86WORX
Old 02-02-2014, 02:00 AM   #57
MadFRS
MadFRS's Avatar
Drives: UltraMarine FR-S
I am looking to keep the factory seats (for now), but what I really need is to be able to lower the seat more. What would be the best way to give myself a lower seating position? For reference, I am 6'3" and I feel I am looking more down the hood, than out the front over the hood. Would I be able to purchase just rails to mount to the seats? Even if it was a fixed mount I would be fine. No one drives the car besides me anyways.
My searching hasn't given me the best results. Hopefully you more experienced members could shed some light. Thanks
She's Gone....
Flickr Page
MadFRS is offline   Reply With Quote
Old 02-02-2014, 07:31 PM   #58
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Scooby South View Post
The ones I am using is on the left. But even with max adjustment.. the sliders don't fit correctly to floor of the car...the sliders are Pinched limiting movement.. so the side rails themselves will need more adjust to go wider to accommodate the seat itself. more "Z" to be able to actually mount the seat to the car..then there's the narrow tunnel on the 86 limiting the size of seat you can actually put in, for full range of adjustment...
Bride seat rails for this car do not "bottom out" completely, the rail will be between the seat and the floor of the car.
Bride rail measurements:
Bolt hole to bolt hole (side of seat): ~11 3/8" to 11 5/8"
Seat width: 16" (the bracket centers on the seat rail width)
Pics:
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
Scooby South (02-03-2014)
Old 02-03-2014, 11:57 AM   #59
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
Originally Posted by umpadupa View Post
i think so! but we need a pro to chime in. So, without the sensor, whats gonna happen? malfunction? no pass airbag?
PS: @jadewbj & @spitfire481
u guys are genius
EDIT: http://www.club-tc.com/threads/remov...lt-warning.67/
maybe this will work for scions!
Not really "rip apart" you just need to remove a few hog clips underneath it to peel back the cover over the seat area. Then put new hog clips on.
If you don't have the sensor hooked up the passenger airbag will never be activated and you will have an airbag light in your dash.
jadewbj is offline   Reply With Quote
The Following 2 Users Say Thank You to jadewbj For This Useful Post:
Scooby South (02-03-2014), umpadupa (02-04-2014)
Old 02-14-2014, 03:54 PM   #60
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
Seeing all these pictures makes me really want a seat haha.
leicaboss is offline   Reply With Quote
Old 03-22-2014, 10:40 PM   #61
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Any new information out there.. Still havn't decided on what mounts I need to use.. or seats for that matter.. mav1178
Good info on your measurements .. thanks ...I have a 36 inch waist and I need something that is comfortable and gets me lower in the car so my helmet clears the roof. (I am 6'3"). I drive to events so they also have to be reasonably comfortable. And they can't break the bank. I would spend about $500 for the seat and bracket ...and the whole assemebly has to weigh At least 25lbs.
Bill
Scooby South is offline   Reply With Quote
Old 03-22-2014, 10:53 PM   #62
Model Citizen
Lacking brains
Drives: frz
Bill
Recaro speed?
I'm similar size long in torso, was about all that had harness holes that worked when I sat in seats at a local shop.
Till finding rx8 Recaro the speed was my plan
Model Citizen is offline   Reply With Quote
The Following User Says Thank You to Model Citizen For This Useful Post:
Scooby South (03-22-2014)
Old 03-25-2014, 05:46 AM   #63
nograde
Drives: Scion FRS
does anyone know if the buddy club rails will allow for a lower than stock seat height? Or are the nagisa rails the only ones that will allow this? Thanks.
nograde is offline   Reply With Quote
Old 03-31-2014, 07:50 PM   #64
Scooby South
Conedancer
Ok.. I ended up with a Corbeau FX1.. I used the stock sliders with Custom side rails. and stock seat belt mount. Very happy.. I appreciate everyone's input.
