Old 06-16-2014, 05:12 PM   #85
WhiteRose
Drives: 2013 Genesis Sedan
Originally Posted by civicdrivr View Post
I still haven't installed the passenger side yet.
Sent from my Nexus 4 using Tapatalk
Cant believe that fits!
Sent from my SM-N900V using Tapatalk
WhiteRose is offline   Reply With Quote
Old 06-16-2014, 05:19 PM   #86
WhiteRose
Originally Posted by mav1178 View Post
You may want to check the types of rails that Bride offers:
http://bride-jp.net/products/super-seat-rail/body/
Depending on the size of your seat you may end up going with an "unconventional" seat rail.
The Bride rail for our cars more or less look like this:
(pic is of a HP10 G20/Primera LH rail)
-alex
Is that slideable?
Old 06-16-2014, 05:49 PM   #87
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by WhiteRose View Post
Is that slideable?
Yup. I just put my Bride rails together yesterday, debating if I want to run it with only a 3-point for normal use or with full bar/harness.
-alex
Old 06-25-2014, 03:40 AM   #88
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
speaking of BRIDE Seats, I have a genuine BRIDE Seat for sale
http://www.ft86club.com/forums/showthread.php?t=68764
glamcem is offline   Reply With Quote
Old 06-25-2014, 12:14 PM   #89
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Is there any aftermarket seat or other stock (like from a Focus ST or RX8 r3 or something) that is fully functional like the stock seat (tilts forward, can be lowered/raised, side bolster adjustment, side airbag still functional etc) ?
Khyron686 is offline   Reply With Quote
Old 06-25-2014, 12:29 PM   #90
Model Citizen
Lacking brains
Drives: frz
http://www.ft86club.com/forums/showthread.php?t=46801
Still holding up fine after about 9 months and 20k miles.
Been worth every penny for the headroom.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 06-25-2014, 06:41 PM   #91
executivekoala
executivekoala's Avatar
Drives: fr-s
Anyone have issues with the bc rails, mine feel like they are bent and have play. I have to sit pretty far back meaning the rail is unsupported some. Also I'm 6'1 220 so I think my weight has a part in it. Just want to know if I'm the only one
executivekoala is offline   Reply With Quote
Old 06-27-2014, 02:58 PM   #92
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
I did like the other guy with the RX8 seats but with Evo X seats. All fully functional but no airbags. Not smart enough or brave enough to figure out how to rewire them.
http://jademotorsports.com/custom-re...seats-in-fr-s/
jadewbj is offline   Reply With Quote
Old 06-27-2014, 08:55 PM   #93
Model Citizen
Lacking brains
Drives: frz
don't rewire, just swap,
in my case with the rx8 seat it went amazingly easy. Was a bit harder when i did the same thing putting gr sti seats into my forester. May have to carve out a bit of foam or fill in some foam, but the general idea of side bags is all roughly the same thing.
Old 06-28-2014, 11:02 PM   #94
Pacific Auto
Master Installer
Pacific Auto's Avatar
Drives: Scion FRS
Sparco Evo 2 with re-welded buddy club rails.
Pacific Auto is offline   Reply With Quote
Old 07-15-2014, 07:50 AM   #95
Dstylez
Drives: Satin White Pearl BRZ Limited
I have Bride Brix ii seats from years ago I intended to put in my AE86 but lately been thinking about putting into my BRZ. I do know that they aren't "side mounted." Any suggestions on rails and brackets to get these in?
Dstylez is offline   Reply With Quote
Old 08-08-2014, 08:10 PM   #96
Lawnik
Lawnik's Avatar
Drives: Flat grey Toyota 86
Originally Posted by umpadupa View Post
sry! another questions!! how did you get the weight sensor out? what does it look like?
im sry bro!! i swear this could possibly be the last question
Originally Posted by moomoopanda View Post
My red Bride Zeta 2 with Buddy Club RS Rails. I also have a resistor inserted so that I don't have an airbag light on my dash.
What resistor did you use to eliminate the light?
Lawnik is offline   Reply With Quote
Old 08-09-2014, 04:33 AM   #97
moomoopanda
moomoopanda's Avatar
Drives: Argento FRS
I used the resistor found in the following link. Bought a ten pack on accident, but they work as advertised. I've never had an issue with my airbag light since using the resistor.
http://www.ft86club.com/forums/showthread.php?t=16293
Originally Posted by Ricepuddin View Post
Warnings:
1)Always disconnect the battery when dealing with Airbags.
2) I am not responsible if you damage your car or yourself during this install
I am assuming if your doing this DIY you have already figured out how to remove the seats and disconnected the the battery and the wires connected to the seat.
First thing you need is a Resister with a resistance of 3.3 Ohms.
Amazon.com: 3.3 Ohm 1W Flameproof Resistor 10 Pcs.: Electronics
Locate the yellow harness .
You will notice that there are only 2 wires connected to the harness but are 4 holes (sorry the picture doesn't really show it, i'll try to get a better one before Install the seat tomorrow morning), you want to plug the resistor into the bottom two holes.
No it does not matter which side of the resistor you plug into which hole. Also I am just going to use electrical tape to secure it for now, later I will find the other end of the connector and solder the resistor to that, and insulate it with shrink wrap.
moomoopanda is offline   Reply With Quote
The Following User Says Thank You to moomoopanda For This Useful Post:
Lawnik (08-11-2014)
Old 08-09-2014, 07:37 PM   #98
wrohdejr
Drives: 2013 subaru limited wrb brz
Just installed these a few days ago.
Portland 86ers
wrohdejr is offline   Reply With Quote
Search this Thread:
Advanced Search
Using OEM Mic for Aftermarket Radio AND/OR Replacing OEM Mic with Aftermarket Mic ecko04 Electronics | Audio | NAV | Infotainment 10 05-05-2018 04:47 PM
SOLD: Used (But Like New Cond.) Stock FR-S Seats w/ rails (Both Seats) Vicious LED Interior Parts (Incl. Lighting) 16 07-21-2013 07:45 PM
WTT: My FRS seats for your BRZ Premium Seats Hanakuso Interior Parts (Incl. Lighting) 17 03-04-2013 02:37 PM
Aftermarket Seats sets off SRS light? Hanakuso Cosmetic Modification (Interior/Exterior/Lighting) 1 08-25-2012 06:09 PM
Please post FR-S w/ aftermarket leather seat pics ngabdala Scion FR-S / Toyota 86 GT86 General Forum 6 05-31-2012 10:51 AM
