#155 | |
Drives: FRS
#156 |
Drives: '14 Midnight Purple FR-S
#157 | |
Drives: 13' Toyota GT86
Looks great! you don't happen to have the part numbers for the seat rails? I might have a pair of CS I can use but need rails. Cheers. |
#158 |
Looks good.
Please post the full setup. Seat, Rails, If the seat is centered, how low it sits compared to stock, the steering wheel, hub. And what you like/dislike about the setup. Also the shifter and the details, like if you hit the dash going into the 1st/3rd/5th and what gear it is in, in the pic.
#159 | |
Steering wheel is a suede Sabelt SW-633 with a Splash (Works Bell) short hub, it's actually a little too close to the signal/wiper stalks right now so I have a spacer on order until I'm ready for a quick release. ![]() Shifter is a TWM Competition shifter, no problems with hitting the dash, but I've slipped once and punched my radio before hahaha.
| The Following User Says Thank You to Krovi For This Useful Post: | swarb (07-18-2015) |
#160 | |
A Demon
Drives: Raven GT86
Looks like you need a resistor :p Sent from my iPhone using Tapatalk |
#161 |
@Krovi are they really centered? Which L brackets are you using? From my experience with buddy club brackets and recaro spg and pole positions; they sit to the left of center. This has been the case on multiple cars I have sat in.
#162 |
It's the Mad Cow
I thought I posted here but I guess I didn't.
Did these Evo 8/9 seats back in 2014. I want to say around March. Either way they have the pressure sensor in the seat for awhile but not where it could work properly as I would have to take the seats apart and I do not want to cause issues. Now it's just under the seat. Resistor for the Airbag Light, everything works great. I have to say seeing someone else's work with the Recaro's out of the RX8 I might give that a shot next as a friend really would like these. Guess we will see what happens. First two pictures are from when we installed them, after that I have not really taken many pictures of the interior so I used the most recent with my wife in the drivers seat.
05 GTO 408 Stroker \ 13 FRS 210 Twin Screw Supercharger on E85 \ 14 F-150 5.0L |
| The Following User Says Thank You to Cross For This Useful Post: | RallySport (09-01-2018) |
#163 | |
Drives: Brz WRB - Europe LHD
#164 |
Edirb 023 red stitch with bride rails and Takata drift 3 harnesses
#165 |
Drives: 2014 Toyota GT86
Bride Zeta 3 Type L FRP and Type FG rail
#166 |
Right now , I have the stock seat belt buckle flip over and it clear everything .
I want the OEM belt to hold better and plan to redo it again soon . I am thinking let the seat belt go through both side tunnel , use the rear seat belt buckle (lot shorter) , and do a resistor on the buckle wire(someone mention just unplug it ?) to trick it . So on street I fasten the seat belt from top , and I can plug the belt in through side tunnel on track for better holding . If anyone know a better solution ? If not , I just try ... |
#167 |
I got the seat belt buckle done , now the seat belt can go through both the side hole , find my confidence on hard braking again , no more slip out from the seat .
It take some time to figure it out what to do , I check both front rear seat buckle and both of them are tall and bent , not idea fit . So I have one of the rear cut and weld , make it straight and short .Don't need resistor for seat belt chime , take the wire/harness out of the buckle and unplug it from the connector under the seat . |
#168 |
Drives: 2JZ FRS
| The Following User Says Thank You to spitfire481 For This Useful Post: | M1K3 (06-17-2016) |
| Using OEM Mic for Aftermarket Radio AND/OR Replacing OEM Mic with Aftermarket Mic | ecko04 | Electronics | Audio | NAV | Infotainment | 10 | 05-05-2018 04:47 PM |
| SOLD: Used (But Like New Cond.) Stock FR-S Seats w/ rails (Both Seats) | Vicious LED | Interior Parts (Incl. Lighting) | 16 | 07-21-2013 07:45 PM |
| WTT: My FRS seats for your BRZ Premium Seats | Hanakuso | Interior Parts (Incl. Lighting) | 17 | 03-04-2013 02:37 PM |
| Aftermarket Seats sets off SRS light? | Hanakuso | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 08-25-2012 06:09 PM |
| Please post FR-S w/ aftermarket leather seat pics | ngabdala | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 05-31-2012 10:51 AM |
