#29 |
Unwashed Heathen
Drives: 2014 Scion FR-S
Here is the Recaro Sportster CS I installed on Monday evening.
As for the passenger side weight sensor, does anyone know if Scion uses the same sensor in other cars besides the FR-S? I spent some time working with a dealership and apparently, the sensor is not available separately, you can only buy the sensor as a part of a seat assembly (ie the entire seat). While it might be fairly easy to remove the sensor from the factory seat, installing it properly in the Recaros will take quite a bit more effort and I am trading my current FR-S in for a new one in a couple of months and want to be able to swap the Recaros directly into the new car and put the old seats back in. It will be a LOT easier for me to be able to get an extra sensor rather than try and use the one thats in the original passenger seat. As to the air bag replacement, its not going to explode without applying voltage and isn't inherently dangerous. Without doing some engineering studies to see how it will function in its new installation, its hard to say what might happen (unintended consequences are indeed hard to predict) but I suspect if the new installation mimics the original one, it should be fairly safe as the side impact doesn't fire directly at an occupant. |
| The Following User Says Thank You to Sh944 For This Useful Post: | APS86 (12-18-2013) |
#30 |
Drives: GTS86 Manual
which seat rails did you use for the recaro's
#31 |
blowhard
Drives: frs, project forester
#32 | |
Conedancer
Drives: 2013 Subaru BRZ SWP
Bill
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
#34 |
Drives: 2JZ FRS
recaro pole position. recaro side brackets, planted bases. no sliders
| The Following User Says Thank You to spitfire481 For This Useful Post: | humanshield (01-31-2014) |
#35 |
Unwashed Heathen
How did you handle the passenger side weight sensor issue?
#36 |
Drives: 2JZ FRS
| The Following 3 Users Say Thank You to spitfire481 For This Useful Post: |
#37 |
Marine Electrician
Drives: Toyota TRD86, 2014
#38 |
Drives: 94 civic hatch, Whiteout frs
Hey guys! Im looking to swap both my seats out and i was worried about the airbag warning. Everyone just puts a sensor in; is there another not so sketch way? or just duck tape it down? also i was wondering will i run into problems swapping the passenger side seat too? Thanks! @spitfire481 did you have to do that?
Thanks! |
#39 | |
Boosted
Drives: Not a supra....yet
#40 |
Drives: 2JZ FRS
The drivers seat just needs a resistor stuck into the airbag connector that comes out from under the carpet underneath of the seat. Nothing else. The passenger seat needs the same airbag plug resistored, but also needs the weight sensor transferred over into the new seat, underneath of the fabric/lower foam. I think there MIGHT be a way to turn off the passenger weight sensor through Toyota techstream software. More than likely it will still show a fault since it is not plugged in and will still show an open circuit
| The Following User Says Thank You to spitfire481 For This Useful Post: | RehabJeff86 (01-27-2014) |
#41 | |
#42 | |
Drives: 2005 Toyota Camry
I know Bride seats offers a bracket that allows their rails to be used with Recaro buckets. I'm running a Zeta III + Bride rail myself. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | Scooby South (01-27-2014) |
| Using OEM Mic for Aftermarket Radio AND/OR Replacing OEM Mic with Aftermarket Mic | ecko04 | Electronics | Audio | NAV | Infotainment | 10 | 05-05-2018 04:47 PM |
| SOLD: Used (But Like New Cond.) Stock FR-S Seats w/ rails (Both Seats) | Vicious LED | Interior Parts (Incl. Lighting) | 16 | 07-21-2013 07:45 PM |
| WTT: My FRS seats for your BRZ Premium Seats | Hanakuso | Interior Parts (Incl. Lighting) | 17 | 03-04-2013 02:37 PM |
| Aftermarket Seats sets off SRS light? | Hanakuso | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 08-25-2012 06:09 PM |
| Please post FR-S w/ aftermarket leather seat pics | ngabdala | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 05-31-2012 10:51 AM |