Here are the pics. I have some tinkering to do. but for the most part, Done
Thanks
Bill
Old 03-31-2014, 08:24 PM   #65
Scooby South
Conedancer
just test fitted with my helmet.. GOOD to go. it probably sits about 1/4in higher than the lowest stock setting ..but it works.
Bill
The Following User Says Thank You to Scooby South For This Useful Post:
Churg (03-31-2014)
Old 04-06-2014, 09:03 AM   #66
Sh944
Unwashed Heathen
Drives: 2014 Scion FR-S
Seriously, if they did, I'd have bought one and trust me, I looked. The dealer won't sell the passenger sensor separately as it's part of a "safety assembly" and they apparently can't get it without buying a whole seat.
If you are running an FRS on the street, you do NOT want to disable the passenger airbag unless you never have a passenger in the car. If you get into an accident, even if it's not your fault, and the passenger gets injured or worse, you'll have a serious liability suit on your hands as well as potential criminal charges.
Sh944 is offline   Reply With Quote
The Following User Says Thank You to Sh944 For This Useful Post:
Tristor (08-25-2018)
Old 04-17-2014, 02:20 AM   #67
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
On the Nagisa rails for the 86, what's the inside-to-inside rail width measurement? I want the seat to drop in between the rails and get my seating position least 2" lower than stock...my hip width is right at 14", and wear size 34" waist pants. I am interested in the Sparco EVO II...but at ~16.5" width shell, will it fit between the Nagisa rails? Would also be interested in the Sparco Ergo (medium) which is ~16.3" width shell. If these don't work I guess I would be forced to go with the Bride Zeta III Type L, or Type XL if it will fit between the rails...wonder if a Sparco Corsa would fit as well (400mm/~15.7" shell width)....would be a really tight squeeze though.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 05-28-2014, 04:23 AM   #68
WhiteRose
Drives: 2013 Genesis Sedan
So if you want the side air bags to still go off in an accident all you need to do is get a passenger seat sensor and driver seat sensor for them to deploy, correct?
WhiteRose is offline   Reply With Quote
Old 05-28-2014, 05:02 AM   #69
R2RO
R2RO's Avatar
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
Here's my Bride Stradia II Japan Venus in my FR-S
R2RO is offline   Reply With Quote
The Following 3 Users Say Thank You to R2RO For This Useful Post:
8R6 (11-03-2015), Goya (05-28-2014), JDsThatGuy (03-31-2016)
Old 05-28-2014, 01:55 PM   #70
WhiteRose
Originally Posted by spitfire481 View Post
The drivers seat just needs a resistor stuck into the airbag connector that comes out from under the carpet underneath of the seat. Nothing else. The passenger seat needs the same airbag plug resistored, but also needs the weight sensor transferred over into the new seat, underneath of the fabric/lower foam. I think there MIGHT be a way to turn off the passenger weight sensor through Toyota techstream software. More than likely it will still show a fault since it is not plugged in and will still show an open circuit
So its better to just get one bucket seat because the driver side is a lot more simpler? (:
Sent from my SM-N900V using Tapatalk
Search this Thread:
Advanced Search
Using OEM Mic for Aftermarket Radio AND/OR Replacing OEM Mic with Aftermarket Mic ecko04 Electronics | Audio | NAV | Infotainment 10 05-05-2018 04:47 PM
SOLD: Used (But Like New Cond.) Stock FR-S Seats w/ rails (Both Seats) Vicious LED Interior Parts (Incl. Lighting) 16 07-21-2013 07:45 PM
WTT: My FRS seats for your BRZ Premium Seats Hanakuso Interior Parts (Incl. Lighting) 17 03-04-2013 02:37 PM
Aftermarket Seats sets off SRS light? Hanakuso Cosmetic Modification (Interior/Exterior/Lighting) 1 08-25-2012 06:09 PM
Please post FR-S w/ aftermarket leather seat pics ngabdala Scion FR-S / Toyota 86 GT86 General Forum 6 05-31-2012 10:51 AM
