward. It's pretty straightforward stuff.
Old 04-10-2014, 11:35 PM   #265
mike the snake
I wrapped my intake tube with that gold heat shield tape.
It made a difference for sure.
Before, eveything under the hood was too hot to touch. With the gold foil tape, even the area of the intake that is closest to the downpipe (maybe 1.2''to 2'' away) is cool enough to hold my hand on indefinitely.
I'm thinking of adding the gold tape to the top of the plastic manifold runners. Would there be any issue with having just the top of the intake manifold covered with the gold foil?
Old 04-11-2014, 01:32 AM   #266
Boss Paco
Subaru Certified Sales
Boss Paco's Avatar
Drives: '13 BRZ Premium, '05 WRX STi
What are your IAT's before and after?
[Subaru WRX STi] Benson Block - Kelford Cams - PTE6466 - ID2000s - AEM - E85
[Subaru BRZ] Speed by Design Turbo Kit - Invidia N1 - BC Racing BR Coilovers - Rota RT5s
[Subaru WRX] Prodrive - Subaru Tecnica International - APS - Tein - Rota Titans
"The only thing that I trust in this world is cars!" - Don 'The Goods' Ready
Boss Paco is offline   Reply With Quote
Search this Thread:
Advanced Search
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 04:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 11:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 10:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 07:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 02:18 AM
