| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
| View Poll Results: What name should Toyota use for the production Toyota FT-1? | |||
| Supra gets my vote! |
367 | 74.59% |
| I don't know, but its time for a new name. |
125 | 25.41% |
| Voters: 492. You may not vote on this poll | |||
#4061 |
Drives: many
Toyota is already asking a lot of me to accept this Supra if it's notably over 3100lbs. That's pushing my limits. The idea big brakes, X-Men magneto suspension and big block boosted V8's will make me or other driving enthusiasts forget we're shoving an extra 800-1000lbs thru a canyon is beyond the pale of sensibility.
Also the notion that the Camaro has visibility barely any better than a WW2 Sherman tank is borderline GM fanboyism if you ask me. Maybe a Lambo Huracan on airbags would be more comparable in that regard. If people were wondering who this car could be for, let's start with all the complainers that moaned for eons the 86 should have come with a turbo and more power. Well, here u go. Please can we move on now from that sad old tale?? If we can, the Supra is worth it for that reason alone if you ask me. |
| The Following 7 Users Say Thank You to abraxis For This Useful Post: | Dadhawk (01-09-2019), Irace86.2.0 (01-08-2019), R_E_L (01-09-2019), SuperTom (01-09-2019), Ultramaroon (01-09-2019), WolfpackS2k (01-09-2019), ZDan (01-09-2019) |
#4062 | |
Panda Trueno
Drives: No twin now.
It's not gm fanboyism, originally this new supra was thought to be on par with the C7, now it's been took down a notch. With a four cylinder turbo option it seems like this will be Toyotas version of a pony car in the market. Of course comparisons will be made. The sixth gen+ camaros are radically different than their predecessors in a lot of ways, including visibility to some extent. Weight is of course inherently hard to overcome, but some of the bigger offerings mask it well. It will be interesting to see how the supra truly winds up when its released and the mass of comparisons start. |
| The Following User Says Thank You to Summerwolf For This Useful Post: | Dadhawk (01-09-2019) |
#4063 | |
Drives: '12 C63 P31, '17 GTI Sport, '00 MR2
Meanwhile I can get 10 track days out of the Pagid Yellows on my Cayman. And 6 days & 20-25,000 street miles on my tires (Pilot Super Sports).
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
| The Following User Says Thank You to WolfpackS2k For This Useful Post: | Irace86.2.0 (01-09-2019) |
#4064 |
Drives: Q5 + BRZ + M796
I’m sure the size can become less disagreeable as the driver becomes acclimatized to the dimensions, but I have gotten into a ND Miatas and immediately felt that it was too small, and I have gotten into vehicles larger than the BRZ like the WRX, Jetta GLI, etc then into pony cars; they all felt huge. In fact, I’ve owned two MKIV Supras, and the first time I got into one and did a walk around I thought it was huge. I’m more of a BRZ, RX7, etc sized driver.
#4065 | |
Panda Trueno
That's a valid concern for someone that is primarily track oriented and concerned about consumable prices. Has Toyota even said what size wheels / tires are on the new Supra? |
#4066 |
Panda Trueno
@Irace86.2.0-Doesn't the MK IV supra have a shorter wheelbase than the BRZ?
100.4 for the supra vs 101.2 for the BRZ or are these not the correct numbers? |
#4067 |
Drives: BMW
dimensions on the A90, for the 100x...
A90 Wheelbase 2,470 mm (97.2 in) Length 4380 mm (172.4 in) Width 1855 mm (73 in) Height 1,290 mm (50.8 in) A80 Wheelbase 2,550 mm (100.4 in) Length 4,515 mm (177.8 in) Width 1,811 mm (71.3 in) Height 1,265 mm (49.8 in) about the same size as the 718 Cayman 982 Wheelbase 2,475 mm (97.4 in) Length 4,379 mm (172 in) Width (70.9 in) Height 1,295 mm (51 in) |
| The Following 3 Users Say Thank You to gymratter For This Useful Post: |
#4068 | |
The length of the MKIV vs 86 is 10''. I sold my 96' hardtop Supra in 2007, so it has been 11 years, but from memory, the hood was not only longer, but was taller. The 86's hood also slants down, which really makes it feel smaller from the driver's perspective. The MKIV was wider by an inch, but I wish I had seat to seat or door panel to door panel comparisons because the 86 feels like the cabin is smaller. The MKIV has the same or slightly shorter height, but inside, I recall the seats were taller, probably to allow enough vision over the hood. The 86 has adjustable height (mine is at the lowest setting). The driver sits slightly further forward in the 86, and the visibility over the front fenders is better than the MKIV. I don't recall if the rear felt more spacious, and the rear seats were further back and larger because the car was a hatch, but I feel like it felt bigger--bigger in the height and width of the rear hunches. Again, it has been a long time. Of course the thing that felt the most different was the weight. It was 600lbs heavier than the 86. The weight and suspension made it feel really planted on the road like rock solid, even at 120-140 mph+, but it was still lumbering and soft in the corners compared to the 86. My first supra was a targa 93' and the chassis flex was horrible with the top off, so bad that I rarely took off the targa if I was even considering driving aggressively on turns--only if I was doing a gentle cruise. That's why I bought a hardtop later, but that flex added to the sense of weight. The MKIV probably had better sound deadening and thicker components making for a sense that I was in a larger, stronger structure, even if the 86 shares similar dimensions. ![]() My feelings are the new Supra will feel both smaller and bigger than the 86, but definitely smaller than the MKIV. It appears to be five inches shorter than the MKIV. It may be lighter, but obviously heavier than the 86. It will likely feel much smaller in cabin size being a two seater. The fact that the 2JZ was an inline six and the B58 is a slant six hopefully means the hoodline will be lower, yet BMW usually adds a whole bunch more stuff on top of the engine, including an air-water intercooler. EDIT: Dimensions play a large roll in size perception, obviously, but the weight is the bigger thing for me. Just adding my 65+lb Harrop supercharger to the BRZ feels cumbersome at times and changes the driving dynamics. Adding a passenger does even more. The MKIV is equivalent in weight to me loading up three, two-hundred-pound passengers. Even if the dimensions are similar to the 86, that weight is significantly noticeable.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Summerwolf (01-09-2019) |
#4069 |
Drives: 2020 BRZ tS
| The Following 2 Users Say Thank You to LancePower For This Useful Post: | funwheeldrive (01-10-2019), Irace86.2.0 (01-09-2019) |
#4070 |
Drives: 2013 frs, 2005 is300
Hopefully that 73" phat ass is sexy :P
#4071 | |
Drives: 2013 Whiteout FRS
| The Following User Says Thank You to m.box.design For This Useful Post: | Irace86.2.0 (01-10-2019) |
#4072 | ||||||||
Drives: '23 BRZ
FWIW the 4-cylinder 1LE is a direct price competitor to the FT86 with Brembos. What does that mean? Personally, despite it being a lot slower, the BRZ PP was by far *the* car for me to buy. Camaro 1LE, while IMO a very cool car in it's own way, is just not for me and emphatically NOT what I want for a DD and track car. The subjective experience *is* very different... Quote:
Any case, I don't want or need for this car to be a Japanese/Austrian/German C7. Quote:
But anyway, consider for a moment that it's late 1969, there's a 230hp SOHC 6 Firebird on the market, and also a 150hp SOHC6 240Z. Did anyone cross-shop these cars? Probably. Are they *really* comparable? Not to me they aren't. Surely the Firebird was quicker, but for me, SO WHAT, 240Z all day every day... Quote:
| The Following User Says Thank You to ZDan For This Useful Post: | Irace86.2.0 (01-10-2019) |
#4073 | |
Length 167-171" Width 73-74" Height 52" Wheelbase 100" HP: 350 TQ: 275 Wt: 3232lbs I do think the 370Z is a little chunky in some departments, but I also expect it to be more stout and less leaned out than the 86.
#4074 | |
Drives: '23 BRZ
Supra should be an improvement over Z for me based on positioning of driver's posterior relative to wheelbase, *way* aft, just in front of rear wheels, like in my beloved/departed 240Z and S2000... |
| Tags |
| bmwforsuckers, boring-zzzzzzzzzzzzz, brz, celica supra confirmed, frs, ft-1, hatch-y +1, morethanucanaffordpal, nomanualnogo, supra, toyota, twins, watstheretailon1ofthose |
| Toyota FR-S : Official Name for the FT-86 Concept? | Dark | Scion FR-S / Toyota 86 GT86 General Forum | 155 | 08-05-2010 12:05 AM |
